Νέα Zidoo Z9S & Z10
Ερώτηση: τι πρέπει να κάνουμε ούτως ώστε το 'Α (αλφα κεφαλαίο, με τόνο) να εμφανίζεται στου υποτιτλους στο z9s;
Ευχαριστώ
ανοίγεις με σημειωματάριο το srt και όπου βλέπεις ANSI κάτω δεξιά πας αρχείο save as αλλάζεις την κωδικοποίηση κάτω σε utf-8 κάνεις save το ίδιο υπάρχον αρχείο και έτοιμος, υπόθεση 10sec...
ZIDOO_Z9S
Version number: v2.3.35 public beta firmware
MD5: 397B579E50AA95B559528EDD29CCC8C3
System:
1. Increase screen saver function
2. Add support for aiff music files
3. Optimize DLNA projection function
4. Add Czech language adaptation
5. Repair 3D seamless playback
Player:
1. Add press the information button to display poster information
2. Fix the problem of pressing the function key to continue playing during pause
3. Optimize subtitle download
4. Optimize the function of forced subtitles
5. Optimize the display of player poster information
6. Fix the problem that the local player's bit rate gets wrong
7. Added file name display for local player information key
8. Fix the problem that the shortcut keys cannot switch chapters
9. Optimize frame rate switching
Picture manager:
1. New revision of functions
2. Add custom folder function
3. Add the function of setting folders as screensaver pictures
4. Optimize the slideshow function
5. Fix the problem that the vertical screen picture is stretched in the slide show
6. Add the function of exclude folder
Poster wall:
1. Upgrade version 4.0
2. Optimize the sorting function of the navigation interface
3. Fix the problem that Douban cannot match
4. Solve the problem that the child lock will be ignored when playing directly
5. Fix the problem of incorrect data after sorting widgets
6. Optimize the ratio of local trailers
7. Optimize the sorting function
8. Optimize the details interface
9. Fix the problem of incorrect TV viewing records
10. Modify the problem that the detailed title is too long
11. When optimizing the list display, the letter navigation and the left side column prompt the picture at the same time
12. Optimize TV series matching
13. Fix the problem that Douban cannot match
14. Add the launch time setting of the trailer in the detail interface
Music player:
1. Re-upgrade music version 6.0
2. Optimize album matching logic
3. Increase the folder function
4. Optimize the detailed interface display
5. Increase music setting function
6. Added support for multiple formats (aiff, nrg, etc.)
7. Increase CD interface information display
8. Optimize playback stability
Main interface:
1. Optimize the boot display speed
2. Shortcuts add sorting function (press the menu key or long press the OK key)
3. Optimize animation fluency
Quick settings:
1. Increase screen saver settings
4. Add input method selection settings
File manager:
1. Optimize the display of playback records
2. Increase the playback record display switch
3. Fix the problem that the wallpaper of the file manager is not synchronized occasionally
Blu-ray navigation:
1. Increase the function of the information button to display movie information
2. Fix the problem of not being able to navigate after entering the screensaver
Сontrol сenter:
1. Optimize connection stability
App installer:
1. Optimize webpage installation function
Kαλησπερα..μια ερωτηση και απο εμενα...αυτην την στιγμη βλεπω ταινιες μεσω υπολογιστη...ο υπολογιστης ειναι συνδεδεμενος με hdmi σε εναν προενισχυτη με ενεργα ηχεια...το προβλημα ειναι πως δεν ξερω εαν ο ηχος που φτανει στα αυτια μου ειναι οτι καλυτερο μπορει να βγαλει ο προενιχυτης μεσω του υπολογιστη η εαν με ενα media player οπως καποιο zidoo θα εχω καλυτερα αποτελεσματα...οι ταινιες που παρακολουθω ειναι κυριως κατεβασμενες συμπιεσμενες μεν αλλα καλης ποιοτητας δε με ηχο dts(αναγνωριζεται και απο τον προενισχυτη) και τα αρχεια ειναι 30gb τουλαχιστον...οποτε pc η καποιο ποιοτικο Media player σε συνδιασμο με προενισχητη για προβολη ταινιων και ηχο 5.1?
Αφού είσαι συνδεδεμένος με HDMI είσαι ΟΚ. Επίλεξε HD ήχο μόνο.
Μια ερώτηση και από μένα,
Υπάρχει κανένας player πέρα από τον εργοστασιακό που να διαχειριστεί αρχεία 4κ με dolby atmos μέσω δικτύου ;
Καλημέρα .
Έχω το z9s.
Το hdmi in σε τι ακριβώς χρειάζεται?
Υπάρχει περίπτωση να κατεβάσω ήχο απο την τηλεόραση απο το hdmi και να ακούω netflix 5.1 μέσω του zidoo?
