Περί ATC
τι συζητάτε για την εμφάνιση; είναι εντελώς υποκειμενικό θέμα
άλλος προτιμάει ξύλο, άλλος μαύρα,
άλλος ψαροκασέλες, άλλος μοντέρνο σχέδιο,
άλλος θέλει να τα βλέπει και άλλος να είναι εντοιχισμένα ή αόρατα
και χίλια δυό
Κανένα εκ των δεδομένων δεν καταργείται. Ιεραρχούνται όμως...
Σωστά, μήπως όμως θα έπρεπε να το βαλουμε πρώτο στην λίστα? :p :D
Directivity Control Waveguide (DCW™) for flat on and off-axis response.
A revolutionary approach was taken by Genelec in 1983 with the development of its Directivity Control Waveguide (DCW™). We have developed and refined this technology over more than 30 years to greatly improve the performance of direct radiating multi-way monitors.
The DCW technology shapes the emitted wavefront in a controlled way, allowing predictable tailoring of the directivity (dispersion) pattern. To make the directivity uniform and smooth, the goal is to limit the radiation angle so that the stray radiation is reduced. It results in excellent flatness of the overall frequency response as well as uniform power response. This minimises early reflections and provides a wide and controlled listening area achieving accurate sound reproduction on and off-axis.
Minimised early reflections and controlled, constant directivity have another important advantage: the frequency balance of the room reverberation field is essentially the same as the direct field from the monitors. As a consequence, the monitoring system's performance is less dependent on room acoustic characteristics.
Sound image width and depth, critical components in any listening environment, are important not only for on-axis listening, but also off-axis. This accommodates not only the engineer doing their job, but also others in the listening field, as is so often the case in large control rooms.
DCW™ Technology key benefits:
  • Flat on and off-axis response for wider usable listening area.
  • Increased direct-to-reflected sound ratio for reduced control room coloration.
  • Improved stereo and sound stage imaging.
  • Increased drive unit sensitivity up to 6 dB.
  • Increased system maximum sound pressure level capacity.
  • Decreased drive unit distortion.
  • Reduced cabinet edge diffraction.
  • Reduced complete system distortion.
Όταν λέω πως είναι άχρηστα τα ηχεία χωρίς waveguide, αυτά τα παραπάνω είναι τα δεδομένα.
Δεν έχει "άψογες" μετρήσεις.
Κατά τη γνώμη μου, φυσικό και επόμενο, γιατί δεν διαθέτει ένα waveguide της προκοπής, και εμφανίζεται (αναμενόμενο) το σκαλοπάτι του κρος, το οποίο δεν διορθώνεται με eq.
Δηλαδή, το ηχείο έχει "χαρακτήρα", δεν είναι "ουδέτερο", και δεν γίνεται να γίνει.
Ηχειαρα, οκ. Αλλά δείχνει τα χρονια της. Μιαν α ανανέωση θα την ήθελε.
Deleted member 50795
δεν μας πειράζει καθόλου, είναι ATC..🙃
σύμφωνα με την εταιρεία, ο μεγαλύτερος αριθμός των πωλήσεων τους, οφείλεται στο όνομα της.:geek:
Δημητρης 777
Spendorious
Ο ''χαρακτήρας'' τους πάντως ή όπως θέλει να το πει κάποιος της συγκεκριμένης εταιρίας (και κάποιων άλλων..:biggrin:) για εμένα λειτουργεί..
Κρατάει ένα επίπεδο ''ουδετερότητας'' σε σχέση με άλλες υλοποιήσεις και το αποτέλεσμα είναι πραγματικά καλό..
Και τα έδωσα γαμώτ'.. :frown:
n_olympios
Μαντιναδόρος!
Αυτό θέλω να το δω γραμμένο. Θεωρώ απίθανο να βγήκε επίσημα η ATC (ή έστω κάποιο στέλεχός της) και να είπε "πουλάμε ηχεία μόνο επειδή είμαστε εμείς".
αν το βρω ξανά , θα το ποστάρω.
γραμμένο το είδα , πρόσφατα .
Vaslamp
