Mede8er ….UFO aka MED1000X3D
Νέο firmware για όλα τα X3D:http://www.mede8erforum.com/index.php/topic,15469.0.html
V3.0.7_4Dec2014 BETA
1. Dev - Browse for Subtitle during Video Play - Supports HDD, USB, Samba and NFS - default will open existing folder and user can navigate the tree structure by selecting the 'Return' icon
2. Dev - Transmission BT : updated to v2.84
3. Dev - Video playback: will support Multi play for ISO media
4. Dev - Video playback: if .MVC.' is included in filename then the file will auto open in 3D
5. Fixed - USB Keyboard: navigate button (left/right/select ,etc.) no response in some screens
6. Fixed - String table: DUTCH: 'HDD slaap stand' -> 'needs to be: HDD slaapstand’
7. Fixed - Some special Korean smi SUB files not readable
8. Fixed - Hebrew Subtitles
9. Fixed - Subtitle Search for TV series - if naming 'TVSeries.Name.1x03.Episode.Information.ext' then only the TV Series name would be loaded for the search
http://www.mede8er.org/beta/Firmwares_Beta/MED1000X3D/2014/X3D_Series_V3.0.7_BETA_4Dec_2014.zip
V3.0.7_11Dec2014 BETA
1. Added User Selectable Thumbnail Focus Colours - In Media Library set the 'View' to one of the Thumbnail Views and Navigate to Devices Screen or any folder structure and press the 'Menu' button on the remote. Focus on new option 'Thumbnail Colour and and press 'Enter' and you will be able to select a colour from the list.
2. Fixed TV Series Episode Subtitle Search
3. Fixed File Manager Background image
4. Fixed GUI bug when returning from TV Series and navigating to the Devices Screen
5. Fixed string table: Setup Menu 'Verander category' -- > 'Verander categorie’ for Dutch user
Temporary pulled, due too issue found,
Νέο διορθωτικό firmware κυρίως για το χθεσινό crash που είχαμε.
Ακόμη βέβαια έχουμε 12/12//2014!;)
http://www.mede8erforum.com/index.php/topic,15524.0.html
V3.0.7_13Dec2014 BETA
6. Fixes crash bug in release V3.0.7_11Dec2014 BETA
http://www.mede8er.org/beta/Firmwares_Beta/MED1000X3D/2014/X3D_Series_V3.0.7_BETA_13Dec_2014.zip
Καλημερα,
σε νημα για τον Popcorn Hour A-410,και συγκρινοντας απο διαφορα tags στο internet,βρισκω καποιες παραπανω δυνατοτητες του Α410 σε σχεση με το M8RX1000 3D..(βεβαια και το..€χάρτι ειναι παραπανω...
Το θεμα ομως ειναι,αξιζει να ρισκαρω απο υποστήριξη,firmwares,συμβατοτητες αρχειων..? Στην.. twindigital δεν βλεπω να το στηριζουν με κομματι support & download,οπως με το M8R!!
Στους υποτιτλους πως συμπεριφερεται ο Α-410 σε σχεση με τον M8RX1000? Παίζουν οι 3d υποτιτλοι απροβληματιστα?εχουν διορθωθει προβληματα απο παλαιοτερα νηματα που ειχαν παρατηρηθει?
Οντως ο 1000 δεν υποστηριζει διαφορους εξελιγμενους τυπους ήχου οπως το HD MA ..?
Δινω μεγαλη βαρυτητα στον ηχο σε συναρτηση με την ταινια διοτι το αμεσως επομενο διαστημα θα κατακλειστουμε απο εξελιγμενα φορματ ηχου και διοτι το ηχοσυστημα βγαζει ακομα και 9.1(BDV N9200).
Οπως καταλαβαινεται στο mp,με ενδιαφερουν μονο οι ταινιες-εξελιμενα full HD,3D UO,χωρις να με ενδιαφερουν τα GB....(10,20...50)..επισης θα παιζω απευθειας απο το mp με ενσωματομενο σκληρο.
Παρακαλω να στηριξουμε την συζητηση για να προβω ΑΜΕΣΑ σε αγορα ενος εκ των δύο!!
