Kii Audio
m1ts0s
News poster
Combine Bruno Putzeys, Bart van der Laan, Wim Weijers, Chris Reichhardt and Thomas Jansen and arrive at new company Kii Audio. Their first project is the kii three active loudspeaker. "We offer linear frequency response, a perfect impulse response plus phase coherence and pack 1'500 watts per speaker divided across six drivers into a compact and lightweight enclosure. Bruno Putzeys invented the Active Wave Focusing™ technology to control dispersion and direct the sound pressure where we need it to be: in the sweet spot! Intelligent DSP processing provides the kii three with a cardioid dispersion pattern down to the low-mid and bass frequencies, which otherwise can only be achieved by very wide baffles, big cabinets or soffit mounting speakers (infinite baffle design). The controlled sound dispersion is the only reason why a big main monitor system in a good room offers the special feel and impact it does."
The kii three uses 4 x 6.5" woofers, a 5" midrange and a 1" wave-guided tweeter each driven by a custom 250-watt nCore amp. Response is given as 20Hz - 25kHz ±0.5dB and long-term SPL as 105dB (115dB peak). All this comes packaged in a 20x40x40cm enclosure of 15kg. Inputs are analog, AES/EBU and WISA.
The Secret of Big Speakers
Kii’s mission for the THREE was to break the sonic mould of compact speakers. Powerful small speakers with deep bass have been around for a while now but none so far sounded like a big speaker. The THREE is built to fix that.
Basic acoustics tells us that a classic box speaker only directs sound towards the listeners from the midrange up while bass frequencies are radiated all around. The frequency where this change happens depends on the size of the box front (the “baffle”). The smaller the baffle, the higher the frequency at which bass is still radiated all around instead of directed towards the listener.
That in short is why big speakers have so far delivered much more precise timing and detail in the bass and low mids than small speakers: the room gets less chance to interfere. And that is what Kii has now managed to make a compact speaker do.
Category Killer
The THREE is the first compact speaker that can better the clarity of a full size sound system in a large room while its small size means it’s equally at home in much more modest spaces. In fact, it is particularly small rooms that will benefit most from the THREE’s controlled bass. Better than big speakers at sounding big and better adapted for small rooms than other small speakers, THREE is a truly no-compromise product.
Common speaker Active Wave Focusing™ speaker
The Active Wave Focusing™ Solution
A loop hole in acoustics says that small directive speakers are possible - if you have enough drivers and you feed them the exact right signal. The THREE has a total of 6 ways, front, side and rear, working together to throw the sound in one direction only without relying on a baffle. The THREE’s ability to direct bass is comparable to, but much better controlled than that of a traditional speaker several meters wide.
What do Active Wave Focusing™ filters do?
Active Wave Focusing™ filters mark a complete departure from the classical crossover filter. Instead of just splitting the spectrum into bands it forces the specially positioned drive units to create a completely coherent wave front that is only emitted forward and behaves as though all of it came from the midrange driver.
With classical crossover filters, loudspeakers can only have a time aligned impulse response on the main axis. The animations on the left show the wave front as it’s built up by a typical modern three-way speaker with side-firing woofers. This example is crossed over at 250Hz, time aligned and phase equalised. Indeed the wave travelling towards the listener is coherent. Towards the sides and the rear the picture breaks down and the impulse is completely smeared. Also, low frequencies get emitted in all directions. In a real room (bottom animation) the sound that escapes toward the back will strike the wall behind the speaker and reflect towards the listener, who actually hears the speaker twice: once from the front and a bit later from the rear. Moving the speaker out into the room doesn't help. The overall bass balance looks better but the impulse response gets worse as the reflection now comes even later.
The animations on the right show how the Active Wave Focusing™ method retains full time alignment all around the speaker and how the presence of the rear wall has no impact. Sonically the effect is a very even, unusually detailed bass. Even in problematic rooms a drum kick has that visceral thud that previously only very big or in-wall speakers could achieve.
http://kiiaudio.com/
Akis_G
Πες μου οτι εχουν 3 χιλιαρικα το ζευγος να αρχισω να πουλαω το συστημα!
dapost
Rehdeko & Harbeth lover
Άλλο ένα καινοτόμο προϊόν που σχετίζεται με τον συνήθη ύποπτο. Controlled directivity από τα 80Hz!!! Και σε ένα τόσο μικρό πακέτο! Αυτό μπορεί να δώσει καλό μπάσο ακόμη και στο δωμάτιό μου! Και με όλα τα καλούδια που μας έχει συνηθίσει ο Β.: perfect impulse response, FR, κλπ.
