Νέα Zidoo Z9S & Z10
κατεβαστε το apdoit κατεβαστε και τρεξτε την εφαρμογή netflix. Πηγαίντε στις προηγούμενες version και κατεβαστε αυτην με πρωτο αριθμό 6 κατι.
Και επίσης με το καινούργιο update δεν βρίσκει πλέον εξώφυλλα .
Τέλεια εεε?
Να ρωτήσω τον @leonkoum: αυτό το update
Νέο-νέο fw update για το Ζ9s με ενσωματωμένα τα google play (και όχι μόνο..δειτε το '10.Optimizing seamless branching issue.')
Model ZIDOO_Z9S
Version v2.3.15_G
Download http://apidl.zidoo.tv/Z9S/v2.3.15_G/ZIDOO_Z9S_N_v2.3.15_G_202001171523_ota-package.zip
MD5: 825F848FFD915D6C7053C42ABB23A223
Upgrade method OTA
System
1.Optimize DLNA function
2.Fix the problem that DTS full-track music cannot be played
3.Fix the issue that HIFI music will not play to next track automatically occasionally
4. Optimize online playback
5. "Info" button on remote control could display the current HDMI output information
6. Optimize the abnormal sound problem when DTS music playback is paused
7.Fix the abnormal sound problem of Bluetooth device when set the Hdmi RAW outputβ
8.Fixed the freezes issue of few Dolby Atmos audio
9.Optimize occasional crashes on individual devices
File manager
1.Fix the problem that NFS displays the same share name(only one can be found for multiple Usbshares of Synology external hard disk cabinets)
2. Cancel the top navigation category and add the circulation list
3. Add tips when CD-ROM insert into
4. Optimize sorting function (save separately by path)
5. Add the function to return to the top of the list by pressing "Popup" button
6. Fix the problem that the played video does not prompt the watched icon
7.Modify the problem that the volume label does not display for when it’s more than 20 characters
Poster wall
1.Optimize the display of videos for a same series movies
2. Optimize segmented video scanning
3. Optimize scanning to solve the problem that stopping scanning during scanning may cause unmatched videos to not match properly when continuing scanning
4. Solve the problem that the child lock set is not displayed synchronously after the movie rating is initially set
5. Increase the HDR corner mark (scanned videos will not be displayed)
6. Optimize file name recognition
7. Optimize application stability
8. Optimize bracket processing for title recognition
9. Add trailer filtering, the word 'trailer' in the file name will no longer be scanned
10.Optimize the NFS mount method
11.Fix the problem that the background service causes the setup wizard language to be incorrect
12.Fix the problem of disordered videos in the folder list interface
13.Fix the problem that poster information cannot be obtained by the file path
14.Fix the problem that the incorrect total number of videos on the device after moving some videos out of the poster wall
15.Clear device and delete device will remove related video information from database
16.Fix the issue that the posters do not refresh after modifying the rating of the child lock
17. Child lock setting interface adds description and child lock reset function
18. Optimize the collection function
19.Fix the issue that playback records cannot be saved when playing NFS files
20.NFO added sorttitle field support, only use this field for sorting in movie collection interface
Music Player
1. Optimize folder browsing function
2. Add CD playback function (CD-ROM is needed)
3. Optimize the sorting function
4. Optimize the calculation method of scanning progress
5. Optimize track identification for SACD and CUE albums
6. Improve API to obtain track list, and solve the problem that the mobile phone Controller APP cannot get CUE / DSF track of the temporary list
7. Modify the time display format of CUE to keep the same with SACD
8. Optimize focus control logic to solve the problem of focus flicker
9. Modify the recording method of the playlist to solve the problem thatβprev trackβwill not work in random playing mode.
10. Add screen saver in playing details interface
11.Fix an issue that list interface displayed incorrectly after the grid layout removed the list
12.Fix the problem of getting albums incorrectly when playing music from file manager
13.Fix the problem that the lyrics could not be disappeared without playing the details interface
14.Fix the problem that sometimes the detailed interface picture cannot be obtained
15. Add automatic full-screen playback switch
16. Add music file information display in the list
17.Solve the problem that search interface focus may be lost
18.Fix the problem that the song is switching abnormally in the playback interface
19. Modify singer details interface
Add album sub-categories, you can directly enter album details interface from the list
Add a picture sub-class, you can set the default picture, delete and add pictures
Add a details sub-category, you can browse all the information of the singer
20. Add "Artist viewing" and "Album viewing" functions
21. Add song names that could not be matched as"track + number"
22.Fix the problem of flashing back when pressing the "Home" button in the folder song interface