Στο Mede8er x3d, οι 3d υπότιτλοι είναι πιο απροβλημάτιστοι απ,ότι στο Α-400/410
HD Audio Master χωρίς κανένα πρόβλημα στα Mede8er
H Twindigital αντιπροσωπεύει στην Ελλάδα τα Mede8er και παρέχει πολύ καλή υποστήριξη γι αυτά.
Δεν είναι αντιπρόσωπος των Popcorn.
Νέο firmware για όλα τα X3D - V3.0.7 - 25Dec2014 BETA -X3D Series
V3.0.7_25Dec2014 BETA - Αλλαγές / Βελτιώσεις:
1. Movie Scraper: added new scrape layouts ‘C' 'D'
To test or use a New Scraper Skin - Select the Movie Scraper Skin in Setup Menu 'Misc' --> 'Scrape Layout' ie A, B,C,D
a. Open an existing movie sheet that was scraped with Mede8er's built in Movie Scraper and press the Edit Button on the remote. Re- Scrape or just select 'Save' and the about.jpg will be updated to the layout you selected.
b. To update all about.jpg's in a Movie JukeBox.
On Favourites Screen focus on a Movie JukeBox and then press the 'Menu' button on the remote and select 'Clear about.jpg'. Now focus on the same Movie JukeBox and press 'Menu' button on the remote and select 'Scan' and the X3D will rebuild all the about.jpg's to the new scraper skin layout.
Sample Movie Scraper Layouts:
Type A : http://www.mede8er.org/artwork/temp/2014/Forum/Scrape_layout_A.jpg
Type B : http://www.mede8er.org/artwork/temp/2014/Forum/Scrape_layout_B.jpg
Type C : http://www.mede8er.org/artwork/temp/2014/Forum/Scrape_layout_C.jpg
Type D : http://www.mede8er.org/artwork/temp/2014/Forum/Scrape_layout_D.jpg
2. Defaulted Auto Standby to 'off'
3. Defaulted HDD Spin Down to 'off'
4. Transmission: due some random freeze reverted back to stable version v2.44
5. Fixed smi sub that includes includes tag 'SAMIParam' - Korean
7. Hdd SpinDown: will not Spin down HDD when Transmission BT is 'on'
8. Updated some Language text strings
Το κατεβάζουμε από εδώ
Στο wifi μοντέλο μπορείς να κάνεις enable/disable το wifi μέσω κάποιου menu; Όχι να βγάλεις την κάρτα (αν γίνεται κι αυτό δηλαδή...) απλά να το απενεργοποιείς όποτε θέλεις.
Χμμμ επικοινώνησα με αντιπροσωπεία και δεν είναι διαθέσιμο - είναι μάλιστα πιθανό να μην το ξαναφέρουν απ' ότι κατάλαβα...
Σου είπε μπορεί και να μην το ξαναφέρουν?Περίεργο αυτό!
Μόνο για το 1000x3d ή και για τα υπόλοιπα mede8er το είπε αυτό?
Βασικά δεν το έχει ετοιμοπαράδοτο (έχει διαθέσιμα κάποια 600 χωρίς wifi και τα 800 αν θυμάμαι καλά) και όταν τον ρώτησα αν γίνεται παραγγελία απάντησε ότι θα ξέρουμε μετά τις 15 Ιανουαρίου. Για να μη μου είπε ξεκάθαρα ότι μπορεί να το παραγγείλει πιθανόν και να μη γίνεται, άρα και ίσως να μην το ξαναφέρει. Δικό μου συμπέρασμα αυτό όμως, ο ίδιος μου ανέφερε τα περί 15 Ιανουαρίου, δεν είπε επί λέξει ότι μπορεί να μην ξαναφέρει...
Τώρα είδα στη σελίδα της twindigital ότι το 1000x3d καταργήθηκε.Αν θες με εσωτερικό δίσκο γιατί δεν αγοράζεις το 800x3d που είναι λίγο πιο φθηνό και έχει ακριβώς τις ίδιες δυνατότητες με το 1000x3d?
