Διάφορα (αυτοκίνητο - μοτοσυκλέτα)
Y
Yiannis_B
Αυτή που έχει πίσω, δημιουργεί πίεση στο πίσω μέρος με αποτέλεσμα να ελαφρύνει το μπροστινό, να σηκωθεί και να τον πάρει ο αέρας.
(αεροτομή)
(αεροτομή)
ΕΙΝΑΙ ΦΤΙΑΓΜΕΝΑ 1500ΗΡ+ ΝΤΡΑΓΚΣ ΜΟΝΟ ΓΙΑ 0-400 ΚΑΙ ΕΙΝΑΙ ΕΝΑ Η ΔΥΟ ΑΛΕΞΙΠΤΩΤΑ ΓΙΑ ΝΑ ΚΟΨΕΙ ΤΑΧΥΤΗΤΑ.
ΠΟΛΛΕΣ ΦΟΡΕΣ ΕΙΝΑΙ ΥΠΟΧΡΕΩΤΙΚΑ ΚΑΙ ΑΝΟΙΓΟΥΝ ΕΙΤΕ ΜΑΝΟΥΑΛ ΕΙΤΕ ΜΕ ΡΑΔΙΟΦΑΡΟ ΣΤΑ 400Μ
Eδώ το ίδιο που πιάνει τα 300 χλμ./ώρα σε μόλις 4.4''
ΠΥΡΚΑΥΛΟΣ.......
Η 911 ΤΟΥΡΜΠΟ ΚΑΝΕΙ 0-200 ΣΕ 8,5 ΚΑΙ ΤΗΝ ΘΕΩΡΟΥΜΕ ΓΡΗΓΟΡΗ......
Y
Yiannis_B
The Bible.
http://www.mediafire.com/view/zl1m3tzmjt0/Twist+Of+The+Wrist+Vol+1.pdf
http://files.meetup.com/1510087/A Twist of the Wrist II.pdf
Κάποτε δεν ξέραμε τι είναι countersteering...-και πολλοί μοτοσυκλετιστές δεν το εφαρμόζουν ακόμη -...ρωτήστε ένα παιδάκι που κάνει ποδήλατο...οι αδερφοί Wright το είχαν ψάξει από τους πρώτους:
Wilbur Wright explained countersteering this way:
"I have asked dozens of bicycle riders how they turn to the left. I have never found a single person who stated all the facts correctly when first asked. They almost invariably said that to turn to the left, they turned the handlebar to the left and as a result made a turn to the left. But on further questioning them, some would agree that they first turned the handlebar a little to the right, and then as the machine inclined to the left, they turned the handlebar to the left and as a result made the circle, inclining inward.[33][34]"
http://en.wikipedia.org/wiki/Countersteering
...According to the Hurt Report, most motorcycle riders in the United States would over-brake and skid the rear wheel and under-brake the front when trying hard to avoid a collision. The ability to countersteer and swerve was essentially absent with many motorcycle operators.[21] The often small amount of initial countersteering input required to get the bike to lean, which may be as little as 0.125 seconds, keeps many riders unaware of the concept....
Y
Yiannis_B
Έχω 1 cd του code με ελληνικούς υπότιτλους.
Αν ενδιαφέρει κάμποσους να το ανέβαζα κάπου...
Ναι! :drinks:
Σε μια χώρα με μιάμιση πίστα, και ανύπαρκτη παιδεία οδικής ασφάλειας, ό,τι ανεβάζουμε, και μπορεί να μας κάνει καλύτερους-και άρα και ασφαλέστερους οδηγούς, είναι πάντα πάνω από τα κλόπυ-ράιτ του συστήματος. Άλλωστε, αν σου ανοίξει η όρεξη, τελικά θα τα αγοράσεις τα βιβλία, η σειρά είναι μια πρώτης τάξεως reference, για κάθε μοτοσυκλετιστή.
Andreas79