Εκτιμώ ότι θα έχουν σίγουρα αρκετά πάνω από 3000€ αλλά κάτι μου λέει ότι θα στοχεύσουν μεγαλύτερη αγορά από ότι π.χ. με τα Grimm LS1 και επομένως θα κρατήσουν πιο χαμηλά το κόστος. Πάντως και μόνο τα 1500watt
ncore / channel έχουν το κόστος τους, όσο νά 'ναι. Αρχίζω να μαζεύω...
Akis_G
".....thanks for your email.
The Kii THREE pair will have an ex VAT retail price of 8.395,00 EUR ex works.
In case you are coming to High End Munich next week we would like to invite you to our launch party.
http://www.kiiaudio.com/exp-events.html
Hope to see you there"
E άμα πας στο launch party ρε μάστορα, πες του μπάρμπα Β, να βγάλει και μια έκδοση made in China για τους κακομοίρηδες εδώ στας νότιας Ευρώπας. Σε κόκκινο αν γίνεται...
(Μα χρειάζονταν 6x250W? Κανε και λίγο οικονομία)
Εάν πραγματοποιούν στο ακέραιο όσα υπόσχονται,τότε θα ενταχθούν σε κατηγορία οπλοσυστημάτων αντί... οικοσυστημάτων.:D
Όπως διαπιστώνεται,υπάρχει ήδη αντιπρόσωπος στην Ελβετία....Δε μένει παρά να ενεργοποιηθεί κι ένα ομαδικό lobbying στη γνωστή Athens Pro....
εμεις δλδ που πειστικαμε για ενεργα ηχεια πλεον (απο δω και περα), ενα πακετακι που ετοιμαζουμε 3δρομα + dirac + dac + pc, με κοστος μικροτερο απο τα 8Κ που ζηταει το Κii, παλι θα ειμαστε "πισω" ηχητικα?
δλδ η διαταξη των μεγαφωνων του Kii ειναι που κανει τελικα τη διαφορα?
μετριαζει τις επιπτωσεις του χωρου ταυτοχρονα με τη δουλεια που κανει ενα εργαλειο πχ σαν το dirac?
δλδ το παραπανω ταπεινο πακετο που προσπαθουμε να σαξουμε δεν θα ευεργετηθει τοσο απο την ενσωματωση του dirac και μονο?
βλεπω επισης οτι μαλλον το dirac και προγραμματα του ειδους, τελικα δεν αποτελουν πανακεια...πχ ο dapost που επαιζε-παιζει με dirac, ακομα ψαχνεται...
τελικα υπαρχει σημειο που σταματαει η αναζητηση?
dapost
Όπως σωστά έχει πει ο Εαρ, η σωστή σειρά είναι πρώτα η ακουστική δωματίου, μετά ένα σωστό ηχοσύστημα και τέλος το room correction. Χρειάζονται και τα τρία για οποιοδήποτε ηχοσύστημα / ηχείο. Αυτά είναι facts.
Αυτό που είναι λίγο facts και λίγο υποκειμενική δική μου εκτίμηση είναι ότι πολύ καλές χαμηλές συχνότητες είναι πολύ δύσκολο να έχεις με τυπικά ηχεία - κουτιά που εκπέμπουν μονόπολα. Καταρχήν τα κουτιά αποθηκεύουν ενέργεια στις χαμηλές που την ακτινοβολούν με κάποια καθυστέρηση, με αποτέλεσμα smearing στα μπάσα. Μονόπολη εκπομπή από την άλλη σημαίνει ψιλο-ανεξέλεγκτη αλληλεπίδραση με το χώρο. Πολύ κοντά στους τοίχους: κουδουνίζουν οι τοίχοι, μακρυά από τοίχους: έχεις ακυρώσεις SBIR και ανακλάσεις.
