Harbeth Monitor 40.2 40th Anniversary Edition Loudspeaker
Mr Spock
demokratischer - sektor
...This tonal characteristic is consistent with most so-called audio improvements in our resolution-obsessed age. It typically takes the form of a rising top end for a more etched, articulated, analyzed, and detailed presentation that is almost always slightly to considerably wrong when it comes to the correct reproduction of voices and acoustical instruments. But it must appeal to thousands, if not tens of thousands of listeners because so many contemporary speakers exhibit it, despite the fact that almost no venue where music is actually performed exhibits it. On the contrary, the response in your typical concert or recital hall drops quite precipitously above 4kHz, and sometimes the drop begins as low as half that frequency (see Robert E. Greene’s invaluably informative TAS essay “Records and Reality...
...On casual listening the two editions are so similar they could be different samples off the assembly line. But on critical listening, I noticed three consistent differences: (1) The Anniversary sounds ever so slightly smoother; (2) the tweeter sounds fractionally—and I do mean hair-splittingly—better integrated; (3) the whole presentation sounds slightly purer, akin to what you might hear from a really good electrostatic such as the Sanders Model 10e or my Quad 2805...
Specs
Type: Dynamic three-way vented
Driver complement: 11.81" Harbeth bass unit; 7.87" RADIAL2 mid; 0.98" ferro-cooled soft-dome tweeter
Frequency response: 35Hz–20kHz ±3dB free-space, grille on
Impedance: 6–8 ohms
Sensitivity: 86dB/1W/1m
Amplifier power requirements: 35Wpc minimum
Power handling: 650W program
Dimensions: 17" x 29.5" x 15.27"
Finishes: Silver eucalyptus, walnut, olive wood
Stands: Approx. 17", sufficient to bring tweeter to ear level
Weight: 83 lbs. each
http://www.theabsolutesound.com/articles/harbeth-monitor-402-40th-anniversary-edition-loudspeaker/
https://www.harbeth.co.uk/hifi-speaker/20/Harbeth-Monitor-40.2-loudspeaker
- οτιδήποτε έχω ακούσει από αυτήν την εταιρεία , μου άρεσε . . . παρά τις όποιες αντισυμβατικότητες , πχ οι λεπτές καμπίνες τους που πάλλονται συμμετέχοντας στο τελικό ηχητικό αποτέλεσμα ( κάτι που έχω συνηθίσει να το θεωρώ ως σχεδιαστικό φάουλ ) , όμως το αποτέλεσμα τους δικαιώνει
Εδώ και αν...παρεξηγούμαστε.Ακόμα ένα νήμα για Harbeth με ανέμελο ύφος στο εναρκτήριο κείμενο εν μέσω όλου του άγους...
Οχι αλλο Χαρμπεθ, οχι αλλο Χαρμπεθ...:):):)
(δεν είναι το δικό σου,μη σε μέλλει) :D
Παραπομπή σ'εκείνη την persona που έλεγε ότι δεν πειράζει άμα ειπωθεί κάτι άσχημο για το άτομό του,αρκεί να γράφεται σωστά το...όνομά του.;)
Σε κάποιους δεν παρέχεται ούτε αυτή η μηδαμινή...αβρότητα.
C
chrispo
Κοιτάξτε το anniversary ταμπελάκι, για να καταλάβετε πόσο πονηρός και ύπουλος market player , είναι . :devilish:
A
AKARL
Σα να λέμε δοκίμιο, με κριτικό υπόμνημα, του Στέφανου Χίου στο ΜΑΚΕΛΕΙΟ... :headbang:
14.000 το απλό και 17.850 το Ανιβέρσαρυ!
Όσο λάρτζ και να είναι κανείς αφτά είναι πολλά λ7 για καφσόκσυλα... :headbang::headbang::headbang::headbang:
Να ρωτήσω κάτι?
Οι γρίλιες στα χάρμπεθ συνεχίζουν να αφαιρούνται με τη βοήθεια ενός συνδετήρα ή το έχουν λύσει το θέμα στα επετειακά?:D
Mr Spock
Να ρωτήσω κάτι?
- απ΄ότι βλέπω , συνεχίζουν
lakiss51
Κατά ΠΟΛΎ φθηνότερα εδω
Να ρωτήσω κάτι?
Γιατί υπάρχει θέμα από τη στιγμή που συστήνεται να παίζουν ΜΕ τις γριλιες;
Emmanouil 1964
Mr Spock
Καλέ μου φίλε .
Εσύ που κατέχεις μιά ολιά αυτή την γλώσσα , .....ήντα λέει ;
lakiss51
Κώστα αντί να ...αερίζεις τον Κινέζο :), δεν τους λες σχετικα;
xkaragi
