$18.99 - phono stage
Mr Spock
demokratischer - sektor
- δεν συνηθίζω να βάζω τις αναγραφόμενες τιμές στα διάφορα προϊόντα , αλλά εν προκειμένω θα γίνει μία μικρή εξαίρεση λόγω υπερ-οικονομικής περίπτωσης . . .
Pyle Phono Preamp
The PP444 is an MM-only phono preamp built around a Texas Instruments NE5532P op-amp chip. It comes with a DC 12-volt power adapter and has an input sensitivity of 3mV at 50k ohms. A green LED indicates that the extremely small and lightweight unit is plugged in and ready . . .
. . . Breakfast In America (MFSL 1-471). This album is known for having many elements spread across the soundstage, but also for its awful, overhyped cymbal sound especially on “Gone Hollywood.” The Pyle delivered a satisfying sound, without greatly over-emphasizing the cymbals and overall produced a rocking performance . . .
. . . Even though for $19 the Pyle PP444 sounds great, extreme disappointment crept in when I played the Raconteurs’ excellent “Now That You’re Gone”/”Sunday Driver” single (colored vinyl 7”, Third Man Records TMR-586) released by the Third Man Vault in December. An overly soft snare drum sound marred “Now That You’re Gone” and “Sunday Driver” didn’t rock nearly as much as it should have, but those in the market for a $19 phono preamp probably won’t know the difference . . .
https://www.analogplanet.com/content/19-pyle-phono-preamp-anything-crap
  • Converts Phono Signals to Line Level Signals
  • State-of-the-Art Circuitry Accommodates Magnetic Pickups
  • Ultra-Low Noise Operation Improves Sound Performance
  • Connects to Turntables and Other Studio Equipment
  • Input Sensitivity: 3mV at 50K Ohms (Phono)
  • Dedicated RCA and 1/4'' Output Connectors
  • Output: 2V max (P-P) at 10K Ohms
  • DC 12-Volt Power Adapter Included
  • Frequency Response: 20 Hz ~ 20 KHz ±2dB
  • S/N Ratio (A-WTD): 70 dB - Output Level: 2V
  • THD: 0.08% @ 1KHz and 3mV Input | S/N Ratio: 70dB
  • Input Sensitivity/Impedance/Phono 3 mV / 50K Ohms
  • Load Impedance: 10K Ohms - Reference Voltage: 1V d
  • Dimensions (W x H x D): 3.54" x 2.13" x 1.02"
  • Sold as: Unit
  • Weight: 0.85 lbs.
http://www.pyleaudio.com/sku/PP444/Ultra-Compact-Phono-Turntable-Preamp
gid
Όλος ο ελιτισμός και ο σνομπισμός της χαϊεντίλας σε μια πρόταση.
gid
Δηλαδη "αδικηθηκε" το phono των 20 δολλαριων ? :p
Όχι βέβαια, εξάλλου δεν ήταν αυτός ο σκοπός. Ο σκοπός ήταν να συνεχίσουν να αισθάνονται σπουδαίοι οι κάτοχοι των phono των 700 δολλαρίων.
PURETONE
Ένα σκέτο "Π"
Γιατι το λες/λεμε αυτο?
Δεν μπορει καποιος να επιλεξει ενα phono των 200,500,1000 αντι ενα των 20 ευρω απλα και μονον διοτι οντως ειναι καλυτερα και το αντιλαμβανεται και το σηκωνει η τσεπη του? Οσοι εχουν τετοια phono,πικαπ,ψηφιακα κλπ τα παιρνουν για να αισθανονται σπουδαιοι? Η "αντιχαιεντιλα" ειναι η αλλη οψη της "χαιεντιλας" imo βεβαια.......και προς αποφυγη παρεξηγησεων,δεν αναφερομαι ειδικα σε σενα αλλα στην νοοτροπια και τα αστηρικτα σχολια.
gid
Αμφιβάλλεις πως υπάρχουν πολλοί και στις δύο παραπάνω κατηγορίες;
Mr Spock
- το χόμπι μας εξασκούμε και δεν επιδεικνυόμαστε ( το αντίθετο θα έλεγα . . . μοναχικό σπορ κάνουμε όπως πχ το βιβλίο ) . . . οπότε αναλόγως συνθηκών ξοδεύουμε από ελάχιστα έως υπερβολικά . . . λογικά είναι όλα φτάνει να ξέρουμε τι θέλουμε
PURETONE
Ένα σκέτο "Π"
Nαι συμφωνω οτι υπαρχουν τετοιοι και στις δυο κατηγοριες (χαιενταδες και αντιχαιενταδες) γι αυτο προσθεσα και τους αντιχαιενταδες στο σχολιο σου.Με τις γενικοτητες και τα τσουβαλιασματα ειναι που δεν συμφωνω,διοτι στο τελος της ημερας,ενα phono των 700 (το νουμερο που αναφερες) σιγουρα θα ειναι καλυτερο απο ενα των 20 ασχετα με το ποιος και γιατι το αγοραζει.
gid
Δεν με κατάλαβες, περιέργως. Οι δύο κατηγορίες στις οποίες αναφέρθηκα ήταν όσοι όντως καταλαβαίνουν διαφορές και τα σκάνε για τα ακριβά μηχανήματα, και όσοι δεν καταλαβαίνουν διαφορές και τα σκάνε για... άλλους λόγους. Έγραψα "παραπάνω κατηγορίες" παραθέτοντας το δικό σου κείμενο όπου περιέγραφες ακριβώς αυτή τη διάκριση.