23.Fix the paused playing problem when Bluetooth remote control is connected
24. Add multi-folder scanning,
25. Fix the problem that the time of the song displayed on the front panel is incorrect
26. Fix the problem that the sample rate of the playback details interface is incorrect.
27. Fix the problem that the DAC switch is switched to play music automatically in pause mode
28. Fix the problem that some DTS-CDs cannot be played
Local player
1. Optimize incorrect bit rate problem
2. Fix incorrect movies files name problem
3.Add ZOOM function
4. Increase the video ratio
5.Fixed the issue that Polish subtitles are displayed in Portuguese
6. Optimize subtitle download function
7. Optimize the front panel USB icon display issue
8. Optimize the problem that DVD cannot select chapters
9. Optimize ASS subtitle displaying
10.Fix the problem that the srt subtitle space is not displayed completely
11.Fix the problem that the file name of the DVD folder was displayed abnormally during playback
12.Optimize the setting of video scale interface display
13.Add function to play in order
Blu-ray navigation
1. Add shortcut keys to display subtitle track list
2. Optimize subtitle downloading function
3. Fix the problem of incomplete display of srt subtitle space
Quick settings
1.Add ignoring EDID function
2.Add video sequence playback function
3. Add USB audio switch
4.Fix the issue that the HDMI RAW output will automatically become LPCM after switching the DAC switch
Picture manager
1.Optimize blur image problem when playing slideshow
Controller APP (need to update mobile app v.1.5.5)
Method 1: Download and install manually (http://apidl.zidoo.tv/app/zidoo_controller.apk)
Method 2: Re-scan the QR code in Control Center to download the application
1.Add audio offset setting in the setting interface
2.Folder browsing function has been added to the music device interface
3. Application interface adds sorting function
4.Fix the problem that the same device is repeatedly added to the music device interface
5.Fix the issue that the CUE / DSF track list cannot be obtained from the temporary list songs
6.Optimize the problem that icon is not displayed in the application interface
7. Optimize poster wall interface
8. Solve the problem that the file management will return to the upper directory when rescanning SMB or NFS because of the influence of search bar
9. File manager adds list refreshing function
10. File Manager adds CD-ROM list
από πού προέρχεται;
Γιατί εδώ βλέπω την 2.3.10:
οχι δεν παιζει ούτε αυτο.
από πού προέρχεται;
επίσης είχα χτές το βράδυ κάποιο θεμα με το ιντερνετ και δεν το είχα προσέξει.
Δεν έχει θέμα με τα εξωφυλλα.Απλά δεν είχε ιντερνετ για να τα βρεί.Σημερα δουλεψε σούπερ (προς το παρών)!!!
Oχι,οχι..
Δεν υπαρχει θεμα με τα εξωφυλλα (ακομα..) μια χαρα τα βρισκει. :acute:
Με το seamless branching εξακολουθουμε να εχουμε θεματακια και θα παρει λιγο καιρο μεχρι να λυθει οριστικα. Αλλωστε το λεν και οι ιδιοι .. optimizing NOT fixing! :gotcha:
Το θετικο ειναι οτι οντως πια θα ασχοληθουν ενεργα με το θεμα και καποια στιγμη θα λυθει σωστα.
Τα fw ως επι το πληστον ειναι -beta και ερχονται απο αυτους.
Οταν δεν υπαρχουν πολλα θεματα τοτε περνει το δρομο για -stable.
(Tα επομενα λογισμικα θα αρχισουν λιγο να ερθουν γιατι οπως πιθανον να ξερετε ξεκινα η κινεζικη πρωτοχρονια και για 15 μερες δεν λειτουργει σχεδον τπτ)
Na ξεκαθαρισουμε και κατι, το μηχανακι αυτο ΔΕΝ ΕΙΝΑΙ kodi box, πραγμα που σημανει οτι οσοι το πηρατε να να τρεχετε 'kodi' κανατε λαθος επιλογη. Το ZDMC -κατα την λογικη τους- το εχουν πια μονο για τα addons. Ως player για τη θεαση ταινιων συνιστουν αποκλειστικα την χρηση του δικου τους ειτε αυτονομα ειτε μεσω του ZDMC.
Επισης ZDMC & KODI ΔΕΝ πανε μαζι..
Ειτε το ενα ειτε το αλλο θα εχετε και κατα προτιμηση το ZDMC, για να εχετε και την δυνατοτητα passthrough στον AVR.
Πλεον το ZDMC ειναι 6-7 προτεραιοτητα τους (βασικα το ψιλοπαρατησανε και καλα κανανε..).