Αν και έχει αρκετό καιρό να βγει κάτι γιαυτο την σειρά σήμερα δεν πρέπει να έχετε παράπονο:
V2.3.45
Change logs:
player
1. Add UPNP video playback function
2. Added the function of adjusting the audio offset using the up and down keys on the remote control.
3. Optimize built-in text subtitle setting.
4. Optimize bookmark playback function.
5. Optimize the subtitle download function.
7. Added ASS subtitle brightness setting
8. Fixed the problem that song occasionally could not be played when switching to the next through the phone
9. Added the default function of the first audio track
10. Add some color settings for srt subtitles.
11. Added MKV chapter information display
12. Add Sony CEC playback function keys
BlurayNavigation
1. Optimize the display of movie information.
2. Optimize bookmark playback function.
3. Add some color settings for srt subtitles.
Home Theater
1. Optimize automatic scanning function.
2. Optimize the function of editing posters on the PC.
3. Added multiple video format icons in the detailed interface.
4. Fix the problem that the detail screen did not refresh after data update
5. Optimize search function.
6. Optimize interface display.
7. Optimize NFO analysis.
8. Optimize part of the UI.
9. Optimize the problem that posters cannot be displayed occasionally
10. Fix the problem that setting data cannot be restored when retstoring data
11. Optimize some interface
12. Optimize the poster saving catalog
13. Optimize the problem of occasional crash problem when scaning
14. Fix the problem of devices offline occasionally
15. NFO added Clear Logo support
16. Optimized the focus control of the device list
17. Optimized the UI display of poster details
18. Fixed the problem of abnormal data if the NFO file already exists when exporting NFO
19. Added more data information of NFO files, such as trailers, directors, actors, etc.
20. Optimized the loading speed of poster images
21. Fixed the problem of unsuccessful loading of poster pictures occasionally
22. Optimized native poster image loading function
23. Optimized data restore function
24. Added TV page selection function for series.
25. Fixed the problem of incorrect display of watch history
26. Fixed the problem that Blu-ray navigation can not be selected caused by the child lock
27. Optimized TVDB synchronizationdata of TVDB series
28.Optimized TV series poster title display
File manager
1. Increase UPNP function
2. Optimize NAS boot and mount speed
3. Optimize UI display
4.Fixed the problem of incorrect playback record.
Picture manager
1. Increase network picture display
2. Add UPNP picture slideshow
3. Fix the problem that the system music does not stop when slideshow
4.Added global folder name exclusion
5.Added slide pause function by pressing OK
6. Added the switch to scan hidden files
7.Optimized display UI
8. Added the function of pressing the information button to display picture information
9. Added the function of page turning button
Quick Setting
1. Add remote control up and down key multi-function setting.
2. Increase the time setting of the bookmark function.
3. Added player bookmark settings
4. Added the default setting for the first track
Mobile APP (scan the QR code of the machine to download and update)
1. Fix the problem that the music search page cannot play music.
2. File manager adds UPNP function.
3. Optimize some UI.
4. Optimize music favourite function.
5. Added music play-list mode.
Ανάλογα το player που έχετε κατεβάζετε προσεκτικά το ανάλογο αρχείο.
Beta version v2.3.80 for Z9S release
Change logs:
Music player
1. Optimized interface freeze problem when there are too many music files.
2. Optimized album sorting function.
3. Fixed the problem that SACD album can not skip to next song occasionally.
4. Optimized the display of some interfaces.
5. Fixed the problem that lists of artists and albums don't refresh when scanning.
6. Optimized the sorting function for the current playlist.
7. Optimized the device removal function.
8. Optimized image loading speed and stability.
9. Optimized matching function.
10. Added the loading function for artist list.
11. Optimized CUE parsing.
12. Optimized UPNP data loading speed.
13. Optimized scanning stability.
14. Fixed the problem that song details interface is sorted incorrectly.
15. Added the custom sorting function on left menu.
16. Optimized CUE seamless playback.
17. Fixed abnormal sound problem when outputting some DTS-CD files via RAW.
18. Optimized the information display of the playback details interface.
19. Added UPnP support DSD contents.
20. Optimized the film details interface.
21. Fixed the problem that no data is displayed when UPNP enters the list.
22. Added a option that artist will not show when the own tracks is less than this number
23. Fixed the problem that the loop playback function does not take effect.
24. Optimized music playback through the File Manager UPNP.
25. Optimized the display of lyrics.
26. Fixed the problem that the state is not saved when switching to list view mode.
27. Fixed the problem that the interface has no focus after re-matching data in the artist details interface.
28. Fixed the problem that the interface displays abnormally when the song details in album is empty.
29. Optimized the lyrics matching function.
30. Optimized partial translation.
31. Optimized the singer information and profile information.
32.Optimized rematch function
33.Support DSD CUE
34.Fixed can not return while enter an empty folder
35.Fixed the problem that UPnP songs can't save lyrics
36. Optimized artist picture display speed
37. Optimize the problem of fuzzy background display in detail interface
38. Fixed the problem that the singer information is not correct after the song is re matched
39. Optimize the lyrics search
40. Optimize the artist's image acquisition
41. Fix the problem that the lyrics get stuck when the single is played repeatedly
42. Fixed the problem that individual music cannot be played
43. Fixed the problem of noise in individual music playback
44. Optimized playback stability
45. Optimized the search function of UPnP devices
46. Added file information and other information to the details interface when UPnP plays,
47. Fixed have not refreshing the playback details after rematched
48. Fixed the problem that the artist information can still be found in the search interface after removed the device
49. Optimized the output sample rate display
50. Optimized playback stability
Poster wall
1. Added movie info acquisition when scanning.
2. Optimized the information icons on movie details interface.
3. Added more information in movie details interface.
4. Fixed the problem that scanning cannot be completed occasionally.
5. Optimized the loading speed of posters.
6. Optimized the poster display of watching record on the homepage.
7. Added information source on movie details interface.
8. Added function to export export collection picture in NFO.
9. Added local collection picture recognition function.
10. Optimized trailer loading.
11. Optimized custom classification collection.
12. Optimized the scanning stability.
13. Added Dolby Vision category on homepage.
13. Fixed abnormal display when collections are added into custom category.
14. Poster add 3D corner icon.
16. Optimized NFO parser
17. Optimized Trailer parser
18. Fixed occasional crash in the details interface
19. Added the path display switch on the detail interface
20. Optimized matching accuracy
21. Support trailer folder
22.Fixed while add a single movie to a category, the entire collection is incorrectly added to the category
23. Optimized scanning stability
24. Optimized the local image support of NFO
25. Optimized the trailers playback
26. Added some language translation
27. Optimized the trailer data acquisition
28. Optimized the Scraping of TV show
29. Added support TVDBID Scraping(follow plex rules)
30. Details shows TMDB source prompt
31. Optimized scanning accuracy
32. Fixed the function of skipping the beginning and ending of TV show on the zidoo control mobile APP
33. Fixed that less than 5 poster are not displayed when replace poster image
34. Added a switch for rotten tomato score
35. Optimized the trailers acquisition function
36. Fixed the problem of tvdb ordinary season being matched as special season
File Manager
1. Optimized interface partially.
2. Added manual network path for adding device in SMB.
3. Fixed the problem that no data is displayed when UPNP enters the list.
4. Added the function of list circulation when selecting devices.
5. Optimized UPNP playback function.
6. Optimized the UPNP list function and the list is gotten by page.
7. Optimized the file sorting function
Player
1. Optimized some shortcut key.
2. Optimized the fast forward function of the remote control.
3. Added subtitle setting function to the subtitle list.
4. Optimized forced subtitles functions.
5. Added the function to display movie info by pressing Left and Right keys for the first time.
6. Optimize playback stability.
7. Fixed the problem that some default subtitle language does not take effect.
8. Optimized interface partially.
9. Optimized the subtitle download function when playing through the poster wall.
10. Clearlogo display associated the loading Title switch
11. Added real-time bitrate display
12. Fixed the problem of wrong order playback
Quick setting
1. Optimized forced subtitle settings.
2. Optimized the static IP settings of wired network
ZD Link
1. Added screen mirroring background playback function.
2. Added AirPlay music screen mirroring function.
3. Optimized the stability of the screen mirroring.
4. Optimized the problem that some video software cannot cast screen.
5. Optimized the problem that the PC cannot be cast to the screen.
6. Added Play/Pause key response function for screen mirroring background playback.
7. Fixed the problem of entering into screensaver when playing video.
Change logs: Music player 1. Optimized interface freeze problem when there are too many music files. 2. Optimized album sorting function. 3. Fixed the...
Einai κάτι μήνες που το z9s den βρίσκει υπότιτλους.... Και μιας και μπαίνω σε mood χειμερινό (όπου προβλέπεται η θέαση ταινιών) είπα να το ψάξω λίγο αλλά άκρη δεν έβγαλα...
Deleted member 35
Από που τραβάει; Διότι και εγώ που είπα πάλι να ασχοληθώ λόγω κρύου διαπίστωσα πως το καλοκαίρι έπεσε σκούπα στο opensubtitles από τα κοράκια της ΑΕΠΙ. Μόνο με VPN.
Sugah
Ζαχαρούλης
Από opensubtitles τραβάει, μόνη λύση η αλλαγή DNS.
Είτε Cloudflare 1.1.1.1 είτε Quad9 9.9.9.9 και κατεβαινουν κανονικά
Ερώτηση μιας και ήρθε φίλος για να ακούσουμε μουσική και κατάλαβα ότι λείπουν από την συσκευή.
Πως μπορούμε να βάλουμε εφαρμογές όπως youtube ,spotify κλπ?
Μπορεις?
Με usb βρισκεις το αντιστοιχο *.apk και το τρεχεις
Σε ευχαριστώ υπάρχει κάπου η διαδικασία για το τι κατεβάζω ακριβώς και πως τρέχω τα αντίστοιχα apk γιατί δεν σκαμπαζω καθόλου??
Εδω και καιρο στο z9s που έχω δεν κατεβαινουν υποτιτλοι αυτοματα και τελευταιο αποκτημα δεν βρίσκει καθολου εξωφυλα απο το TMDB .
Προέκυψε ένα θέμα με το token της Zidoo στο TMDB.
Βγήκε καινούργια έκδοση του Home Theater, η οποία το λύνει.
Δεν χρειάζεται root.
NIK DRAGON
