Διάφορα (Βιντεοπροβολείς)
EU regulation – no more lamp projectors from January 1st, 2026!
SPECIAL: EU regulation – no more lamp projectors from January 1st, 2026!
Published onJanuary 1, 2024 by Michael B. Rehders
The EU regulation EU 2017/852 is tough! From January 1, 2026, many products containing mercury may no longer be manufactured, imported or exported. This also applies to our beloved home theater projectors. In this special, I'll look at what exactly that means and what alternatives there are.
Photo: Michael B. Rehders - From January 1, 2026, projector lamps containing mercury may no longer be manufactured, imported or exported in the EU.
Mercury is harmful to health
Mercury is a toxic element that poses significant health risks to humans. As a neurotoxin, it causes permanent kidney and brain damage. In addition, it affects fetal and early childhood development. Therefore, it has been classified by the EU as life-threatening if inhaled, harmful to organs and the environment.
Given the dangers that mercury poses to people and the environment, the EU developed a mercury strategy in 2005, which was revised in 2010. The goal is to replace harmful mercury-containing lamps with more energy-efficient lighting alternatives. These are, for example, light-emitting diode lamps (LED).
Everything is summarized in the Mercury Regulation (EU) 2017/852.
2026 – THE END OF LAMP PROJECTORS!
Anyone who wants to buy a new projector now should be aware of this: from 2026, projector manufacturers will no longer (be allowed to) produce lamps for it. This statement refers to the EU. From this point on, no new projectors will be manufactured or imported for EU countries (such as Germany) whose built-in light source will be a UHP lamp. From now on there will be other light sources for new home cinema projectors. Namely: laser and LED.
Background: Regulation (EU) 2017/852 stipulates that from January 1, 2026, products containing mercury may no longer be manufactured, imported or exported. The European Parliament's Directive 2011/65/EU also serves to restrict certain harmful raw materials used in electronic and electrical equipment. In our case, this applies to all lamp projectors because they contain components containing mercury. Namely the UHP lamp.
Manufacturers of projectors are currently assuming that this regulation will take effect - and that no exceptions will be made.
Photo: Michael B. Rehders - The JVC DLA-NZ8 has a long-lasting laser/phosphorus light source that can continue to be used in 2026.
Manufacturers stop producing UHP lamps
In the European Union, this means for retailers and customers: Halophosphate lamps containing mercury and projectors with these UHP lamps may be sold after January 1, 2026. It's just that new lamp projectors are no longer being produced or imported. The problem I now see is that from 2026 onwards, obtaining replacement lamps for projectors will likely become problematic. As soon as the local quotas are sold out in stores (and this should happen relatively quickly), UHP lamp failures in a projector mean that the devices are essentially broken if the user has not previously bought replacement lamps in stock. How long will lamps containing mercury still be? It also remains to be seen whether the number of buyers for projectors will be produced for projectors. Production in very small quantities is unlikely to be financially lucrative.
Photo: JVC – Laser light diodes are already replacing UHP lamps at JVC. The new 4K and 8K projectors almost all use laser/phosphor. These are the current models JVC DLA-NZ7, DLA-NZ8 and DLA-NZ9. Only the JVC DLA-NP5 still has a conventional mercury lamp, which will no longer be manufactured by January 1, 2026 at the latest.
Are there alternatives?
At home you can now use LED bulbs in conventional lamp holders. I think it is unlikely that projector manufacturers will follow a similar path for older lamp projectors. When I asked some manufacturers about this, I received the following answer: There are currently no plans for such technical developments. This means: from January 2026 at the latest, manufacturers will stop producing UHP lamps and importing them to Europe.
Photo: Michael B. Rehders – How long lamps will continue to be produced outside the EU is unclear. Since projectors use different lamps (see photo), it becomes much more difficult to find a suitable model.
Conclusion
The good thing first: new projectors will continue to be available in the EU from January 1, 2026 - only from now on they will use LED and laser light sources instead of the harmful gas discharge lamps (UHP) containing mercury. Home cinema projectors with UHP lamps that are already imported and stocked in specialist retailers may continue to be sold. Then there is practically a pure sale. The same also applies to the UHP lamps. The procurement of spare parts for consumables (i.e. suitable UHP lamps) is likely to become increasingly difficult, as manufacturers and dealers will no longer be allowed to manufacture, import and export lamps containing mercury in the EU from 2026.
