Magnepan LRS loudspeaker
Mr Spock
demokratischer - sektor
The LRS is a relatively low-sensitivity (86dB/500Hz/2.83V), low-impedance (nominally 4 ohms) loudspeaker with a taste for amplifier current. That suggests to me a speaker that will likely sound different with every amp I try—and sure enough, after weeks of auditioning these slender (14.5" by 48" by 1"), quasi-ribbon floorstanding panels, and driving them with a variety of high-quality tube and solid-state amplifiers, I realized that getting the most from the new Magnepans requires not only a sophisticated, current-capable amplifier, but it also requires a sophisticated audiophile with some listening room floor space and a trained ear.
"Whether the tweeter is on the inside or outside, the tweeter should not be closer to the listener than the bass section," Wendell Diller told me. "Measuring from your seated position, if the bass panel is 10' 6" [away], the tweeter should be at least 10' 7"." Think in terms of mid-to-treble balance and remember to not place the LRS parallel to any walls.
I left my home in Norfolk Virginia
California on my mind
I straddled that Greyhound
And rode him into Raleigh and on across Caroline
I woke up high over Albuquerque
On a jet to the promised land
When the song ended, I was speechless. I could not imagine a million-dollar system playing it any better. Like a child, I played "Promised Land"—America's greatest poem by America's most original poet—over and over, each time louder than the last. Suddenly I wondered: Could the new Maggies play Chuck—loud and with attitude?
Magnepan LRS, anechoic response on mid-panel tweeter axis at 50", averaged across 30° horizontal window and corrected for microphone response, with the nearfield panel response plotted below 300Hz.
Magnepan LRS, step response on mid-panel tweeter axis at 50" (5ms time window, 30kHz bandwidth
https://www.stereophile.com/content/magnepan-lrs-loudspeaker-0
https://www.magnepan.com/model_LRS
Magnepan’s extraordinary LRS ribbon speakers
:hi:
C
chrispo
..για ¨κουρτίνες¨, μια χαρά μετράνε και ειδικά στην τιμή αυτή..8-)
gid
Πονηρή η Magnepan, ενώ μιλάει για ηχεία των 4Ω, δίνει ευαισθησία για είσοδο 2.83V... και όχι για 1W....
Mr Spock
Την καταβόθρα στα 3KHz που είναι -12db την κάνουμε γαργάρα; :p
- ναι γιατί πέριξ των 3k η ευαισθησία του αυτιού χτυπάει κόκκινο
Ξανασκέψου το.
Οταν πας Live ζητάς απο την ορχήστρα να κόψει 12db στα 3Khz?
Ναι.
Ανετως.
Να άκου: γαρ γαρ γαρ γαρ
Άμα ζήσεις ποτέ με δίπολα θα δεις ότι έρχεται αυτή από το χώρο. Αλλά με τα μπιενταμπλεγιου που να ξέρεις από τέτχια συ...
Αυτά τα ηχεία αλλιώς μετράνε νιαρ Φιλντ, κι αλλιώς στη θέση ακρόασης. Η απόσταση τοποθέτησης από τον οπίσθιο τοίχο, αλλάζει το σύμπαν όλο.
Η ανηχοικη μέτρηση της μεμβράνης, δείχνει μια εξαιρετική ταργκετ κερβ, και μένει στο χρήστη να ολοκληρώσει το έγκλημα στις πρώτες οκτάβες.
Το στεπ ρισπονς εγγυάται εξαιρετική χωρική πληροφορία και εστίαση, αλλά και μικροδυναμικα.
Για την τιμή του ηχείου, στο χώρο του Χάι Εντ, είναι ευκαιρία. Η δυσκολία οδήγησης και τοποθέτησης είναι τα βασικά του μειονεκτήματα.
Να δω καλή μέτρηση στη θέση ακρόασης, μέχρι τότε δεν θα μιλάς για την μπιεντάμπλεγιου :p.
Άκου -12db.