Το non-WiFi καταργήθηκα αλλά το 1000άρι WiFi το δείχνει κανονικά διαθέσιμο. Για να είμαι ειλικρινής ενώ το 800άρι μ' αρέσει περισσότερο εμφανησιακά (ok δεν είναι κριτήριο αυτό αλλά το 1000άρι είναι λίγο κουλό σα σχήμα) με χαλάει το ότι έχει ανεμιστηράκι, ειδικά δεδομένου ότι τα άλλα δεν έχουν (φαντάζομαι είναι λόγω του σκληρού + στο 1000άρι πιθανόν να βοηθάει το σχήμα και το μεταλικό περίβλημα για την απαγωγή της θερμότητας). Θα μου πεις πόσο ακούγεται... Έλα ντε; Επίσης ευχαρίστως θα πήγαινα στο 600άρι αλλά θέλω το coaxial audio output (και ο σκληρός δε με χαλάει!). Κάπου επίσης διάβασα και κάποια διαφορά για το audio output σε σχέση με το 1000άρι;
Δεδομένου ότι δεν το βιάζομαι (δε θα με χάλαγε να το έπαιρνα και άμεσα βέβαια) λέω να περιμένω λίγο. Το βρίσκω βέβαια και σε amazon αλλά η διαφορά τιμής είναι μικρή και προτιμώ να το πάρω απ' τον εδώ αντιπρόσωπο, εάν είναι εφικτό.
Πάντως δε θέλω ντε και καλά το 1000άρι, απλά προτιμώ να έχω όλες τις επιλογές διαθέσιμες :)
Ελάχιστα ακούγεται το ανεμιστηράκι στο 800άρι.Δε θα σε ενοχλήσει καθόλου.Το 1000άρι δεν έχει ανεμιστήρα.Το 800άρι με το 1000άρι δεν έχει καμία άλλη διαφορά.
Νέο firmware:http://www.mede8erforum.com/index.php/topic,15621.0.html
V3.0.7_30Dec2014 RC XXXXXXXXX Final Release Candidate XXXXXXXXXX
1. Changed Movie Scraper Skin Type D - sample http://www.mede8er.org/artwork/temp/2014/Forum/X3D_BD_Cover_Movie_Skin_C.jpg
2. Updated Movie Scraper Skin Type C
3. Added Spanish Translations
4. If Transmission BT is set to 'on' will turn it back to 'on' 'after reboot
http://www.mede8er.org/beta/Firmwares_Beta/MED1000X3D/2014/X3D_Series_V3.0.7_BETA_30Dec_2014.zip
Νέο firmware και stable:http://www.mede8erforum.com/index.php/topic,15654.0.html
V4.0.0_2Jan2015
Changelog
New Functionality
1. New Movie Trailer Functionality - new setup option 'Trailer' On/Off, default is On.
How to get Movie Trailers links
a. Delete xml's and do a new Scan or
b. Use 'Add Trailers' option on Favourites Screen for existing Movie JukeBox's that were generated in the X3D or for Jukeboxes that have been scraped with external PC based Scrapers like Y2M / Thumbgen etc
c. You can use the 'Add Trailers' option to update the Movie Trailers as often as you like.
d. Use ‘EDIT’ on about.jpg (Movie Info Sheet) on one by one basis
e. Use 'Add Trailers' option for JukeBox+ structures that dont have Trailer tags - in this case the xml files in the source Movies folders will also be updated.
How to view Movie Trailer:
In Movie JukeBox open the Movie Info Sheet 'about.jpg' and you will see two new Icons - 'Play' and 'Movie Trailer'
To play the Movie - select the Play Icon (default focus when Movie Info Sheets opens' and select 'Enter'
To Play the Movie Trailer - use 'Right Nav' to change focus to the Movie Trailer Icon and select 'Enter'
Note: CC option in Movie Trailers is not supported by the X3D HTML5 Browser
2. Dev: Added Support for Local Trailer Play.
Instructions
Copy Movie Trailers into Movie Folders
Name the Movie Trailers 'xxxxx.trailer.*' xxxxxx = any name * = extension
If X3D finds the local trailer it will play it from Trailer Play Icon on the info sheet (about.jpg) and if not it will play the YouTube Trailer as normal if the xml has the <Videos> node.
