Cambridge Audio NP30
Πωλειται σε αριστη κατασταση και παροπλισμενο.
http://www.whathifi.com/cambridge-audio/np30/review
http://www.techradar.com/reviews/au...ems/cambridge-audio-sonata-np30-974900/review
Tιμη 250€
Χαρακτηριστικά:
  • DAC Wolfson WM8728 24-bit/96kHz capable
  • THD+N 0.003% 1kHz
  • Frequency Response: 20Hz-20kHz +/- 0.2dB
  • Signal to Noise Ratio: > 95dB
  • Total correlated jitter: <200pS
  • Digital Outputs: S/PDIF Co-axial and TOSLink Optical
  • 16-24 Bits, 22.05-96kHz
  • Audio Formats WAV containing uncompressed PCM 16-24 bit 32-96kHz
  • FLAC containing losslessly compressed PCM 16-24 bit 32-96kHz
  • Apple Lossless (ALAC) 16-24 bit 12/16/22.05/24/32/44.1/48/96kHz
  • AIFF containing uncompressed PCM 16-24 bit 32-96kHz
  • Microsoft® Windows MediaTM Audio (WMA 9 Standard) 32-320kbps
  • MP3 (CBR or VBR) 16-320kbps, AAC, HE AAC and AAC+ (CBR or VBR) 16-320kbps Ogg Vorbis 32-320kbps
  • (88.2kHz sampling frequency not supported)
  • Streaming Protocols RTSP (Real Time Streaming Protocol)
  • MMS (Microsoft Media Server Protocol)
  • HTTP (Hyper Text Transfer Protocol)
  • Wi-Fi IEEE 802.11 b / g or n (Ethernet connection required for 24-bit files)
  • Wi-Fi Encryption WEP, WPA, WPA2
  • Ethernet IEEE 802.3,10 Base-T or 100 Base-T
  • USB 2 x USB 1.1 current limited to 500mA each
  • File systems FAT32
  • Trigger In 12V DC
  • Mains inlet voltage 120-240 VAC (switch mode)
  • Standby consumption <1W
  • Max power consumption 21W
  • Dimensions (H x W x D): 67 x 270 x 285mm (2.6 x 10.6 x 11.2")
  • Weight 2.1kg (4.6lbs).
Tιμη 250€
Χαρακτηριστικά:
  • THD+N 0.003% 1kHz
  • Trigger In 12V DC
Υπάρχει ο ONKYO ARV 401 μαύρος με τηλεχειριστήριο (2×80watt).
Τον δίνω 120 και η διαφορά μετρητά δικά μου,
akalavo
