McIntosh MC257 - 7 x 200-Watt Home Theater Amp
Αυτά είναι μηχανήματα. Με στροφόμετρα να βλέπεις ποσο γκαζια θα δωσεις, στιβαρα (58 κιλα παρακαλω), με μπορνες να σφιγγεις το καλωδιο μεχρι να του βγαλεις το λαδι. Δυο μονο κουμπια μπροστα, όχι σαν κατι αλλους που πρεπει να βγαλεις πανεπιστημιο να ξερεις πιο να στριψεις.
Ον οφ και ενταση, ετσι απλα ρε γμτ. Γι αυτό τ αξιζει τα λεφτα του. Εχει γινει πλεον δυσευρευτη η απλοτητα.
Mr Spock
demokratischer - sektor
. . . in addition to the new TripleView meter, the MC257 features many other upgrades. When using just the front left, center and right channels, power output has been increased by 25% from 200 Watts per channel to 250 Watts per channel. When using all 7 channels, each will receive a healthy 200 Watts per channel. Regardless of how many channels are used, the full 200 or 250 Watts is delivered to either 4 or 8 Ohm speakers via McIntosh’s Dynamic Power Manager® (DPM) technology. Filter capacity has been increased by 20% which has produced an amazing 94% increase in dynamic headroom from 1.7dB to 3.3dB as well as improving low frequency performance – both key features in a home theater amplifier, especially when listening to an energetic soundtrack . . .
ELECTRONIC SPECIFICATIONS
  • Power Output per Channel3 Front Channels only: 250W @ 4 or 8 Ohms
    All 7 Channels: 200W @ 4 or 8 Ohms
  • Number of Channels7
    (can also be used as a 2-zone amplifier with 5 channels in zone A and 2 channels in zone B)
  • Total Harmonic Distortion0.005%
  • S/N below rated output108dB
  • Dynamic Headroom3.3dB
  • Damping Factor>70 @ 4 Ohms
    >140 @ 8 Ohms
  • Rated Power Band20Hz to 20kHz
  • Frequency Response+0, -0.25dB from 20Hz to 20,000Hz
    +0, -3dB from 10Hz to 100,000Hz
CONTROL
  • Remote Power ControlYes, 7 or 5 + 2 Channel
  • Multi-Channel DB25 CableYes
GENERAL SPECIFICATIONS
  • Circuit ConfigurationPush-Pull Complementary
  • Circuit DesignSolid State
  • Mono BridgeNo
  • Mono ParallelNo
  • Output TypeDirect Coupled with Dynamic Power Manager®
  • MetersYes
  • Meter Light SwitchYes
  • Balanced Input7
  • Front PanelGlass
  • IlluminationDirect LED
  • Chassis StylePolished stainless steel & black painted steel
CONNECTIVITY
  • Speaker Binding Post TypeStandard
WEIGHTS & DIMENSIONS
  • Dimensions (W x H x D)17-1/2" (44.5cm) x 9-7/16" (23.9cm) (including feet) x 21" (53.3cm) (including front panel and cables)
  • Weight95 lbs (43 kg)
  • Shipping Weight128 lbs (58 kg)
  • Like
Reactions: PMC
petepappas
το προηγουμενο μοντελλο αν και αρκετα καλο δε δικαιολογουσε ηχητικα την τοσο αυξημενη τιμη αλλα γουστα ειναι αυτα.....
Τι να λέμε τώρα, την εποχή των ψηφιακών τελικών, αυτά τα μηχανήματα είναι δεινόσαυροι. Φαντάζομαι έχει αρκετά πάνω από 10.000 ευρώ. Αλλά δεν παύει να είναι έργα τέχνης και ως τέτοια κυρίως πρέπει να τα αντιμετωπίζουμε. Έργα τέχνης με μπόνους χρηστική αξία.
Mr Spock
Vakis2000
Κλιψ κλαψ
Οι ψηφιακοί τελικοί.... είναι ψηφιακοί! Δηλαδή ψυχροί, κουραστικοί κλπ κλπ, βέβαια δίνεις 3 - 4 κατοστάρικα για 300 -400 βατ, όμως ότι Πληρώνεις, Παίρνεις! Έτσι είναι οι νόμοι της Αγοράς!
Κατά τα άλλα συμφωνούμε απόλυτα!
Με βάση αυτό, λέτε σε μερικά χρόνια οι "λαμπάτοι" της εποχής να θεωρούνται οι ΑΒ ?
Katerinanota
