Integra DRX-R1 AV Receiver and DRC-R1 Preamp-Processor
  • MSRP: $3,200 (DRX-R1) and $2,500 (DRC-R1)
Integra is also stepping up support for the present and future of hi-resolution and streaming audio. Top on that list is support for MQA (Master Quality Authenticated) decoding.
Speaking of streaming, the Integra is Apple AirPlay compliant It also supports today’s major streaming services such as TuneIn Radio, Pandora, and Spotify. Research Series models will also include Tidal and Google Cast for audio. MQA, Tidal, and Google Cast for audio support will be forthcoming as a future firmware update on the announced models.
App Control
The Integra Remote app for iPod touch®/iPhone,® Android, and Kindle devices is a convenient way to control your home entertainment from anywhere within wireless range. The app has a clear graphical interface to control playback, adjust settings and handle content across multiple zones. The app serves hi-res, lossless, and compressed audio files (including 192 kHz/24-bit FLAC, DSD, and Dolby® TrueHD) to the DRX-R1 from your mobile devices, and gives it stunning sound.
384 kHz/32-bit Hi-Grade DAC
No matter what you're listening to, it will sound powerfully full, clean and clear. A premium-quality AK4458 digital-to-analog converter from Asahi Kasei implements unique low-distortion filtering technologies for clear sound, and unlocks the full potential of any audio format, including compressed, lossless, and hi-res audio (MQA, MP3, WMA, WMA Lossless, FLAC, WAV, AAC, Apple Lossless, AIFF, DSD 11.2 MHz, and Dolby TrueHD).
Λινκς:
http://www.integrahometheater.com/Products/model.php?m=DRX-R1&class=Receiver&source=prodClass
http://www.audioholics.com/av-receiver-reviews/integra-drc-r1-preamp-drx-r1-receiver
Νομίζω πως ο προ αυτός είναι ο νέος βασιλιάς στο είδος, στην τιμή του γιαμαχα, αλλά καλύτερος και πιο πλήρης από ότι κυκλοφορεί, όχι μόνο από τον γιαμαχα. Τα κάνει όλα.
Η διαφορά τιμής με τον ολοκληρωμένο, που είναι μόλις 700 αμερικαν νταλαρς για ένα τσούρμο κανάλια, δείχνει πως τα τελικά στάδια είναι κατάλληλα μόνο για ατμος, και άν. Καλύτερα κανα ενεργό, έχει XLR.. ;)
Το επόμενο βήμα σε ποιότητα, είναι επιπέδου τρινοβ ή αντίστοιχων μηχανών, με εξόδους AES EBU και τιμή στα 20κ, όπου βέβαια βάζεις δικής σου επιλογής ντακ, ή ηχεία με ψηφιακή είσοδο στην πλάτη (βλέπε κιι), και ο νοων νοειτω.
O Yamaha είναι στα 2.500€ στον σκρούτζ, αλλά κοντά στα 2.200 στην πραγματικότητα. Είναι μεγάλη η διαφορά τιμής.
Δεν ειναι κατανοητή η μικρη διαφορά του ολοκληρωμένου απο τον προ- 250€- οταν στις ΗΠΑ οι διαφορά ειναι 700$.
Ειχα ρωτησει εγω πριν παρω τους anthem και ειναι φθηνοτεροι
Βεβαια τοτε πριν κανα μηνα δηλαδη ο αντιπροσωπος με ειχε ενημερωσει για τις νεες αφιξεις αλλα οχι για τις ακριβης τιμες
Εχουν την φημη μηχανηματων αλεξισφαιρων
Βαγγέλης Λάμπρου
Να επισημάνω εδώ περί του "Αλεξίσφαιρου" οτι η εγγυήση που δίνει ο οίκος είναι 3 ετών με ΑΝΤΙΚΑΤΑΣΤΑΣΗ και μάλιστα advanced replacement.
Πρώτα λαμβάνεις το νέο μηχανημα και ΜΕΤΑ παίρνουμε πίσω το παλιό.
Οσο για το τι κάνουν και πως παίζουν οι Integra...
Με χαρά να σας δειξουμε απο κοντά εφόσον επιθυμείτε.
Βαγγέλη μου, άσε το τι κάνουν, και πιάσε το πόσο κάνουν, διότι βλέπω μία αναντιστοιχία:
$3,200 (DRX-R1)
$2,500 (DRC-R1)
DRX-R1: 3.450€
DRC-R1: 3.200€
Ε, δεν πολυκάθεται καλά στο μάτι η διαφορά 700 σε νταλαρς και 250 σε γιουρος.
Αναλογικά, εφόσον ο X βγαίνει 3.450€, ο C θα όφειλε να είναι κοντά στα 2.700€. Μήπως έχει γίνει κάποιο λάθος; ;)
Διότι από 2.700 έως 3.200 είναι ένα πεντακοσάρικο που αλλάζει τα δεδομένα.. ;)
Τιμολογιακα, όχι. Παραμένει ο γιαμαχα ;)
Αν χτυπούσε τον γιαμαχα στην ίδια κατηγορία τιμής, όπως υπέθεσα βλέποντας τα 2.500 νταλαρς, τότε και μόνο τότε θα ήταν ο νέος χαλίφης στη θέση του χαλίφη ;)
οποτε ο ονκυο εινσι καλυτερος στα σπεκς σε σχέση με τον ονκυο ...
με τον Ανθεμ ;;;
για τον ονκυο λέω ...
Jiovani75
