Denon AVR-X5200W Dolby Atmos AV Receiver
Nelsy
Ιεράπετρα
Pros
  • Supports Dolby Atmos and Auro-3D (with upgrade)
  • Offers some of the most versatile speaker and amp configuration options we’ve seen
  • Does everything but make you coffee
Cons
  • Confusing setup options and terrible user manual
  • Includes the world’s worst impedance selector switch
http://www.audioholics.com/av-receiver-reviews/denon-avr-x5200w
Safety Last * tl;dr *
Τα Dolby Atmos speakers που τοποθετούνται πάνω σε υπάρχοντα παίζουν άσχημα. Αυτό το περιμέναμε βέβαια. Τα οροφής παίζουν όπως πρέπει.
Φρικτό manual, κακό menu με λανθασμένες ονομασίες.
I was a bit surprised to find the AVR-X5200W downsampling to 48kHz, thus limiting the high frequency bandwidth to just over 20kHz once the DSP was engaged. I confirmed with Denon that the receiver does this to conserve MIPS given all the processing power needed for Dolby Atmos and Audyssey. Audio purists will want to engage Direct mode for recordings with sampling rates higher than 48kHz as long as they don’t mind giving up Audyssey EQ and Atmos for purity of signal. Direct mode and Pure Direct mode will still allow you to enjoy the full resolution of Dolby TrueHD and DTS-HD with no downsampling.
Και σ' αυτόν, όταν χρησιμοποιούνται Audyssey και Atmos κάνει τα πάντα downsample στα 48KHz αφού δεν επαρκεί η επεξεργαστική ισχύς.
With the low setting engaged, no matter how many channels were driven, the output was limited to about 25 watts/channel with one channel driven and significantly less with all channels driven (18 watts for seven channels driven). Denon jumped on the impedance switch bandwagon to get the UL 4 ohm rating, but severely choked off performance in doing so. This is likely due for two reasons, inadequate heat sink area to keep the receiver running cool enough for the rating, and an overzealous and cautious safety engineer that took things just a little too far. Regardless of whatever speaker impedance you have, under NO circumstance do I EVER recommend using the low impedance setting. Just leave it at the default 8 ohm setting and forget there is even an option to change it.......Regardless of whatever speaker impedance you have, under NO circumstance do I EVER recommend using the low impedance setting.
Όταν επιλεγεί το 4Ω για τα ηχεία, ο ενισχυτής περιορίζεται σε λιγότερα απο 25W ανα κανάλι...
Άλλο ένα προϊόν που βγήκε στην αγορά χωρίς να είναι έτοιμο.
Τέλειο το κάνει.
ειναι θεμα .....μεγαλες βουτιες με 12db διαφορα !!!!!!
ειναι +/- 6 db το οποιο θα λεγαμε οτι δεν χρειαζεται καν να μπεις στον κοπο να κανεις αυτοματη ισοσταθμιση ...παιρνεις ενα ντεσιμπελομετρο μετρας σταθμες και βαζεις αποστασεις ηχειων....και αποτι δειχνει παιζει καλυτερα φλατ ο av
Η νέα σειρά Denon υποστηρίζει ηχεία 4ohm; Ενώ στο site τους, αν δεν κάνω λάθος, αναφέρει για 8, είδα από κοντά (δεν θυμάμαι ποιο μοντέλο ήταν) στην αντιπροσωπεία καινούργιο που έγραφε πίσω για 4. Συγκεκριμένα μου το ανέφερε ένας εκεί, όταν τον ρώτησα για ηχεία 4ohm και τον 3313.
  • rose.athens
PiterPan
