Analog News
Sony Cashes In On Nostalgia With 40th-Anniversary Walkman
In honor of the original Walkman’s 40th birthday, Sony is releasing an anniversary edition of the iconic cassette player that first made music portable, the company revealed at IFA on Thursday. Only, it doesn’t actually play cassettes, so don’t go breaking your collection out of storage. And it’ll set you back about three times as much as one would have in 1979.
Sony’s NW-A100TPS (doesn’t exactly have the same ring, does it?) marks the company’s latest attempt to revitalize the Walkman brand, and this time around they’ve seemed to have given up any pretense that this is anything more than a nostalgia cash grab. While Sony has purportedly made a cassette tape with a storage capacity that would put its 20th-century brethren to shame, the commpany smartly decided to forego magnetic tape entirely with its new design.
Instead, an Android-powered music player stores up to 16GB of your favorite tunes. It lacks a SIM card but you can connect to Wifi and use Android apps via its itty bitty 3.6-inch touchscreen. For the complete nostalgia factor, the device has a screensaver that looks like an old-school cassette player except the color changes depending on what type of music file is playing. An accompanying soft case that comes with it looks every bit like an old Walkman, so when you throw up that screensaver and snap the case closed it’ll make you feel just like you’re back in the ‘80s. Or, for those of our readers too young to remember the Walkman’s heyday (like me), it’ll make you feel just like you’re in an episode of Stranger Things.
If you want to go full retro mode, this special edition Walkman has a headphone jack as well. But you can also just connect to Bluetooth like a normal person too.
Unlike back then though, when a Walkman had a price tag of about $150, this special-edition Walkman will go on sale for $599 in Australia and €440/£400 in Europe come December.
Mr Spock
demokratischer - sektor
diskohead
Διαθέσιμο από χτες στην αμερικανική αγορά το Sol, το πρώτο πικάπ της γνωστής από τα ενισχυτικά της Schiit. Πολύ όμορφος σχεδιασμός, βραχίονας unipivot, τιμολογιακά ανταγωνιστικό ($928 με το mani, $799 χωρίς phono).
Mr Spock
AirTight ATE-3011 Phono stage για κεφαλές ΜΜ
Καινούριο phono stage παρουσίαση η Ιαπωνική AirTight που τελευταία είναι αρκετά δραστήρια. Πρόκειται για το μοντέλο ATE-3011 που είναι εφοδιασμένο με πέντε καμπύλες ισοστάθμισης για RIAA, NAB, AES, FFRR και FLAT τόσο για Turnover όσο και για Roll-Off. Τα turnover και roll-off μπορούν να επιλεχθούν ανεξάρτητα ώστε ο χρήστης να δημιουργήσει άλλες καμπύλες ισοστάθμισης ανάλογα με το βινύλιο που ακούει.
Η συσκευή είναι μεγάλη σε διαστάσεις, έχει αυτοφωτιζόμενη οθόνη και επιλογέα καμπυλών ισοστάθμισης στην πρόσοψη.
O AirTight ATE-3011 φέρει τρεις λυχνίες 12AX7 και έχει τρεις εισόδους RCA για κεφαλές MM. Ακόμη έχει μια μονοφωνική RCA και μια στερεοφωνική RCA έξοδο. Το κέρδος του είναι 40dB και το βάρος πάνω από 12 κιλά.
Valves employed:12AX7 x 3
Phono equalizer input:RCA/MM × 3
Input impedance:47kΩ(Gain 40dB)
Phono equalizer output:RCA × 2 + 1(mono only)
Output impedance:Recommended load more than 47kΩ
THD:-0.02%(1V/1kHz)
Frequency response:50Hz~20kHz(±0.2dB) /20Hz-2.5dB
Power consumption:50VA
Dimensions:400(W) × 375(D) × 151(H)mm
Weight:12.2kg
Μπράβο!
Αυτό είναι εργαλείο!
:hi:
Ημίθεος
Ααα γειά σας κ. Γουώτερς, τί κάνετε; Καλά είστε; Μπράβο μπράβο! Λοιπόν, θέλει λίγη δουλίτσα ακόμη, αλλά μέχρι το απόγευμα θα σας το έχω έτοιμο το μάστερ. Περάστε κατά τις έξι να το πάρετε!
Πλάκα στη πλάκα έτσι έκαναν μοντάζ. Σε ήχο και σε εικόνα. Και αν δεν κολλούσε σωστά η ένωση ή γινόταν λάθος; Καληνύχτα. Πάει η λήψη, έβαζαν την επόμενη καλύτερη.
Mr Spock
Clearaudio Performance DC Wood Turntable with Tracer Tonearm
As befits a high-performance turntable a step above entry-level, the Performance DC ships with a few goodies, such as a set of small screwdrivers and Allen wrenches for assembly, synthetic bearing oil, and even a pair of white gloves to prevent scratches and/or fingerprints on the platter, etc. during setup. The only ho-hum part of the package is the rather lightweight wall-wart power supply. Not a major disappointment but at this price I might have expected a slightly more upscale solution. However, I just learned that Clearaudio now offers an upgrade option, its Smart Power 12V ($1k), a self-regulating, low-impedance-battery power supply, in which greater current delivery allows the motor to produce greater torque, and also reduces noise
but most customers will likely choose one of Clearaudio’s ’arms in one of the tonearm-and/or-cartridge packages (which include discounts offered by Musical Surroundings) at different price points. As noted, my sample was fitted with the mid-tier Tracer tonearm upgrade; it features a carbon-fiber armtube and is the fifth of ten ’arms in the Clearaudio lineup. Initially it was fitted with a Hana SL cartridge, which had its merits, such as a bit more weightiness and a touch of richness as well as a hint of dryness (probably due to its pre-break-in status), but I couldn’t resist getting the amazing Clearaudio Stradivari V2 mc cartridge swapped in for an all-Clearaudio front end
Type: Belt-driven turntable with aluminum subplatter and DC motor
Bearing: Ceramic magnetic bearing (CMB) with sinter-bronze bushing
Speeds: 33, 45, 78rpm
Speed accuracy: .05%
Warranty: 5 years
Weight: 24.25 lbs. (11kg)
Dimensions: 16.54" x 4.92" x 12.99" (without tonearm)
Mr Spock
- το βάζω εδώ στα κρυφά και χωρίς καπάκι , για να μην γίνει ''της σκουριάς'' . . .
phono από την Φως Audio
Το κύκλωμα είναι δομημένο γύρω από τρεις διπλοτριόδους 12AX7 με ταιριασμένα χαρακτηριστικά, χρησιμοποιεί τυπωμένο κύκλωμα και καλής ποιότητας υλικά.
Η τροφοδοσία βασίζεται σε δακτυλιοειδή μετασχηματιστή και είναι σταθεροποιημένη. Το κέρδος του προενισχυτή είναι 45dΒ, η αντίσταση εισόδου 47kΩ και η χωρητικότητα 240pF.
. . . 240pF . . . γιατί όχι το στάνταρ 100pf ? . . . όλο και κάποια περαιτέρω χωρητικότητα μπορεί να προσθέσουν τα καλώδια
PURETONE
Ένα σκέτο "Π"
Κατι θυμιζει.................
Alex Nik