Το κιι έχει καρδιοειδή εκπομπή, λέει, σε κάποιο εύρος χαμηλών, κάτι που είναι πολύ καλό γιατί μειώνεις την αλληλεπίδραση με τις επιφάνειες που βρίσκονται πίσω από το ηχείο. Παρόλα αυτά, εξακολουθούν να είναι κουτιά :-(
Προσωπικά θέλω να δοκιμάσω ένα damped υ-frame sub που συνδυάζει καρδιοειδή εκπομπή και απουσία κουτιού. Ελπίζω ότι αυτό, σε συνδυασμό με ισοστάθμιση, θα παίξει καλά. Μία άλλη πολύ καλή λύση IMHO είναι τα soffit ηχεία που εξουδετερώνουν την πίσω ακτινοβολία και επίσης μειώνεται και η επίδραση της κουτίλας (δεν ακούγεται πολύ). IMHO, από τα soffit ηχεία που έχει το athens mastering έχω ακούσει το καλύτερο μπάσο ever, αν σημαίνει κάτι αυτό βέβαια.
dapost
Κάτι ακόμη για το dirac: Είναι σαφώς πολύ καλό, τελείως διάφανο και προσωπικά δεν ακούω χωρίς αυτό. Όμως στα μπάσα (στη minimum phase περιοχή του δωματίου) είναι μικρά τα οφέλη: Θα σου μειώσει τις κορυφές αλλά δε θα σου γεμίσει με "πειστικό" τρόπο τον ήχο στις κοιλάδες. Με άλλα λόγια, θα σου μειώσει το "μπουμάρισμα", αλλά δε θα σου δώσει impact. Από minimum phase περιοχή και πάνω, είναι πολύ καλό αρκεί να κάθεσαι σε συγκεκριμένες θέσεις ακρόασης.
μαλιστα...
και το θεμα ειναι οτι και ακουστικη φροντιδα να βαλεις (μπασοπαγιδες στις γωνιες κλπ), μαλλον οριακα εισαι και παλι...
ασε που θελουμε το δωματιο να δειχνει δωματιο και οχι στουντιο
dapost
Τι να σου πω, εγώ έτσι πιστεύω. Από την άλλη υπάρχει και το δωμάτιο του Μ. Αλλά ο Μ έχει μία απόληξη...ΝΑ...μετά συγχωρήσεως.
οκ...
κανονιστε λοιπον να παρει καποιος τα Κii να δουμε :D:D
λενε οτι θα πεσει το ΦΠΑ...
μην κανετε power-buy ακομα...:D:D
dapost
Ερώτησις: Για να επιτευχθεί καρδιοειδής πολική απόκριση με τη συγκεκριμενη διάταξη μεγαφώνων, πρέπει τα οπίσθια μεγάφωνα που ακτινοβολούν σε αντίθετη φάση από τα μπροστινά και να βρίσκονται σε κάποια απόσταση από τα τελευταία, σωστά; (Και να εφαρμοστεί και κάποια καθυστέρηση.) Το kii όμως είναι ένα πολύ μικρό ηχείο, αρκούν τα 40εκ max απόστασης για να επιτευχθεί η καρδιοειδής απόκριση; Αυτός είναι ο λόγος που είναι καρδιοειδή από τα 80Hz και όχι πιο χαμηλά;
Σωστά αυτή είναι η λογική.
http://www.aes.org/e-lib/browse.cfm?elib=12401
εχω τις ενστασεις μου οσο αναφορα τη σειρα των πρωτων δυο θεσεων, δε μπορεις να φτιαξεις κατι αν δεν ξερεις τι θα βαλεις μεσα
και αυτο επειδη ακριβως ο τροπος ακτινοβολιας τους ποικιλει αναλογως της σχεδιασης.(πλυν καποιων σταθερων που μενουν αναλοιωτες).
στην ερωτηση σου, αν εχω καταλαβει σωστα δεν καταλαβες σωστα:D
πισω και πλαι ειναι τα γουφερ ελεγχομενα 80 -250hz,
μπροστα και μονοπολα ειναι μονο τα μιντ-τουιτερ...
  • loggeo
antikotsos