Δεν χρειαζόταν αυτο το περιοριστικό μέτρο/οδηγία , η πορεία και η εξέλιξη θα το έφερνε από μόνο του...
Απλά με την ανακοίνωση θα κοιτάξουν και ιδιώτες που έχουν καλούς προβολείς λάμπας να καβατζαρουν κάποιες έξτρα.
Να το θεσω αλλιως , εχεις ηδη ενα jvc laser και εχει γραψει 30.000 ωρες , αλλαξε του τον μηχανισμο laser ,συμφερει;
Θυμάμαι κάποιος το πάλευε και εδώ καμιά δεκαετία πριν - είχε πάρει φώτα λεντ από το ιμπει και προσπαθούσε να κάνει έναν συμβατικό προβολέα να δουλέψει με αυτό. Δεν πρέπει να είχα πετύχει βέβαια την κατάληξη της προσπάθειας.
Υπάρχει πλήθος προβολέων πενταετίας, δεκαετίας, δεκαπενταετίας, που προφανώς δεν απευθύνονται στους power users αλλά έχουν το δικό τους κοινό, είτε λόγω ανάγκης είτε λόγω προτίμησης (π.χ. οι HD Ready προβολείς έχουν εγγενή ανάλυση 1280χ720 κάτι το οποίο λειτουργεί εξαιρετικά για το retro gaming και δεν υπάρχει εναλλακτική για τέτοια ανάλυση, οι HD Ready τηλεοράσεις ήταν κατά κύριο λόγο 1366χ768 και κάποιες λίγες είχαν κάτι περίεργες αναλύσεις τύπου 1024χ720). Αυτές απλά πηγαίνουν στα σκουπίδια;
JOHN MARKOU
Münchhausen
Είδαμε μια τέτοια πατέντα πριν μερικά χρόνια, την είδε κι ο Καστρουνής.
Ρώτα τον αν του άρεσε. :rolleyes:
Φυσικά και δεν του άρεσε γιατί δεν είναι η ενδεδειγμένη λύση. Δεν μπορεί να αντ/σει μία λάμπα uhp ένα led.
Η τρία led ή 103 led.
Προφανώς αυτοί οι ιδιοκτήτες θα πρέπει να πάρουν καμία έξτρα λαμπίτσα όσο θα είναι ακόμα φθηνές. Όταν παραδώσει και η δεύτερη, αλλαγή προβολέα, ή μέχρι τότε, μεγάλη τηλεόραση.
Η έξτρα λαμπίτσα κοστίζει πλέον πανάκριβα αν είναι αυθεντική. Το θέμα δεν είναι οι ελάχιστοι home cinema προβολείς αλλά όλοι οι Data που κατά χιλιάδες έχουν προμηθευτεί τα σχολεία! Πιστεύεις ότι θα πάνε σε πανάκριβους Laser; Γενικώς ο φθηνός προβολέας θα εξαφανιστεί! Είναι που είναι πανάκριβοι οι καλοί, αυτό θα πάει το entry level στα 3.000 ευρώ!
billpeppas
A/V Επαγγελματίας
Καταστροφή!
100-130€ η σκέτη ορίτζιναλ λάμπα για JVC... έρανο θα χρειαστεί να κάνουν οι ιδιοκτήτες :D
(μην πεις με την βάση, γιατί είναι περιττή, και πάλι, πιο φθηνά σου βγαίνει να στην βάλει άλλος αν εσύ δεν ξέρεις/μπορείς να βάλεις σκέτη νέα λάμπα)
Καταστροφή!
Προφανώς μιλάς για αυτές τις "UHP OEM Genuine Original Lamp" δίχως το κουτί οι οποίες ΠΟΤΕ δεν έχουν την απόδοση των κανονικών! Η JVC δεν πουλάει σκέτη λάμπα. Οι 2 απο αυτές με πήγαν τις μισές ώρες και η μία έσκασε στις 500 ώρες σπάζοντας και το κουτί της. Οπότε πάλι 500ρα. Και φρόντισα να μην την ακουμπήσω καθόλου. Αύριο θα βάλω φωτο! Ίσως σε άλλους προβολείς να δουλεύουν, δεν ξέρω.
