Monoprice HTP-1 16CH Immersive Surround AV Processor
Monolith by Monoprice HTP-1 16 Channel Dolby Atmos, DTS:X, Auro3D Home Theater Processor w/Dirac & Alexa Compatibility
Price: $3999
The Monolith HTP-1 Home Theater Processor is a state of the art, 16 channel processor engineered for the most demanding audiophile. Featuring the latest in multichannel surround sound with Dolby Atmos and DTS: X decoding, the most advanced room correction with Dirac Live, the latest generation AKM4493 DACs, and plenty of inputs for all your sources, the Monolith HTP-1 is the no compromise foundation of any high end home theater.
Specs:
Audio Codecs Supported
Dolby® ATMOS
  • Includes support for Dolby® TrueHD and Dolby® Digital
  • Up to 16 output channels with flexible speaker assignment.
  • 9.1.6 (add wide channels, and upper front and rear)
  • 7.3.6 (3 subwoofers instead of wide channels)
  • 7.5.4 (5 subwoofers, only 4 upper)
  • Dolby Surround Upmix (replaces Dolby® Pro Logic®)
DTS:X™
  • Includes support for DTS-HD Master Audio™
  • Up to 12 DTS:X channels (7.1.4)
  • Bass management can produce 7.5.4
  • DTS Neural:X Upmix (replaces DTS Neo:X™)
Other Audio Sources
Roon Endpoint
Ships with a Google Chromecast dongle for basic Ethernet Audio like Spotify, etc.
Bluetooth
Audio Enhancements
Dirac Live Room Correction
Bass Management
Up to 5 Subwoofers
4th Order Linkwitz-Riley Crossovers
PEQ
Tone Control
Dynamic Range Control
Video Inputs
HDMI 2.0b with HDCP 2.2 HDR10, HDR10+, Dolby Vision (upgradable to HDMI 2.1 in the future) x7
Video Outputs
HDMI 2.0b with HDCP 2.2 with HDMI eARC
Audio Inputs
Toslink x3
Coaxial x3
AES/EBU
USB Audio (24bit/192khz)
2 Stereo Pairs RCA
Other Inputs
Trigger in
USB Service Port
Ethernet
Alexa Compatibility (Requires Echo or other Amazon Device)
Audio Outputs
16 Balanced XLR Connectors (primary)
1 Pair Stereo RCA Unbalanced (stereo mixdown)
Other Outputs
Trigger Out x4
Chassis
Size: 17.1”W x 5.7” H x 12” D
Front panel touch screen 4.3 inch diagonal, RGB 480 × 272
Q&A Interview with Hobie Sechrest, Business Unit Manager of Monoprice
Q: Is the HTP-1 manufactured overseas or in the USA?
A: The HTP-1 is made in the USA with globally sourced parts.
Q: Does the HTP-1 have OSD overlay via HDMI?
A: No, the unit is configured via PC and Tablet like many of the high end processors on the market.
Q: Can you assign LFE to the main channels even if the subwoofer channel is engaged?
A: Yes you can. You can also configure 5 independent subwoofers and run a full 7.5.4 speaker layout or do 3 subs in a 7.3.6 configuration.
Q: What version of DIRAC is included with the HTP-1 and does it come with a calibrated mic?
A: Dirac Live, and at this time no mic is included. We are working with Dirac to be able to have the customer purchase additional modules if they want, like the new Bass Correction they just announced.
Q: How many bands is the manual PEQ and is it fully adjustable (fs, Q, etc)?
A: Right now, there are 3 bands and fully adjustable. But, based on your suggestion, we are looking to expand it to 5 bands.
Q: What is the max unclipped Voltage output from the balanced outputs?
A: The max unclipped output is 24dBu (12Vrms).
Q: Is the power supply in the HTP-1 linear or SMPS?
A: Right now it is an SMPS, but we might change it to an LPS. This is still TBD. We think the noise floor with the SMPS is good at over -110db, but if we feel using an LPS we can make the switch before production.
Q: Does the HTP-1 support Auro 3D or will there be a firmware upgrade to support it?
A: The hardware is already inside to support it so it would just be a firmware update to add it. Auro 3D will be supported on the HTP-1 as just announced at CES 2019!
Q: Does the HTP-1 allow cross surround upmixing between formats or does it follow the new Dolby protocol to restrict codec upmixing?
A: The HTP-1 will follow the new protocol.
