Dragonfire Acoustics Mini Dragons
m1ts0s
News poster
Dragonfire Mini Dragon Satellites
You won’t have to turn them up loud for full-range, full-impact sound; they’ll do that at any SPL level with spectacular sound and imaging. How so? Conventional dynamic-driver speakers diffract soundwaves off speaker cabinets and nearby surfaces. The soundwaves bounce back and crash into each other causing interfering peaks and nulls.
Soundwaves from a planar magnetic source coherently propagate along the axis of the originating plane – like a laser beam – interfering far less with surrounding surfaces for much less distortion. Results are more dynamic lifelike sound with spectacular imaging and soundstaging.
The Mini Dragons’ planar driver is ultra-efficient and requires only few watts to generate normal listening levels. As a purely resistive load, the DFA Mini Dragons can be driven by a wide variety of high-end audio amplifiers. For best performance Dragonfire recommends the DFA MD-4 amplifier with built-in DAC/DSP/Crossover.
Dragonfire MD-4 Amplifier
Built into a matching anodized aluminum enclosure, the DFA MD-4 is a beautifully built class-D DAC/AMP/DSP engine featuring high-quality A/D conversion for its balanced analog XLRs, SPDIF and USB digital inputs. There’s advanced DSP for speaker correction with a total of 120 parametric filters, crossovers, delays and compression limiting circuits too. The powerful MD-4 offers an amazing full-power spectrum of 1-to-100kHz, taking advantage of its great efficiency for vivid and exciting sound at any volume.
Free of high-frequency damping networks, the MD-4 delivers full power up to 100kHz while the extremely high-voltage-rail-to-RMS-power-rating-ratio for up to 250W RMS per channel at over 93% efficiency ensures minimal cooling requirements and maximum long-term reliability.
Dragonfire SB-8P Subwoofer
The SB-8P Subwoofer seamlessly matches the Mini Dragons with tuning down to 30Hz. The bottom end is essential in setting up the size of the recording venue or one that’s mixed in. The SB-8P is self-powered with 180W on tap, cutting off at 200Hz to blend in perfectly with the Mini Dragons. The SB-8P features a long-excursion, high-speed, low-distortion woofer plus a custom long-excursion 8" passive radiator and is part of the full system price.
Dirac Room Correction System
Many people don’t realize they’re listening to their speakers and their interaction with the room. While absorptive and refractive acoustic panels are typical these days to tame splashy acoustics, Dirac's Live Room Correction Suite (LRCS) includes digital room correction so the Mini Dragons sound even better. Dirac measures the room and speakers, establishes target curves, and calculates correcting digital filters. The Dirac is supplied with the premium Dragonfire system with calibrated microphone.
The result is seriously more impact, lifelike and focused imaging, with a detailed and airy soundstage that escape the boundaries of the speakers. It’s music you can feel.
Mini Dragon Satellites MSRP $4,998
Dragonfire MD-4 Amplifier MSRP $2,998
SB-8P Subwoofer MSRP $498
https://www.dragonfireacoustics.com/
papaevagelouv
