SQUARE ROOT
m1ts0s
News poster
SQUARE ROOT are professional reference-grade loudspeakers that are linear both in frequency and time domain, created to experience the most natural and undistorted sound reproduction in near-field listening environment. Perfect experience for a true musician!
Every artist should try to use non-distorting loudspeakers to have an evidence-based possibility to evaluate performance quality and behavior of any music instrument as well as recording and sound processing gear. Without a truly neutral and non-coloring speaker system music creation can become extremely complicated.
The first loudspeaker system launched earlier this year by Square Audio is called SQUARE ONE. These are unconventional mid-to-near field studio monitors with innovative approach to enclosure design featuring the very best components that industry provides today. SQUARE ONE acoustic system is unique, with ultra-high performance standard but not everyone can afford them. Therefore SQUARE ROOT speakers were created.
The key advantages of SQUARE ROOT:
• Single full-range driver - a true point source
• No distortions introduced by crossover of two (multiple) drivers
• No delays caused by driver alignment
• Driver has soft suspension and long excursion - avoids compression and loss of detail in low frequency range
• No timbral distortions created by difference in drivers' materials
• Smart and powerful digital filtering to remove slightest non-linearities of speakers performance both in frequency and time domains
Technical specifications:
• Full range, near-field, bass reflex system
• Frequency response: 40Hz-22kHz (+/-2.5dB)
• Phase response: +/-10 degrees (250Hz-20kHz)
• 103dB max SPL
• Class D amplification
• DSP filtering
• Dimensions: D 10'' (25cm), W 8'' (21cm), H 14'' (35cm)
• Weight: 18.7lbs (8.5kg), each speaker
SQUARE ROOT is launched and available for pre-ordering on Kickstarter on May 26 to raise funds for manufacturing of the first batch. During the campaign that will last for 24 days until June 19, SQUARE ROOT will be available at several price points and with optional finishes. Standard pitch black and dream white version limited to 25 pairs for early backers will be offered at $690. SQUARE ROOT special editions with the optional mahogany, cherry and oak finishes will be available for $990$. SQUARE ROOT products will be shipped worldwide.
Will cost $1490 in retail.
https://www.kickstarter.com/projects/1201749352/square-root-the-ultimate-speaker-for-a-true-musici
http://www.square.audio/en/squareroot
Το προηγούμενο ηχείο τής εταιρίας: http://www.avsite.gr/forum/threads/square-audio-square-one.143351/
m1ts0s
News poster
Μονάδες Mark Audio, μάλλον το alpair 7.
"The one we are using is 3 generation Alpair 10M. For SQUARE ROOT we will have slightly modified for our powerhandlig requirements. As well we are considering to offer both metal alloy option and paper cone option. At the moment we can handle metal alloy model better."
m1ts0s
News poster
"Last couple of KICKSTARTER weeks were totaly exciting for us. We had great support from you all and we have not expected everything to be this awesome. Thank you for that!
From the very beginning we knew that launching campaign for a specific and sophisticated prosumer SQUARE ROOT wil be not an easy task. But at the same time we see that many people believe our story and are excited about SQUARE ROOT.
Now we see that there is a minimal chance in reaching our goal but regardless we have decided to make SQUARE ROOT real and to keep our promises to you guys anyway!
After the end of this campaign SQUARE ROOT will be available for preordering at Square Audio and even more, those who have backed and will back SQUARE ROOT here in Kickstarter until campaign ends will have opportunity to receive respective reward for the same price."
TGD
Thread Gravedigger
Γιατί δεν έφεραν τα μεγάφωνα "πρόσωπο" με την μπάφλα;
Katerinanota
