Το σινεμά του "Ρόδου"
αν το 7.1 ειναι ψηλα οπως συμβαινει στις περισσοτερες των περιπτωσεων το atmos δεν εχει το αναμενομενο αποτελεσμα......
Αφήστε, το βρήκα από εδώ: http://www.dolby.com/in/en/guide/dolby-atmos-speaker-setup/7-1-4-setups.html
http://www.dolby.com/in/en/technolo...tmos-home-theater-installation-guidelines.pdf
As in the past, the placement of all listener-level speakers should follow these recommendations, which are based on ITU-R BS.775-3:
• The speakers located in the front of the room shall be used as a reference point. All speakers in the listener plane should ideally be equidistant from the listener position. If this is not possible, compensating for distance may be used to time align the arrival of audio from each speaker to the listener.
All listener speakers should be at the same height, typically 3.9 feet (1.2 meters), which is ear level for the average seated listener (as defined in ITU-R BS.1116-1).
If possible, the height of the rear speakers should be the same as the height of the front speakers. If the room design makes this impractical, or impossible, the rear speakers may be higher than the front speakers. However, we suggest that the height of the rear speakers not be more than 1.25 times the height of the front speakers.
Overhead Speakers
Overhead sound is a vital part of the Dolby Atmos experience. There are a variety of options for adding this capability to a room.
One solution is to install speakers overhead. Most high-power, full-frequency conventional overhead speakers with wide dispersion characteristics will work in a Dolby Atmos home theater.
stathis
Ultra Home Theater
Ψηλά μεν 7.1 ,αλλά η κλίση των ηχείων είναι προς την θέση θέασης;
Προφανως εχει να κανει με την χρονικη ευθυγραμιση και να μην δυσκολευουμε το εργο της ψηφιακης ισοσταθμισης...
Καλά τα λέω, presence. Αν πρέπει να βάλεις τα LCR στο 1,20 θα εμποδίζουν λίγο. :D
Εμ ,αυτό; Τι νομίζατε, πως όπως πετάγατε τα ηχεία στην τύχη θα δουλέψει σωστά και το Atmos;
το προβλημα ειναι τα 4 περιφερειακα...sr-srb
αυτα πρεπει να πανε κοντα στο 1.2μ
αν μπορει να το κανει ειναι οκ για 4 atmos ....αν δεν μπορει να βαλει 2 απο πανω στην θεση ακροασης και οπως λεει η dolby
η να παρει του Δημητρη τον 5000 και να παιξει 9.1 η 11.1
....και να βαλει η mitsy atmos :D
Θα κατέβουν εκεί κοντά στo 1.20.
η να παρει του Δημητρη τον 5000 και να παιξει 11.1
Τι να το κάνει το atmos η καψερή χωρίς προβολέα; :roflmao:
Κοίτα και τις αγγελίες βρε! :)
  • Like
Reactions: PPG
melina
Cargo 200
Ροζυ πολυ καλή επιλογή τελικά ο 5100, και το atmos ειναι το καταλληλο setup για το χωρο σου και για καθε σινεφιλ που σεβεται τον εαυτο του και θελει να απολαμβάνει σωστα κινηματογράφο στο σπιτι του.
Αγιο ειχες τελικα που δεν έμπλεξες με την μπουρουχα το 5000.
δυστυχως ολα τα συστηματα πασχουν στο κεντρο .....
η βαζεις πισω απο οθονη ηχεια η πας σε συστημα οπως εχει η yamaha με τα μπροστινα να ανεβαζουν τους διαλογους ......μιας και νομιζεις οτι ολοι μιλανε απο σκαμνι.....κατι μου θυμιζει αυτο :roflmao:
SimosPan
