Barefoot Sound MicroMain45
m1ts0s
News poster
"Barefoot Sound is proud to introduce our newest studio monitor, the MicroMain45. Featuring the same signal path, amplifier and driver technologies as our flagship MiniMain12, the MicroMain45 is stripped down to the bare essentials in order to deliver renowned Barefoot resolution and translation at a more affordable price. Prepare yourself for the next Barefoot revolution!"
Description:3-way active monitor
Controls:Input level stepped attenuator, Equalization contour
Input Impedance:50k Ohm
Frequency Response:40Hz – 45kHz (±3dB),
53Hz – 40kHz (±1dB)
Bass Response:-3 dB @ 35Hz, Q = 0.707
Slope = 12 dB/octave
Cabinet:14 liters total internal volume, Sealed woofer and midrange enclosures, Machined aluminum baffle plate, Long fiber wool acoustic damping throughout
Crossover Frequencies:600 / 2500 Hz
Tweeter:1″ ring radiator, Advanced geometry motor, Rear waveguide chamber
Amplifier: 180W Hypex
Midranges:
2 x 2.5″ aluminum cones, Advanced geometry motor, +/- 2 mm linear excursion
Subwoofers:
8″ aluminum cone with high linearity motor, +/- 13 mm linear excursion
Amplifier: 250W Hypex
AC Power Input:Nominal 115 VAC or 230 VAC selectable
Power Consumption:Idle: 18W, Maximum: 400W
Weight:Speaker: 37.5 lbs each (17 kg)
Shipping: 47 lbs each (21 kg)
Dimensions HxWxD:Cabinet: 11.0 x 15.5 x10.75 inches (279 x 394 x 273 mm)
Overall: 11.0 x 15.5 x 11.0 inches (279 x 394 x 279 mm)
http://barefootsound.com/micromain45/
m1ts0s
News poster
Στο gearslutz κάποιος πέταξε ότι η τιμή θα είναι 6000 δολλάρια το ζεύγος (τίποτα επιβεβαιωμένο).
JAndronikos