προβλεπω μεγαλη καθυστερηση στο dirac ,
οτι εχει παθει και η emotiva.
στα @@ ς
Πολύ φτηνό για αυτά που προσφέρει!
Μεγάλη επιτυχία προβλέπεται, αν δουλεύει κανονικά.
ομοίως στα @@ ς
:lolsign: :lol:
Ενα χιλιάρικο πιο φτηνό:
Μόλις ενσωματωθεί το Dirac θα είναι πολυ ανταγωνιστικό προϊόν.
TERMATOGAZI
Bass!
Λιγάκι πιο λιανά και για μάς τα... ανήλικα?
Ουσιαστικα ο monoprice ειναι αντιγραφη του emotiva rmc1 , ο οποιος εδω και ενα χρονο περιπου παλευει να ενσωματωσει το dirac .
Ομοιως βγηκε ο xmc-2 χωρις dirac ακομα.
Υπαρχει μεγαλο θεμα με την ενσωματωση του dirac στα πολλα καναλια . Οταν το λυσουν θα εμφανιστουν πολλες καλες λυσεις αλλα μεχρι τοτε δεν θα ρισκαρα να αγορασω καποιο ημιτελες προιον.
Σταύρος Λαγκαδιανός
Το αγοράκι με τα σπίρτα
Και o Trinnov? Γιατί οι Γάλλοι μπορούν και οι Αμερικάνοι όχι? Υπάρχει μήπως αιτιώδης (και διαπιστωμένη βέβαια) σχέση με τη διαφορά στην τιμή και πού μπορεί να εντοπίζεται αυτή?
Ο τρίνοβ δεν εχει ντιράκ, έχει δικό του λογισμικό.
TERMATOGAZI
Bass!
Δεν ειναι θεμα της dirac .
Υπαρχει datasat και stormaudio που δουλευει.
Το chip που πρεπει να κανει ο κινεζος δεν ειναι ακομα ετοιμο για τις πιο φθηνες λυσεις οπου δεν ειναι υπολογιστης ο προ.
Και το ίδιο με φίρμα στην ουγια να λέει φοκαλ.
Επίσης υπάρχει wisdom, mackintosh, bryston, κλπ κλπ κλπ.
Λεφτά να έχεις, λύσεις με Dirac υπάρχουν.
Απλώς όταν τα κοστολογια αυτών των λύσεων αγγίζουν το κόστος του τρινοβ, ε, νισαφι. Ντροπή.
Και ο NAD που είναι φθηνός πως έχει Dirac; Είναι διαφορετική έκδοση λογισμικού;
TERMATOGAZI
Bass!
Το προβλημα ειναι στα >11 καναλια
έτσι όπως το βλέπω.... σε λίγο να τους βγαίνει πιο φθηνό το pc based από το να καταναλώνουν εργατοώρες σε ανάπτυξη chip και προγραμματισμούς
για να δούμε ποιος από τους γνωστούς θα κάνει την αρχή :geek:
Δεν θεωρώ ότι είναι τόσο απλό.
Θα είχε γίνει ήδη αν ήταν έτσι.
δεν έχει διαφορά ως προς τον κώδικα....
απλά οι μεγάλοι έχουν μάθει-εγκλωβιστεί στο να παράγουν ολοκληρωμένα κυκλώματα σε συνεργασία με άλλες εταιρίες του χώρου...
είναι συμβόλαια δεκαετιών-γραμμές παραγωγής
άλλωστε υπάρχει έτοιμος κώδικας του dirac για pc hardware
θεωρώ και κρίνω (από τα προβλήματα ενσωμάτωσης του dirac και των dsp chips που ακούστηκαν)
ότι είναι πιο απλό-οικονομικό να επενδύουν σε μια πλατφόρμα pc based από το να εξελίσσουν κώδικες και να χάνουν ώρες προσωπικού στο να τα ενσωματώνουν σε chip περιορισμένων δυνατοτήτων
πλέον έχουμε ξεφύγει σε θέματα καναλιών και αντίστοιχης ισοστάθμισης που πρέπει να τα συνοδεύουν....και άρα επεξεργαστικής ισχύος που απαιτείται για να εφαρμοστούν τα φίλτρα αυτής
αργά η γρήγορα πιστεύω πως θα γίνει.....έστω και σε υβριδική μορφή συνεργασίας pc-amplifier
Jiovani75