Για kodi υπαρχουν φθηνοτερα και καποιες φορες τολμω να πω & καλυτερα κουτια γιαυτο κυριως αυτα που βασιζοντται σε almogic SoC
Επισης, ΔΕΝ ειναι android TV box, ΔΕΝ ειναι certificate για NETFLIX οποτε η οποια προσπαθεια να περασετε neflix θα καταληξει βασικα σε 'αποτυχια'. Η επισημη εφαρμογη δεν παιζει και η μονη που ξερω και παιζει ειναι μια παλια εκδοσης v6.xx για tablet οπου ομως σε παει μεχρι 576i αν θυμαμαι καλα και η πλοηγηση σε αυτην ειναι 'χαλια' γιατι θελει ποντικι.
Κατα την γνωμη μου βεβαια θα επρεπε ειδικα στις ακριβες τους κατηγοριες να ειχαν την σχετικη εφαρμογη & τις σχετικες αδειες 'αλλα'..... :O_o:
(και το DUne διαφημιζε οτι επαιζε netflix μεχρι που εσκασε μια αναβαθμιση και το εστειλε αδιαβαστο και μεχρι να το ξαναπατσαρουν περασαν 2+ μηνες.. εκτοτε δεν ξερω τι εγινε και πως παει με αυτο αλλα αποδεικτηκε οτι κοροιδευαν & παραπλανουσα τον κοσμο τα παλλικαρια εκει στην dune...:confused:)
H καλυτερη, φθηνοτερη και απροβληματιστη επιλογη για Netflix εαν η tv δεν ειναι smart -για μενα παντα- ειναι το Αmazon FireStick 4K. Απλο, ομορφο και ωραιο, -end of story!
(Πολυ καλο, απλουστερο αλλα δυστυχως οχι πληρως εκμεταλλευσιμο εδω στην Ελλαδα ειναι και το ROKU. Πολυ απλο και καλο.)
Επισης καλο ειναι να μην βαζετε μεσα οποια σχαχλαμαρα σε android εχετε στα κινητα σας.
ΑΝ το θελετε για θεαση ταινιων ειναι ισως αυτη την στιγμη η πιο VFM επιλογη -τηρουμενων των αναλογιων & δυνατοτητων- και προσπαθηστε να το εχετε 'καθαρο' απο οτιδηποτε ασχετο με τις δικες τους εφαρμογες.
Προβληματα & 'προβληματα' παντοτε υπηρχαν και θα υπαρχουν, το θεμα ειναι να αντιμετωπιζονται 'συντομα' & σωστα...
Υπομονη για το τελειο μηχανημα που δεν θα υπαρξει ποτε!
Αυτα τα ολιγα.. :gamer:
Χρήσιμα όλα αυτά που αναφέρεις.
Εγώ το επέλεξα για θέαση 4Κ περιεχομένου αφού το Nvidia Shield Pro δεν ήταν διαθέσιμο άμεσα και το παρέλαβα την Παρασκευή, αυτό που προσπαθώ να λύσω όμως είναι το conflict που μου παρουσιάζει με το arc.
Μέχρι πριν να το συνδέσω στο σύστημα μου ο ήχος της τιβι πέρναγε μέσω arc στα ηχεία του home cinema και έτσι είχα atmos - netflix από την τιβι.
Αν το ανάψω όμως δημιουργεί ένα κοκομπλόκο, μέχρι που δεν έχω καθόλου ήχο από τις άλλες πηγές(cosmote-nova-ps3) ή μόνη λύση που έχω βρει μέχρι στιγμής από το λίγο που κατάφερα να ασχοληθώ, είναι να σβήνω το Z9s από τον διακόπτη του από πίσω....
Επίσης έχεις κανένα οδηγό για τις βέλτιστες ρυθμίσεις;
Frame rate mode, Resolution, Color settings, HDR.
loggeo
Βέλτιστες ρυθμίσεις; Δεν το έχω, αλλά ιδανικά θα πρέπει να έχεις auto frame rate, uhd resolution (3840x2160), 4:2:2, hdr στο auto.
Προτεινόμενες εννοώ. Το frame rate είναι στο auto, αλλά εκεί έχει και κάποια υπό μενού- switch frame rate and resolution, με επιλογές- off, switch frame rate only, switch frame rate and resolution. Αλλά αυτά μάλλον θα τα βρω κατά την θέαση.
uhd resolution (3840x2160) έχει επιλογές στα 60,50,30,25,24 και 23Hz
Έχει κι άλλα.....θέλει μελέτη και χρόνο o_O
Στα παραπολυ γρηγορα,
Αυτο switch frame rate and resolution θα το εχεις ενεργοποιημενο.
Το hdr καλυτερα στο auto.
