Barefoot/Shinola Bookshelf Speakers
m1ts0s
News poster
FEATURES
  • Active 2-Way Speakers
  • Hand Finished Oak Composite Cabinet
  • 300W Peak Power Total
  • 6.5” Woofer and 1″ Tweeter
  • 48Hz – 22kHz +-3dB Frequency Response
  • Bluetoooth® Enabled
  • Built at Barefoot in Portland, OR
TECH SPECS
ENCLOSURE:
Hand finished, uniform density, Oak composite cabinet
POWER OUTPUT: 300W peak power total (100W RMS per channel)
INPUTS: 3.5mm Stereo Jack, RCA L/R, S/PDIF, USB Type-C, Bluetooth®
OUTPUTS: S/PDIF
INPUT VOLTAGES: 100/240V, 50/60Hz (requires fuse change)linear excursion
TWEETER TYPE: Soft Dome Tweeter
WOOFER COMPOSITION: Custom high-excursion surround, 33oz ferrite magnet, metal cast basket
WOOFER SIZE: 6.5”
IMPEDANCE:
FREQUENCY RESPONSE ACOUSTICALLY: 48Hz – 22kHz +-3dB
ANALOG INPUT IMPEDANCE: 10kΩ
INPUT SENSITIVITY: 2Vrms input
AMPLIFIER TYPE: High Efficiency Class D
SPEAKER DIMENSIONS: Active & Passive: 8″ x 9″ x 12″
ACTIVE SPEAKER WEIGHT: 7.9 kgs
PASSIVE SPEAKER WEIGHT: 7.41 kgs
$1,500
http://barefootsound.com/bookshelf-speaker/
https://www.shinola.com/audio/all/speakers/book-shelf-speakers-2-black.html
Θάνος Γαλάνης
