Διάφορα
Hard to pardon:
why Tenet's muffled dialogue is a very modern problem
“If you watch old movies, you might hear some sound effects here and there but now they go nuts: somebody’s walking across the room in a leather jacket, you hear the zippers clink and the creak of the leather and every footstep is right in your face.”
As with most problems, every department assumes that another department is to blame. Although many viewers claim that films are getting louder, Bochar says that the opposite is the problem: “All of us in the industry will tell you point-blank that generally every single cinema is playing it lower than it should be.” A studio’s reference level tends to be around 85 decibels, or 7 on the Dolby scale, he says. But cinemas will often play the film at 4 (around 75 decibels). The Irish Film Institute has been playing Tenet at 4, Markey says, because 6 was “ridiculously loud” when tested. Cinemas will not necessarily play a film at the recommended level of 7 if they feel it is too loud.
Music changes chord for first time in seven years
Fans have flocked to a church in Germany to hear a chord change in a music which lasts for 639 years.
It is the first chord change to As Slow As Possible in seven years. The work by avant-garde composer, John Cage, is one of the world's longest and slowest piece of music.
The score is made up of eight pages of music, to be played at the piano or organ - very slowly. But the wait for the next scheduled chord change will be quick in comparison - with 5 February 2022 slated as the date.
The piece will end in 2640.
Cage, who passed away in 1992 at the age of 79, wrote the piece in the 1980s.
symos
You're not worthy!
Τις προάλλες έλυσε ο θείος μου ένα μικρό subwoofer από ένα σύστημα 2.1 που έχει στον κήπο για να ακούει ραδιόφωνο, γιατί είχε ξεκινήσει να κάνει ένα θόρυβο, σαν συντονισμό.
Μου στέλνει σήμερα το παρακάτω και μου λέει "βρήκα γιατί τρίζει"! 😲
Διπλό ρεκόρ, εθνικό και ευρωπαϊκό, σημείωσαν οι ανανεώσιμες πηγές ενέργειας την περασμένη εβδομάδα στην Ελλάδα. Σύμφωνα με τα επίσημα στοιχεία του ΑΔΜΗΕ, τη Δευτέρα 14 Σεπτεμβρίου οι ΑΠΕ (αιολικά, φωτοβολταϊκά) κάλυψαν το 51 % της ζήτησης ηλεκτρικής ενέργειας, ποσοστό που ανεβαίνει στο 57% αν συνυπολογιστούν τα μεγάλα υδροηλεκτρικά.
Την ίδια ημέρα, σύμφωνα με τα στοιχεία της WindEurope που εκπροσωπεί περισσότερες από 400 επιχειρήσεις και οργανισμούς της αιολικής βιομηχανίας, ο άνεμος στη χώρα μας κάλυψε πάνω από το 40% της ζήτησης, ποσοστό που ήταν το υψηλότερο στην Ευρώπη.
Άναβε ο μπαρμπούλης κάθε πρωί στις 7 την αρχαία τουβούλα του, κοβόταν το internet σε όλο το χωριό. Μετά απο 18 μήνες βγήκαν οι τεχνικοί απο το χάραμα στην παγανιά και το βρήκαν. :roflmao:
SHINE = Single High-level Impulse Noise
TGD
Thread Gravedigger
Μεγάλο ενδιαφέρον για μένα έχει η τελευταία πρόταση του κειμένου:
Το Όρκνεϊ ηλεκτροδοτείται πλήρως από αιολική και ηλιακή ενέργεια, ωστόσο δεν υπήρχαν προβλήματα στην ηλεκτροδότηση του υποβρύχιου data center.
Δεν του κάνουν δώρο μια καινούρια; Αν σκεφτείς τι τους κόστισε για να βρουν το πρόβλημα...
ROS