Άλλο πράγμα είναι παίρνω μια original σε oem κουτί γιατί μπορώ και είναι μικρό σχετικά το κόστος και άλλο το γεγονός, που πιστεύω έχει δίκιο ο Κώστας, ότι δηλαδή θα υπάρξει σοβαρό πρόβλημα στις χαμηλές κατηγορίες όταν πάψουν να κυκλοφορούν προβολείς με λάμπες.
Καταστροφή!
6.500 το δέρμα στο αυτοκίνητο, 500 η λάμπα στον προβολέα, όχι Κώστα, κώτσο τον πιάσανε... :biggrin:
βάλε και 100% αύξηση στο φυσικό αέριο :biggrin:
Προφανώς δεν έχετε ασχοληθεί ποτέ σας με προβολέα. Και κάθε φορά δικαιολογείτε την έκφραση: IQ...........
Μιλάς σε κάποιον που αποσυναρμολογούσε εννιάιντσο CRT (έχεις δει ποτέ σου;), έφερε τον πρώτο 1080p στην Ελλάδα, τον πρώτο Dila, τον πρώτο επεξεργαστή DUNE και του κάνεις και μάθημα. Έ ρε γλέντια !!!!
Δε μιλάμε για παιχνίδι, για κανονικό προβολέα DATA μιλάμε να μπορεί να παίξει με φώτα και δίχως συσκότιση, έτσι είναι στα σχολεία και σε παρουσιάσεις γραφείων. Με decent ποιότητα εικόνας. Εκτός αν νομίζεις ότι ένας κινέζικος προβολέας των 280 ευρώ με ηχεία είναι κανονικός. Θα είχαν όλοι τότε από 2 αντί να τα χώνουν σε τηλεοράσεις.
Όσοι μεγάλωσαν με view-master ίσως μπορούν να ανεχθούν τέτοια εικόνα. Όσοι κάνουν παρουσιάσεις σε ακροατήριο και θέλουν να φαίνονται καθαρά τα μικρά γράμματα, άρα μιλάμε για πάνω από 2500 Lumens και υψηλή ανάλυση, όχι.
Και στα 3.000 αναφερόμουν σε αντίστοιχο αξιοπρεπή Home Cinema προβολέα που σήμερα βρίσκεις με 1500-1800 ευρώ. Το πρόβλημα βλέπεις των LED είναι η πολύ χαμηλότερη φωτεινότητα σε σχέση με τους Metal halide and UHP.
10 χρόνια με benq w1070 άλλαζα σκέτη λάμπα χωρίς βάση με 50-55€ κανένα πρόβλημα ποτέ σε πάνω από 10 λάμπες.τωρα με Epson 9400 άλλαξα την πρώτη με 130€ μόλις λήξει η εγγύηση πάλι σκέτο bulb θα αλλάζω.και παίρνεις φουλ φως σαν την πρώτη μέρα!με το laser τι φώς χάνεις με την χρήση; εγώ παίζω 4000 ώρες το χρόνο αν σε δύο χρόνια έχω το μισό;;;
Είχες 2000 ANSI Lumens και 10,000:1 High Contrast Ratio σε φουλ specs. Με σωστή ρύθμιση τα μισά! Με Epson πήγες στα 2600 με πολύ καλύτερο contrast. Μιλάς για σχετικά χαμηλής κατηγορίας προβολείς, μέτρησες ποτέ φωτεινότητα: με νέα λάμπα, 300 ώρες, 1000 ώρες, μισή ζωή λάμπας; Εκεί θα καταλάβεις τη λάμπα. Αν πάς στο μισό σε οποιαδήποτε από τις προηγούμενες φάσεις, τότε κάτι πάει λάθος! Όσο γρηγορότερα φθίνει φωτεινότητα, τόσο χειρότερη είναι η ΟΕΜ λάμπα.
Και φυσικά αν σκάσει κάποια κινεζιά, τότε πάνε τα πάνελ!
nikpapageo
