Fluid Audio 2nd Generation FX Series
m1ts0s
News poster
Fluid Audio announces 2nd Generation FX Series Coaxial Studio Monitors
Building upon the success of the FX8 8” Coaxial studio monitor, Fluid Audio now announces the 2nd generation FX80 monitor as well as the addition of the FX50 5” version. Now featuring Class D amplifiers with high and mid frequency adjustment knobs, acoustic space, low frequency roll off and optimized composite cone woofers, the FX series delivers outstanding imaging and off-axis response…in a new, striking industrial design. DSP controlled crossover provides a perfect blending of the woofer to the soft dome tweeter and ensures that there is effectively zero variance amplifier to amplifier.
“Ever since the FX8 was released 4 years ago, mixing engineers have really taken to our version of the coaxial design. In the past, coax designs put the tweeter inside the voice coil space, and used the cone as a waveguide”, says Kevin Zuccaro, the ears behind the Fluid Audio brand and its owner. “Although this makes sense, since the woofer cone is moving (as it produces low frequencies), you get a lot of mid and high frequency smearing and coloration. Our waveguide is stationary, so it does not have the same issues”.
FX50/FX80 Highlights:
• Seamless, transparent response in a compact footprint
• Very symmetrical off-axis response due to the coaxial driver
• 5”/8” composite cone, low-frequency driver
• 1”/1.2” Silk dome tweeter mounted in waveguide
• Bi-amplified 100Watt/140Watt Class D amplification
• Acoustic Space Control lets you calibrate the low frequency to your mixing environment (0,-2 and -4db)
• Tweeter high and mid frequency trim control (+2db, 0, -2db )
• Low frequency roll-off (high pass) switch for optimum integration with subwoofers
• FX50 49Hz – 22kHz frequency response (+/- 3db)
• FX80 35Hz – 22kHz frequency response (+/- 3db)
• Front loaded slot port for directional (and predictable) bass response
“The problem with many studio monitors is that you have to really turn them up to hear the midrange and the vocals the way you need to in order to mix properly. The beauty of our coaxial design is that this is not necessary. With the inherent point-source aspect of the coaxial design, you get better phase alignment between woofer and tweeter…and a more natural sound, even at low volume levels.”—said Kevin Zuccaro.
The FX Series will be available in May with the following street prices:
FX50 ($149.99 USD MSRP / 149€ per unit) FX80 ($249.00 USD MSRP / 249€ per unit)
https://www.fluidaudio.com/
Αν δεν κάνω λάθος ο τύπος, ο Kevin Zuccaro, ήταν σχεδιαστής στην krk και αποχώρησε δημιουργώντας την fluid audio. To 5'' στα 300€ το ζεύγος δείχνει να είναι μία από τις πιο δυνατές προτάσεις στην αγορά για desktop σύστημα, τώρα μάλιστα που μας "τελείωσαν" και τα vfm lsr 305.
Οι τιμές αυτές βέβαια αποδεικνύουν για άλλη μία φορά πόσο φθηνή είναι σήμερα η παραγωγή και η διάθεση τέτοιων προϊόντων στην αγορά και πως μας αρμέγουν τα μεγάλα και καταξιωμένα brands. Αν μπορεί μία βιοτεχνία ουσιαστικά σαν την fluid audio (με outsourcing παραγωγή φυσικά) να πουλάει σε αυτές τις τιμές, μπορούμε μόνο να φανταστούμε τι κονομάει η JBL, η Yamaha και όλοι οι γίγαντες του χώρου.
καλουπάκι με οδηγό 4 βίδες από τον plate amp και βίδωμα της βάσης πάνω εκεί
4 κιλά το ένα είναι...;)
Υ.Γ. Και φυσικά επαναφορά των σνόουμπορντς ΕΠΙΤΕΛΟΥΣ!!:party::roflmao:
Όταν το κουτί με τα 2 δηλώνεται 20 κιλά, είναι απίθανο να ζυγίζουν κάτω απο 8.
Αν είναι τόσα, δεν ψήνομαι να τα στηρίξω με ξυλόβιδες πάνω απ' το κεφάλι μου. :p
sorry....είδα ότι τα πουλάνε ανά ζεύγος και υπέθεσα ότι το κουτί των 9.8kg (στο fx8 που είδα) θα πήγαινε /2
αλλά τελικά αναγράφει ατομική συσκευασία:p
όπως και να χει...
χ3στήκαμε για το βάρος των ηχείων....τα jetski θέλουμε να ξαναδούμε :p:party::laugh::roflmao:
Ήταν
στην M-Audio πριν (As first Program, then Product Manager for M-Audio, I was responsible for the launch of 25 M-Audio branded products from '05 to '11.).
Φαίνεται και μια ομοιότητα:
George195