Επίσης, πιστεύεις πως ο reviewer που έγραψε το κείμενο έβγαλε τα συμπεράσματά του στα πλαίσια τυφλού Α/Β τεστ;
Καλημέρα λεβέντες. Θα κάνω μια πολύ χαζή ερώτηση και σχωρατε με γιαυτην. Τι κάνει αυτό το πράμα?
Απάντηση παρακαλώ με λέξεις που θα τις καταλάβει ένα παιδί νηπιαγωγείου!
Mr Spock
. . . Οι δύο κατηγορίες στις οποίες αναφέρθηκα ήταν όσοι όντως καταλαβαίνουν διαφορές και τα σκάνε για τα ακριβά μηχανήματα, και όσοι δεν καταλαβαίνουν διαφορές και τα σκάνε για... άλλους λόγους.
- όντως υπάρχουν και οι δύο κατηγορίες . . . τους δεύτερους απλά δεν τους λαμβάνουμε υπ΄όψιν σε ότι αφορά τις κρίσεις τους για τις σχετικές συσκευές , σεβόμαστε όμως τις επιλογές τους ακόμα και εάν τα κίνητρα είναι ιδεοψυχαναγκαστικά . . . έτσι και αλλιώς κάπου αλλού θα τα ''ακουμπούσαν''
- το ποιοι είναι ποιοι , μόνον με προσωπική γνωριμία - ακρόαση - συζήτηση , μπορούμε να το αντιληφθούμε
Παίρνει το σήμα από το πικ απ, το ενισχύει και το στέλνει στον ενισχυτή.
PURETONE
Ένα σκέτο "Π"
Ακριβως αυτο εννοω και γω ;)
Δεν ασχολουμαι με τον ριβιουερ η τον οποιον ριβιουερ.Αυτο που λεω ειναι οτι ενα phono των 700 εινα ΚΑΙ by design ΚΑΙ ακουστικα καλυτερο απο ενα των 20 ευρω.Και δεν χρειαζεσαι blind test να το καταλαβεις οταν ξερεις 5 βασικα πραγματα.Προσωπικα χρησιμοποιω μεταξυ αλλων και ενα phono των 150 δολλαριων,το βρισκω εκπληκτικο για τα χρηματα του αλλα ξερω και τα ορια του.Και ναι, προσωπικα το πετυχαινω 100% σε οποιο τυφλο τεστ εκανα μεχρι τωρα με την βοηθεια φιλων.Και μαλιστα το πετυχαινω στα πρωτα 10 δευτερολεπτα με την μουσικη που επιλεγω να κανω τα τεστ μου.
Βλακείες αντιχαιεντίλας...
Μπορεί το ΝΕ5532 να είναι άριστο για τη χρήση, αλλά με 20€ ούτε τροφοδοτικό για κινητό δε παίρνεις της προκοπής, δεν γίνεται.
Πόσο μάλλον κάποια ποιοτικά υλικά για το κύκλωμα...
Προφανώς βέβαια, είναι απίστευτο το κοστολόγιο, που συμπεριλαμβάνει κουτί, βύσματα, λαμπάκι, τροφοδοσία, πλακέτα, συσκευασία και κέρδος για τον κατασκευαστή...
Εγώ πάντως, για να φτιάξω ένα φόνο (στην περίπτωση που ξεχάσω ότι υπάρχει ψηφιακό) θα χρειάζονταν 20-100€ για κουτί, 20-50€ για βύσματα, 100-250€ για τροφοδοσία και 30-100€ για πλακέτα και υλικά, δηλαδή 170-500€ και μάλλον πιο εύκολο να πάω στα 500 παρά πιο κάτω, και αφού υπάρχει το dact δεν έχει νόημα η ενασχόληση με αυτή τη θεωρητική προσέγγιση κόστους.
Θεωρητική, διότι η ψηφιακή ρία δε παλεύεται.
gid
Σοφέ και ΠΑΝΕΞΥΠΝΕ γιατρέ μου.
Δεν έγραψα ποτέ πως το συγκεκριμένο phono είναι καλό ή κάτι τέτοιο. Το δικό μου είναι το PP2 της NAD και το πλήρωσα 70Ε πριν πολλά χρόνια. Αν αυτό σου λέει κάτι.
Σχολίασα τη συγκεκριμένη πρόταση που παρέθεσα, από το review του τύπου.
Κατάλαβες τώρα, τιτανομέγιστε;
gid
Κάνε ένα κόπο και διάβασε το ποστ #415 εδώ για να δεις πού οδηγεί το παραπάνω σκεπτικό σου.
  • rose.athens
PiterPan
