JBL One Series 104
m1ts0s
News poster
With JBL 104 Reference Monitors, you’ll hear true clarity and detail, with no coloration. The 104s deliver crisp highs and rich bass just as intended.
They’re optimized for desktop placement, with neutral low-frequency performance. And their smooth off-axis response means you can monitor with confidence in a wide sweet spot.
The world’s top recording studios and touring artists rely on JBL Professional monitors to deliver unparalleled fidelity and performance. Now, we’ve optimized that technology in our smallest form factor ever. The 104 Reference Monitor’s innovative new coaxial driver design features a high-frequency driver aligned with a precisely contoured woofer cone to deliver accurate response, exceptional detail and impressive off-axis performance, for the most neutral, accurate presentation, desktop to desktop, room to room. The cabinet’s precisely contoured low-frequency port works with the driver to provide accurate bass at all listening levels. And with low frequency extension down to 60 Hz, you’ll be impressed with the bass you get, even without a subwoofer.
JBL 104 Reference monitors offer this high level of performance, even at loud playback levels. This is accomplished through clean, integrated 60-watt Class D amplification that distributes 30 watts per speaker.
And with their efficient design, One Series speakers can be driven to 104db SPL (peak), without the distortion found in other monitors in their class.
Full Features
  • Master and extension speaker sold as one set
  • Coaxial 4.5-inch (118 mm) contoured LF driver with integrated.75-inch (19 mm) soft-dome HF driver
  • Contoured low-frequency port
  • Integrated 60-watt Class D power amplifier; 30 watts distributed to each speaker
  • Acoustically optimized for desktop placement
  • Three sets of inputs allow connection with professional equipment, personal music players and consumer-level devices
  • Master monitor includes electronics for the extension monitor, minimizing wiring and clutter
  • Front-panel volume control
  • Front-panel headphone jack with speaker mute feature
  • Integrated power supply
http://www.jblpro.com/www/products/recording-broadcast/one-series
[/QUOTE]
To crisp highs πως μεταφράζεται; Τραγανά υψηλά; Ούτε πατατάκια να ήταν :)
Το rich bass το κατάλαβα.
Δεν πωλούνται χωριστά μάλλον, άρα 149 τα δύο;
(Το ένα μόνο έχει ενισχυτή)
Δίκιο έχεις,με μπερδεψε το quantity 1 που γράφει στο σαιτ.Αρα 150 ευρώ.
deleted user 10898
the most accurate sonic presentation of any monitors in their class
In their class.
In their class.
Κατανοητό?
Ρεσπεκτ ξανά στην μεγάλη jbl.
Τελος στο θέμα ηχεία για υπολογιστή. (In their class που λέγαμε...)
Που προ παραγγέλνω Ελλάδα?
Super! Εκει που χαλβαδιαζα τα ανταμ Τ5V, 300 γιουρο το ζευγος, παιρνω αυτα με τα μισα, κοτσαρω και το Benchmark πανω τους και τελος!
Nick Arvanitakis
Audio Pro
Νομίζω πως θέλουν ν αντικαταστήσουν το JBL Control one( 1 , one Pro), που πρωτοεμφανίστηκε το μακρινό 1986 και έκτοτε πούλησε αρκετά εκατομμύρια ζευγάρια.
Προσωπικά περίμενα κάτι παραπάνω, αλλά με την τιμή αυτή, είμαι ok.
venar
