HEDD
m1ts0s
News poster
ADAM Audio founder and long-term head of R&D, Klaus Heinz launches new company HEDD
Klaus Heinz and his son Frederik Knop founded the Berlin-based family business HEDD | Heinz Electrodynamic Designs in October 2015. At NAMM, HEDD introduces three analog active studio monitors with optional digital connectivity. Series ONE is comprised of three speakers: Type 05, Type 07, and Type 30. Each of these three models features improved woofer designs, modern uni-body cabinets in matt black, the latest generation of ICE power® amplifiers, and a sophisticated new version of Klaus Heinz’ well known Air Motion tweeter design (the HEDD Air Motion Transformer).
• Type 05 active near field monitor: 5,5“ woofer, HEDD AMT tweeter, 2x50W RMS amplifier, 45Hz–50kHz frequency response, max. peak 103db SPL
• Type 07 active near field monitor: 7“ woofer, HEDD AMT tweeter, 2x100W RMS amplifier, 32Hz–50kHz frequency response, max. peak 107db. SPL
• Type 30 active midfield field monitor: 2x7“ woofer, HEDD AMT tweeter, 4x300W RMS amplifier, 30Hz–50kHz frequency response, max. peak 116db SPL
Furthermore, HEDD | Heinz Electrodynamic Designs developed a modular input card system called the HEDD Bridge. Individually fitted to the needs of users, every speaker may be equipped with one optional AES3/AES EBU, Dante Audio or Ravenna /AES67 card for Audio-over-IP integration (USB2 and Wireless card solutions will follow during 2016). HEDD studio monitors are the first loudspeakers worldwide to combine analog monitoring with the ability to fully integrate with audio-related protocols over Ethernet. This makes them team players in IP-based recording and mastering studios but also in more complex multichannel environments such as Dolby Atmos, Auro 3D, broadcast or live concerts, where multiple separate loudspeakers have to be administrated and fed with individual high resolution audio streams.
m1ts0s
News poster
https://www.gearslutz.com/board/11645159-post12.html
"Just a few remarks that might be helpful to understand what these new monitors are about. The new speaker line (called Series ONE) may remind people of ADAM in terms of look (and I indeed heard that comment several times today at NAMM). However, these are very different beasts:
– the woofer / diaphragm material is based on a new resin-coating which makes it way stronger than anything we`ve used before. The bass response is a big step forward in my opinion. Fuller and more accurate.
- we are working with a waveguide for the tweeter now (indeed based on the Air Motion Transformer, that Klaus Heinz is known for since the early 90s). The use of this waveguide lowers the crossover frequency by about 400Hz (the tweeter kicks in at 2.4kHz now), which is great to improve the midrange in 2-way-systems.
– the cabinets (with up to 40mm thick front-plates) and ICEpower amps are new as well.
– those are unibody-style cabinets with a rubber finish: very different feel.
And please note that these speakers, although 100% analog, come with the ability to understand various digital protocols, including DANTE and Ravenna Network. No other speaker brand has this feature at the moment."
Απόψεις ενός κατά-τα-φαινόμενα έμπειρου σχεδιαστή:
http://www.hedd.audio/en/find-better-studio-monitor/
Situation 4: an experienced colleague is with you, you have to accept that he does not agree with you in the one configuration and shares your opinion in another.
και σκεφτείτε ότι μιλάει για sound engineers που ξέρουν και 5 πράματα ο καθένας, ιδίως από θεωρία!
Η Τατιάνα η ωρολογοποιός;
Post automatically merged:
Ωραία είναι εκεί μέσα, θα γουσταρα να κάτσω κει να μιλάω με τους παραγωγούς. Απ'την παραγωγή στην κατανάλωση, μια ευθεία.
Τουλάχιστον δε θα ακούω αρλουμπες για καλώδια ρεύματος, αυτό που το πας...
Τι να τα κάνεις τα σαμπ, δε χρειάζονται, χαλάνε τη μουσική όπως και τα dsp.
Σκέτοι οι δορυφόροι με ένα 6-αρι αρκούν για τον μέσο χαϊεντά. Αυτά έχουν 7,2" έκαστο μιντγουφερ, υπερβολές...
Εξαρακια λεμεεεεεεε
ΥΓ. Τα 4 τεμάχια 9" σε έκαστο σαμπ, μου θυμίζουν το παρόμοιο σαμπ της dynaudio. Πολύ.
Σαν ίδιο...
16 9άρια σε 2 Towers.
:lol: :lol: :lol: :lol:
:smg::smg::smg::smg:
Τα Type 20 & Type 07 πόσο έχουν ;;
1799 και 659 αντίστοιχα. Εγώ μάλλον θα προχωρήσω με 2χ type 07 για αρχη. Τα χαρακτηριστικα τους και η τιμη τους ειναι η χρυσή τομή για εμένα ώστε να μπορέσω να τα κάνω 5άδα και 7άδα αργότερα με ένα λογικό κόστος.
thanos117
