Neumann KH 750 DSP Subwoofer
m1ts0s
News poster
Compact DSP-controlled closed cabinet subwoofer
  • Easily installed compact cabinet with a very deep bass response
  • DSP engine optimizes output to achieve reference class sound
  • Neumann.Control App for iPad® to setup, align and operate in a system
DEEP BASS IN A SMALL SPACE
The compact KH 750 DSP is the ideal choice for smaller rooms and smaller studio monitors, such as the KH 80 DSP. It has a unique and flexible 2.0/0.1 Bass Manager allowing the subwoofer to be used in many different system configurations. On the back panel there are analog and digital inputs and outputs, four routing modes and adaptable acoustical controls to allow for seamless system integration. The Neumann.Control software gives access to many additional functions inside the subwoofer. The KH 750 DSP can be used in music, broadcast, and post production studios for tracking, mixing, and mastering.
The newly designed 10” long-throw driver has a large magnet, linear motor design and a very stiff pressed steel basket. As subwoofers are usually placed on the floor, a robust grille protects the driver from accidental damage. The well-braced cabinet is a sealed designed which brings the fastest possible transient response. The two analog XLR inputs are balanced as are the two analog XLR outputs. The 192 kHz / 24-bit digital input can accept AES3 and S/P-DIF signals. There is a bypassable standby function and the switch-off time can be adjusted in Neumann.Control.
CONTROL AND ALIGN YOUR MONITOR SETUP WITH YOUR IPAD®
Via standard IP networking, Neumann.Control gives access to many additional the functions of the KH 750 DSP Subwoofer. Systems of loudspeakers can be defined, from mono to 3D, aligned for a good in-room sound, and then operated centrally: Setup, Align, Operate. At last, you do not have to be an expert to optimally integrate this subwoofer into your system, even in a small room.
The Neumann.Control app for iPad® offers several features allowing you to setup, align and operate the KH 750 DSP and KH 80 DSP even in large setups up to 9 loudspeakers.
The key features are:
Setup:
• 1, 2, 4, 5, 7 and 9 loudspeakers and subwoofers
• Identify loudspeakers and subwoofers on the network that are in the room
• Assign the identified loudspeakers and subwoofers to positions in the room
Align:
• Guided Alignment – a set of simple questions resulting a well-balanced sound. The Guided Alignment is a process where you are asked very simple questions about the room and the loudspeaker/subwoofer position, and then the app adjusts the response of each loudspeaker/subwoofer accordingly.
• Manual Alignment – an 8-band fully parametric equaliser for expert users. In Manual Alignment expert users have complete freedom to adjust an 8-band parametric equalizer, levels and delays in each loudspeaker/subwoofer as they wish. Manual Alignment can also be used to edit Guided Alignments in a more detailed way.
Operate:
• System and alignment selection
• Volume control, preset levels, dim, mute all
• Groups, solos, mutes
• Other system settings such as delay, standby level and logo brightness
https://en-de.neumann.com/kh-750-dsp
Όχι, εντάξει. 256 watt λέει.
Σε αυτήν την τιμή (με τον περιοριστή ισχύος απενεργοποιημένο) σημειώνεται 10% ποσοστό ολικής αρμονικής παραμόρφωσης,ήτοι:
- 20 dB.
Ανώτατες στάθμες στο 1 μέτρο σε συνάρτηση με τη συχνότητα υπό ολική αρμονική παραμόρφωση 10% (κόκκινη γραμμή) , 3% (πράσινη - 30dB) & 1% (μπλε -40dB)
Ακουστικής ανάρτησης σαμπ θα ξεσκίζει σε ταχύτητα και πιστότητα.
Λογικό να μην ανεβάζει στάθμες και να μην παίζει πολύ χαμηλά σε απόκριση.
Σχεδιαστικές γραμμές τους, η πιστη αναπαραγωγή στη στάθμη αναφοράς στη θέση ακρόασης.
Τι λες; Το'χει; ;)
Εφόσον δεν θα χρησιμοποιηθεί μονάχα...ένα τεμάχιο.Στα 4 τεμάχια (μαζί με τους προβλεπόμενους δορυφόρους ΚΗ80) η ανώτατη ωφέλιμη στάθμη στη ζώνη 50-100 Hz θα φτάνει τιμή ΄΄αναφοράς΄΄ 108 dB περίπου υπό ολική αρμονική παραμόρφωση -40dB.
Η δε εφαρμογή προβλέπει μέχρι...9 τεμάχια,ήτοι 123dB.Σε συνεχή μέση στάθμη ακρόασης της τάξης των 90 dB,η αρμονική παραμόρφωση τότε θα βρίσκεται κοντά στα όρια της ακουστότητας με τη καλόβολη δεύτερη αρμονική να επικρατεί έως τα 150 Ηz.
Με τη γραμμική απόκριση της υποβαθύφωνης μονάδας να εκτείνεται μέχρι και τη ζώνη των (χαμηλο)μεσαίων...
Και ομαλή φασική απόκριση μαζί με το δορυφόρο ΚΗ-80
Τι λες; Το'χει; ;)
Μας έχεις πιπιλήσει το μυαλό για 130 dB και ΣΟΥ ΦΑΙΝΟΝΤΑΙ τα ούτε 100 στα 30 Hz ικανοποιητικά;;;;;;>:(:smg:
Ανταγωνιστικό του νέου 10" subwoofer της Adam;
Edit: Όταν ανακοινωθεί η τιμή, ίσως να απαντηθεί το ερώτημα.
Προπαραγγελία πού κάνω;!!!
Ιδανικό ταίρι για τα KH80, που με έχουν ξετρελλάνει με την απόδοσή τους.
- 20 dB......
Αρα μια χαρα το χειμωνα για καυσοξυλα ειναι!
Το κοιτούσα και εγώ αλλά ακριβώς στα ίδια λεφτά νομίζω ότι Dynaudio 18s είναι καλύτερη επιλογή. Εκτός και αν το ματσάρισμα παίζει τόσο ρόλο.
Ιδανικές βάσεις για τα ΚΗ80 θα είναι δυο KH750, και με παραμετροποίηση και έλεγχο μέσω iPad με το δικό τους λογισμικό.
Στην ουσία θα μετατραπούν σε τρίδρομα.
MA 1 - Automatic Monitor Alignment
MA 1
The Beginning of a New Era in Monitoring
  • Calibration algorithms jointly developed with Fraunhofer IIS
  • For stereo setups with KH 80 DSP and all pairs of analog (non DSP-based) Neumann monitors using the KH 750 DSP subwoofer
  • Individually calibrated measurement microphone
  • Room adaptive target curve
  • Phase and amplitude optimization for analog Neumann monitors
  • For Mac and PC
Τιμή: 249 ευρώ
Όποιοι κάτοχοι KH750 ή KH80 θέλουν να μαζευτούμε και να αγοράσουμε συνεταιρικά ένα MA-1 ας μου στείλουν π.μ.
Manosmathiou