To RGB 16-235 (κανονικα το περνουν αυτοματα αλλα καλυτερα εσυ βαλτο καρφωτο)
4:2:2 (ή 4:4:4 αν σε αφησει..)
Αν εχεις AVR το audio βαλτο καλυτερα στο raw
Και τα υπολοιπα αστα γενικα στο auto.
Αν εχεις καλιμπραρισμενο μεσο μην το πειραζεις και φερε την εικονα στα γουστα σου με τa picture settings.
Aν δεν εχεις HDR πανελ βαλε ενεργη την μετατροπη HDR>SDR και καλυτυερα επελεξε το vivid mode.
Aν δεις οτι γενικα το player και το πανελ δεν πολυσυνεργαζονται βαλε το edid στο off και περνα τις ρυθμισεις που θες.
Καληεπιτυχια
Και πάνω που θα δήλωνα ενθουσιασμένος, μου ήρθε η π@παριά από εκεί που δεν το περίμενα: πολλές από τις συχνότητες στις εντολές του remote του Zidoo είναι ίδιες με τις συχνότητες στο remote του SVS PB-16! :headbang:
Tip:
Αν το τηλεκοντρόλ του zidοo δεν κοιτάει στην ευθεία το zidoo και το SVS αλλά το γυρίσεις 90ο (το μάτι από την άλλη πλευρά από αυτήν που βρίσκεται το SVS) πιάνει το zidοo αλλά όχι το SVS. ;)
Ξαφνικά από χθες το βράδυ, δεν μου βλέπει το NAS.
Δοκίμασα από εξωτερικό σκληρό να παίξω ταινίες και όλες είχαν κόμπιασμα στον ήχο!
Είμαι με το τελευταίο beta,για να βάλω official πρέπει να φλασάρω όπως λέει εδώ https://www.zidoo.tv/Support/support_guide/guide_target/ua1h3YuLrJzeq7k9e[ld]3ulg==.html και μετά update στο τελευταίο;
Κυκλοφορει στο διαδικτυο η εκδοση v2.3.17 Beta.
Kαλο ειναι ακομα να ΜΗΝ την βαλετε γιατι υπαρχουν καποια μικροθεματακια.
Οταν (..και ΑΝ) την ανεβασουν 'επισημα' τοτε.
Αντιθετα αν βρειτε την zidoo_poster_v2.8.0.apk βαλτε την, προς το παρον δειχνει ναναι οκ και εχει και την προσθηκη trailer της ταινιας που επιλεγετε ..
(αρκει φυσικα να εχετε συνδεση και να εχετε κανει και καμια επανεκκίνηση της συσκευής..)
Η ιδια εκδοση παιζει και στην σειρα Χ9s/X10 κανονικα...
που θα βρουμε το apk με την νεα version(για το x9s) και πως την περναμε
αν θέλεις ενα Link? κκαι πως την περναμε δεν εχω κανει εγκατασταση μονο apk.
Υπομονή λίγες μέρες που έρχεται νέο update.
Οποίος βιάζεται μπορώ να του το στείλω με pm.
(Η πλατφόρμα εδώ μέχρι ποσά ΜΒ αρχείο επιτρέπει; :whistling:)
Πούλησα το zappiti και πήρα z10 σχετικά με το να βρίσκει ταινίες και σειρές αν δεν τα έχεις ok θα στα βγάλει και οκ.
Τώρα δεν βρήκα τρόπο επιλογής μόνο για ταινίες απευθείας ..πρέπει να πας στο φίλτρο δυστυχώς ...
Επίσης όταν έχει και εσωτερικό δίσκο με ταινιές UHD δεν βρίσκω πως να τον μετονομάσω ...και πως θα ξεχωρίζουν ότι ειναι 4Κ...
Για να σου πω την αληθεια δεν καταλαβα ακριβως τι προβλημα εχεις για να σε βοηθησουμε...
Για το τελευταιο...
Αφου σκανρει κανονικα πανω στο καθε ποστερ σου βαζει ενδειξη '4Κ', '3d', 'collection' κτλ
Για το πρωτο αν δεν θες για καποιο λογο το ΗΤ2 πας το media center και επιλεγεις τον σκληρο, usb κτλ και τρεχεις απο εκει το αρχειο που θελεις ή οτι αλλο.
Γιατι να θες να μετονομασεις τον σκληρο? :O_o:
Δοκιμασε στο media center και αφου επιλεξεις την πηγη που σε ενδιαφερει πανε με το δεξι βελακι του remoteτερμα δεξια και εκει θα σου βγαλει νεα επιλογη (rename, copy, delete κτλ)
NIK DRAGON
