Teac NT-505 Black
sps
Το Φοβερό και Τρομερό Net Streamer Dac σε άθικτη κατάσταση με όλα τα παρελκόνενα.
Αγορά 05/19
950 Ευρώ
  • Hi-Res audio playback supporting DSD512 (22.6MHz) and PCM 768kHz/32-bit PCM
  • Dual monaural circuit design with a high-end AKM VERITA AK4497 DAC on each channel
  • Supports MQA decoding and TIDAL and Qobuz music subscription services, and is Roon Ready
  • DSD128 (5.6MHz) and PCM 192kHz/24-bit Network streaming from NAS/PC
  • 5 types of PCM digital filters and 2 types of DSD digital filters
  • Up-conversion up to 24.5MHz DSD and 384kHz/32-bit PCM
  • Dual on-board clocks for 44.1kHz and 48kHz frequencies, and 10MHz external clock input
  • Bluetooth® receiver supporting LDAC™ and Qualcomm® aptX™ HD
  • TEAC-HCLD output buffer circuit and TEAC-QVCS volume control for high quality sound
  • Dual toroidal-core power transformers
  • Digital Isolator for separated digital and Analog sections
  • 1/4" (6.3mm) stereo TRS jack supporting ground-separate drive
  • "Bulk Pet" USB transferring technology with four transfer modes for various sound characters * "Bulk Pet" is a registered trademark of Interface Corporation.
  • USB audio port for Hi-Res audio input from Windows/Mac
  • Coaxial and optical digital inputs on both front and back
  • Front USB port supporting Hi-Res playback from USB flash drive
  • Analog outputs with balanced XLR and conventional unbalanced RCA outputs
  • High-contrast full-graphic organic EL display with dimmer
  • Full-metal body with an A4-sized footprint
  • Free TEAC HR Audio Player for DSD512 and PCM32/768 playback
  • Free TEAC HR Streamer app for iOS/Android devices
  • Compliant with RoHS
sps
Ευχαριστώ γιά την φιλοξενία της αγγελίας, το ντάκ έφυγε.
Καλές ακροάσεις.
Να κλείσει η αγγελία.
Klipschlascala_pro1988
