Linkwitz LXmini
πολυ ωραια δουλεια :thumbsup:
αυτο που βλεπω και γω ειναι οτι το LXMini, το δινει με το MiniDSP, ενω το pluto "φοραει" to ετοιμο που λες...
οπως ρωτησα και πιο πανω, ειναι το mini γενικα ας το πουμε, μια καλυτερη εκδοση του pluto?...
επισης, απ οτι αναφερεις, ανετα μπορει κανεις να δουλεψει το pluto, με aftermarket dsp (minidsp κλπ)
αυτο που διαβαζω παντως στα λιγα review μεχρι τωρα, ειναι οτι αλλαζει εντονα (σε σχεση με αλλες σχεδιασεις) ο χαρακτηρας του ηχειου, αναλογος τοποθετησης, καθως επισης και οτι λογο σχεδιασης, υπαρχει μικρο θεμα με τα "δυναμικα"
παραθετω αποσπασμα απο review...
...Setting these speakers up is interesting, their presentation changes more than most depending on how close to the walls they are and the imaging doesn’t really gel until they’re about two or three feet from the rear wall. You get more bass power further back but that is not what the Pluto is about, in fact they strike me as being better suited to 2.1 operation. The bass is not very extended by box standards, it’s clean but lacks power. This can be a tolerable compromise if everything else is strong enough to distract you and they do one thing really well, that is imaging. You’ve heard the term holographic bandied about, well this speaker pretty much does it. And it does it as well as models costing significantly more. The absence of a vibrating box around the drivers really pays off with a soundstage that’s as big as the room will allow but not overblown. Live tracks like Nils Lofgren’s Keith Don’t Go sound spectacular, the atmosphere of the venue crackles and the voice and guitar sound extraordinarily present. This result was not achieved without some tweaking however, primarily with the speaker cable. By replacing the supplied cable with some relatively affordable DNM Stereo made for a significant increase in clarity and pace, you could hear a lot more. The supplied cable allows them to image well but they are more capable than that.
The weakness of the system is that it can struggle with complex rhythms, when a big band starts playing dense material things can get congested. The other limitation is dynamics, it’s not possible to get the energy levels that you can with a conventional speaker and amp pairing of similar price. The rhythmic limitation is only obvious with certain material but the dynamic one is harder to ignore.
zakman35
Ναι το LXmini φτιάχτηκε με βάση το miniDsp 2x4, ενώ το Pluto είχε ένα ASP σχεδιασμένο από τον Linkwitz.
Εγώ τα δικά μου Pluto τα έφτιαξα με το miniDsp 2x4, οπότε έπρεπε να φτιάξω το cross μόνος μου, μιας και τότε ο Linkwitz δεν είχε ασχοληθεί με αυτό.
Όσον αφορά τα δυναμικά του Pluto είναι λογικό να είναι περιορισμένα, αφού το tweeter είναι 84 db, 15 Wrms (60 watt max), αλλά και πάλι είναι σχετικό αυτό, αν σου αρκούν στάθμες 90-95 db τότε το Pluto θα σε καλύψει, αν θες να ακούς μεγάλες ορχήστρες με στάθμες 110 db και πάνω τότε θες τρίδρομο – τετράδρομο ηχείο με πολλές μονάδες π.χ LX521.
Άλλωστε ο ίδιος περιορισμός ισχύει και σε πολύ ακριβότερες υλοποιήσεις π.χ.GrimmLS1.
Ιδανικά τo Pluto πρέπει να τοποθετηθεί όσο το δυνατόν μακρύτερα από αντικείμενα και τοίχους, σε ισοσκελές τρίγωνο και σε σχετικά κοντινή απόσταση 2 μέτρα τον ακροατή. Το ηχείο ζυγίζει 2-3 κιλά οπότε είναι εύκολο να το τοποθετείς στην ιδανική θέση κάθε φορά που θες να κάνεις ακρόαση και πάλι πίσω στην θέση αποθήκευσης όταν δεν τα ακούς. Άλλωστε κανένα ηχείο δεν παίζει σωστά κοντά σε τοίχους και αντικείμενα.
Το σημαντικότερα πλεονεκτήματα των Pluto, είναι η εντελώς τρισδιάστατη και ολογραφική εικόνα που σου προσφέρει κάτι που δεν θα το βρεις σε καμία συμβατική σχεδίαση και βέβαια ότι επηρεάζεται πολύ λιγότερο από τα room modes σε σχέση με συμβατικά ηχεία καμπίνας.
Φαντάζομαι ότι το LXmini είναι ακόμα καλύτερο.
αυτο που αναφερεις περι τρισδιαστατης εικονας, ειναι ενα απ τα κυρια χαρακτηριστικα που ψαχνω απο ενα ηχειο...
παιδευομαι τωρα με τη τοποθετηση αυτων που εχω, να πετυχω οσο το δυνατον καλυτερο αποτελεσμα στο τομεα αυτον... θελω τα ηχεια απλα, να "εξαφανιζονται" απ το χωρο ας το πουμε...δεν το χω πετυχει...θα εξαφανιστουν, μονο αν τα βγαλω απ το δωματιο:D:D
το mini ισως ειναι καλυτερο απ το pluto, λογο αναβαθμισεων σε καποιους τομεις, αλλα απ την αλλη δεν ειναι full ενεργο και αν ειναι κατα τι μικροτερο απ το pluto, σιγουρα θα εχει περισσοτερο θεμα με τα "δυναμικα"...θα μου πεις, μπορεις ανετα να του κοτσαρεις 2 hypex ή κατι αλλο...σου δινει τη δυνατοτητα να "παιξεις"...κατι που δεν μπορεις να κανεις με το pluto...αν το συνοδευε και ενα σαμπ, ισως κερδιζε λιγους ποντους στα δυναμικα...
αναγκαστικα λοιπον, αν παρει κανεις "ετοιμο" το pluto, παιρνει τα ενισχυτικα και το dsp του Linkwitz...δεν μπορεις να τα δουλεψεις με εξωτερικο dsp σαν αυτο που εχει το mini...σε τετοια περιπτωση, πρεπει να "πειραξεις" cross
πολυ θα ηθελα να τα κατσω διπλα-διπλα με ενα ενεργο κλασσικης σχολης (box), να δω τι θα ακουσουμε
zakman35
Και τα δύο ειναι ενεργά. και τα δύο έχουν το ιδιο μεγάφωνο και την ίδια καμπίνα στα χαμηλά.
Το Pluto έχει Asp το mini Dsp.
Πάντως ο Linkwitz λέει ότι το μινι είναι ένα lx521 για μικρούς χώρους, είναι σχεδόν ίδιο στη απόδοση του 3d της στερεοφονικής ψευδαίσθησης εκτός κάτω απο τα 200hz και το roll off κάτω απο τα 45hz.
Andreas79