Instructions for JukeBox+
As above but copy the trailers into the movie folders in the 'data' folder of the JukeBox+
Movie Trailers Online User Guide
http://www.mede8er.com/mede8er_x3d_movie_trailer_user_guide_V0.html
Local Trailer Downloader Guide
http://www.mede8erforum.com/index.php/topic,14953.0.html
3. Added User Selectable Thumbnail Focus Colours - In Movie JukeBox or Media Library set the 'View' to one of the Thumbnail Views and Navigate to Devices Screen or any folder structure and press the 'Menu' button on the remote. Focus on new option 'Thumbnail Colour' and and press 'Enter' and you will be able to select a colour from the list.
4. Added Subtitle Browse during Video Play - Supports HDD, USB, Samba and NFS - default will open existing folder and user can navigate the tree structure by selecting the 'Return' icon
5. Added three new additional built in Movie Scraper Skins 'C' 'D' 'E'-- Setup -> Misc -> Scrape Layout.
To Update Existing Movie Collection
a. You can use the 'Edit' option and update Movie by Movie - Open movie info sheet 'about.jpg' and press the 'Edit' button on the remote and then select 'Save' and the info sheet layout will be updated.
b. Bulk Update - Focus on a Movie JukeBox on the Favourites SCreen and press the 'Menu' button on the remote. Select the option 'Remove about.jpg' and all the exiting movie info sheets will be deleted. Now select 'Scan' and the Movie Info sheets will be rebuilt with the new skin you selected. Note - this option does not rescrape the movies but just rebuilds the Movie Info sheets from exiting images and xml files. If you require to rescrape the collection the you must delete all the 'movie.name.xml' files and then Scan the JukeBox.
Note - If you notice some random noise on the Movie Poster on the Movie Info Sheet with Skins 'C' 'D' and 'E' then the movie must be rescanned.
6. Multi Play Video playback for .ISO files
7. MakeMKV 3D Video playback files: if '.MVC.' is included at the end of the filename then the file will auto open in 3D
8. Improved Movie Scrape accuracy by including 'Year' in the search - folder name should be - ‘movie name (year)’-
if If the Movie Scraper App fails to match release name it will try to match to original movie name. Updated Movie Scraper App tmdb: 1.3.2
9. Dev. Updated TV Series default background layer images
10. Added support for French folder names for TV Series - TV Series : Séries TV - Season : Saison - Specials: Hors-Saison
11. Added support for MPO 3D image playback and auto open in 3D
12. Added 'Auto Standby' options 3,4,6,8,12 hours - set default to '0' hours.
13. Added 'Auto Detect Encoding' setup option for auto detection of Korean subs.
14. Added setup option 'Remember JukeBox Filters' for Movie JukeBox.
15. Replaced YouTube HTML5 on Home Page with YouTube Flash
16. NETAPI: Updated to V1.3 - Added new commands
Added new commands to list X3D Mac Address - Command: info ethaddr Command: info wifiaddr
Added new commands to 'Scan' JukeBox - Command: jukebox scan ID
17. If Transmission BT was set to 'on' it will auto set back to 'on' after reboot
18. Added some extra colour setup nodes in skin xml for skin developers - 'FocusText' 'TextColor'
19. Dev: media library: 'folder.jpg' removed case sensitivity
20. Changed default text colour in GUI to R192 G192 B192
21. Subtitle menu: changed default to border shadow type and second option to mirror shadow type.
22. Setup Menu: removed 'System - Screensaver - Options - Flickr'
23. Setup: set option 'Force Decode AAC/MP3' to 'on' as default.
24. Updated support for community Movie Scraper Skins - http://www.mede8erforum.com/index.php/topic,15603.0.html
25. Added Genre images for 3D and JukeBox+
26. Set 'xvYCC' video Setting to default 'off'
27 Set AutoView and JukeBox View to default 'on'
28. Set watched indicator to mark videos if over 90% of the video is watched
Bug Fixes
1. Fixed - Subtitle Search for TV series - if naming 'TVSeries.Name.1x03.Episode.Information.ext' then only the TV Series name would be loaded for the search