:fuckyou:
Σιγά τα ωα, ψάξε παλιότερα θρεντ, έχω φλατ μετρήσεις στη θέση ακρόασης, δεν είναι αυτό θέμα συζήτησης..
Επειδή έχω φάει με το κουτάλι το θέμα των μαγκ, είναι βέβαιο πως με κατάλληλα ενισχυτικά και με κροσαρισμενα σαμπ, και μια δόση ισοστάθμισης, μπορούν να κατατροπώσουν την συντριπτική πλειοψηφία των χαιενταδικων ηχείων, με πειστική αληθοφανή μουσική εικόνα και με αέρα νικητή από τα αποδυτήρια.
Βεβαίως βεβαίως, το αντίπαλο δέος εκφράζεται κατά βάση από τα επαγγελματικά όπλα ανάλυσης και τα μετρημένα κουκιά υψηλής πιστότητας αναπαραγωγής, όπως λόγου χάριν είδαμε κι ακούσαμε στο μάξιμουμ από την γαμημ.. τιμημένη σχολή των Γκετ Χάρντ. Προφανώς, άλλος πλανήτης. ;)
Κάπου στον πάτο του βαρελιού της παγκόσμιας παραγωγής Χάι Εντ, κάτω από τα σκατα του Χάι Εντ, λίγο πάνω από τα ρεντεκο και μεταξύ ρεντεκο και χαρμπεθ, βρίσκονται τα μπιενταμπλεγιου. Συγκριτικά δηλαδή, προκειμένου να πάρεις ρεντεκο, καλύτερα πάρε μπιενταμπλεγιου, αλλά αν έχεις πιο πολλά λεφτά, πάρε χαρμπεθ, τα σκιζουν τα μπιενταμπλεγιου. Ναι, τα ντουλάπια.:p
Mr Spock
Ξανασκέψου το.
- ναι αλλά εδώ μπορεί να έχει να κάνει με το voicing, ποιο ξεκούραστο πχ, ok,,, 12db παραείναι
Ο ντιζης σιγοβράζει μέσα του να τα ξεφορτωθεί όλα μαζί πακέτο να ακούσει πολυκάναλη μέταλ στο περιποιημένο τσαρδι του, μετά από το σοκ στου Στάθη.
Εγώ, βοηθάω προς τη σωστή κατεύθυνση, σα πραγματικός φίλος. :D
Το επόμενο και τελειωτικό βήμα είναι να έρθει ο ντιζης Σαλόνικα, να περάσει από μας τους 3 πολυκάναλους να φάει τις μπατσες τη μια μετά την άλλη.. Θα στείλει από δω sms στη γυναίκα του στην Κύπρο να πακετάρει τα μπιενταμπλεγιου..
Τι λέει αυτός ρε @wizzy;
Μην τον ακούς, έκανε σεισμό στην Αθήνα και κουνήθηκε το μυαλό του στη Θεσσαλονίκη!
Θα γίνει κι αυτό κάποτε...8-)
Rosinante
Dark Nιάου
Παντα ηθελα μεμβρανη, ειναι το κρυφο μου απωθημενο. Τωρα που ειναι φτηνα θα τα παρω επειδη εμπιστευομαι το γιατρο. Κι αμα δε μ' αρεσουν, τα κραταω για παραβαν να αλλάζω. Που να τρεχεις τωρα ικεα για παραβαν.:D
Εγω σιγά σιγά το στήνω το πολυκάναλο με B&W στον πάνω όροφο. Να δω και πεντακάναλο με μάγκνεπαν στο σαλόνι του Εαρ κι ας πεθάνω :laugh:
Άντε, όρμα, με δυο χιλιάρικα παίρνεις τρία κομμάτια, φτηνά βγήκαν αυτά.
Nick Arvanitakis
Audio Pro
Εσύ τα λες χρόνια τώρα, αλλά ...
Τα Magneplanar είναι πολύ φτηνά , για αυτά που μπορούν να δώσουν, διότι σου τρώνε τα λεφτά εκεί που λέει ο EAR.
  • rose.athens
Ioanniss