2. Fixed - Some special Korean smi SUB files that could not be read
3. Fixed - '._' "dot underscore" OSX files problem
4. Fixed - Arabic SRT subtitles
5. Fixed - SUBParser: will split new line when sub include symbol '|'.
6. Fixed - Watched indicator: does not work on TV Series if you press NEXT >>| or PREV <<| to switch another episode.
7. Fixed - TV Series Navigation Bug - Navigate with Right Nav Button 123456..up - up to Episode #16 it correct and then the focus jumps to #21 – should be #17,18, 19 ,20 then 21
8. Fixed - Movie Jukebox: will fail to scrape movie when folder name has Western European symbols.
9. Fixed - Jukebox+: menu 'empty' function not working on fat32.
10. Fixed - Jukebox+: does not copy the 'cover.jpg'image
11. Fixed - Resume Play BDISO/BDMV: random subtitle selected.
12. Fixed - USB Keyboard: navigate button (left/right/select ,etc.) no response in some screens
13. Fixed - NETAPI: fixed query during screensaver.
14. Fixed - TV Screensize adjuster not working when using custom skins
15. Fixed - Crash when Powering Down during movie playing
16. Fixed - Movie Jukebox: After navigating the movie sheet (about.jpg) with up /down Nav and Movie Play the focus does not return to the correct Movie Thumbnail.
17. Updated Language translations
19. Fixed GUI bug when returning from TV Series and navigating to the Devices Screen
20. Fixed - skin customization as some images were not updating
21. Fixed - spdif audio: auto set audio config to support Core 5.1 passthrough when using HD Audio ie DTS MA/Dolby True HD on SPDIF.
Note: for YouTube exit on USB Keyboard - Ctrl + ',' = Stop
Array of new built in Movie Scraper layouts in V4
New Movie Scraper Layouts High Res
http://www.mede8er.org/artwork/temp/2015/Mede8er_X3D_v4_Movie_Scraper_A.jpg
http://www.mede8er.org/artwork/temp/2015/Mede8er_X3D_v4_Movie_Scraper_B.jpg
http://www.mede8er.org/artwork/temp/2015/Mede8er_X3D_v4_Movie_Scraper_C.jpg
http://www.mede8er.org/artwork/temp/2015/Mede8er_X3D_v4_Movie_Scraper_D.jpg
http://www.mede8er.org/artwork/temp/2015/Mede8er_X3D_v4_Movie_Scraper_E.jpg
http://www.mede8er.org/Firmware_Final/MED1000X3D/X3D_Series_V4.0.0_2Jan_2015.zip
παιδιά δώστε μια βοήθεια ...
μετά το τελευταίο firmware έχω πρόβλημα με την αναπαραγωγή ταινιών.
αυτό πρώτη φορα έγινε.
olla τα αρχεία είναι BDMV η iso ....
το πρώτο πρόβλημα einai ότι όταν πατάω να παίξει από ένα φάκελο δε κάνει τίποτα και δε το κάνει σε ολα σε άλλες παίζει...και σε αυτεσ που παιζει μου ανοίγει το εξώφυλλο τις ταινίας και μου βγάζει πάνω αριστερά την επιλογή να πατήσω για να παίξει.αυτά πριν δε τα έκανε...και το άλλο πάλι είναι όταν πάταγα το (I) ΜΟΥ ΕΒΓΑΖΕ ΤΑ ΕΞΩΦΥΛΛΑ ΣΕ ΜΕΓΑΛΗ ΜΕΓΕΝΘΥΣΗ ...ΤΩΡΑ ΔΕ ΤΟ ΚΑΝΕΙ...
Κάνε από την αρχή scan όλο τον φάκελλο που έχεις τις ταινίες και δες αν είναι εντάξει μετά.
Πως μπορώ να καθαρίσω όλο το παλιό scrap από τούς φακέλους?είναι 3TB ο άσκληρος και είναι δύσκολο " να σβήσω ξεχωριστά κάθε φάκελο στο pc
Παναγιώτης55
