Κατάργηση του πολυπριζου και των συν αυτώ.
την εγγενη κατευθυντικότητα της ροης ηλεκτρονιων
Απ'το βουνό κατέβαινα, και στην κορφή κανέλα.
Τι ειναι το "waveforming"?
Τρόπος ψησίματος μπριτζόλας.
Κι ομως ετσι λενε οτι ειναι, η mitsubishi το βρηκε στο ερευνητικό της κεντρο. 50€
Certainly. Let me provide a recap, recommendation, and alternatives for a proper high-fidelity two-channel system, along with a final summary and assessment.
Recap:
1. RT60 (Reverberation Time 60) is less critical in home environments compared to professional spaces, but balanced room treatment is beneficial.
2. Wave forming technology, like that developed by Trinnov, can significantly improve room acoustics and system performance.
3. Effective wave forming typically requires a minimum of four subwoofers for optimal results.
Recommendation for a proper high-fidelity two-channel system:
1. Speakers: High-quality full-range speakers or a combination of main speakers with subwoofers.
2. Amplification: Separate high-quality preamplifier and power amplifier, or a top-tier integrated amplifier.
3. Source: High-resolution digital source (e.g., network streamer) and/or a good quality turntable for analog.
4. Room treatment: Basic acoustic treatments (diffusers, absorbers) to manage reflections and standing waves.
5. Room correction: Consider a system like Trinnov, Dirac Live, or Anthem Room Correction (ARC).
6. Subwoofers: While not strictly necessary, 2-4 subwoofers can significantly enhance bass performance and overall system balance.
Alternatives:
1. Traditional approach: Focus on high-quality main speakers, careful room placement, and minimal electronics without room correction.
2. DSP-based systems: Use of digital room correction built into receivers or standalone processors (e.g., miniDSP).
3. Active speakers: All-in-one solutions with built-in amplification and sometimes room correction (e.g., Dutch & Dutch 8c, Kii Audio Three).
Are subwoofers necessary?
Subwoofers are not strictly necessary for a high-fidelity two-channel system, especially if using full-range main speakers. However, they can offer several benefits:
1. Extended low-frequency response
2. Reduced distortion in main speakers by offloading bass
3. More flexible placement options for optimizing room response
4. Potential for more accurate bass through multi-sub setups and room correction
Final Summary and Assessment:
A proper high-fidelity two-channel system should aim for accurate reproduction of the original recording, taking into account room acoustics. While traditional approaches focusing on high-quality components and careful setup can yield excellent results, modern room correction technologies offer powerful tools to overcome room-related issues.
The necessity of subwoofers depends on personal preference, room characteristics, and main speaker capabilities. For those seeking the highest level of performance, especially in bass response and overall system integration, a multi-subwoofer setup (2-4 subs) combined with advanced room correction like Trinnov's wave forming technology can provide exceptional results.
However, it's important to note that such advanced setups come with increased complexity and cost. For many listeners, a well-chosen pair of full-range speakers in a treated room can provide a highly satisfying listening experience without the need for additional subwoofers or complex room correction systems.
Ultimately, the best system is one that meets your personal preferences, budget, and room constraints while providing an engaging and accurate listening experience. Audition different setups if possible, and consider starting with high-quality main components before exploring advanced room correction or multi-sub setups.
Decembered
Μαϊμού
Εκείνο το 8 είναι αμφισβητησιμο αν είναι έκφραση των καλλιτεχνών η των τεχνικών.Τελος πάντων,αρκετοί δικοί μου καλλιτέχνες προτιμούν το mono και οι υπόλοιποι το stereo οπότε γλύτωσα.
Byrds:Younger than yesterday
Tim Buckley:Goodbye and hello
Music Machine:Turn on
West Coast Pop Art Experimental Band:part one
Pretty Things:Get the picture?
Electric Prunes:S/T
Downliners Sect:The rock's sect in
Ugly Ducklings:Somewhere outside
Kinks:Kinda Kinks
Kaleidoscope:Tangerine dream
Rising Storm:Calm before
Yardbirds:For your love
Standells:Dirty water
... οι μισοι απο αυτους λαμβαναν lsd...γιατι δεν τους εφτανε να την ακουν στερεοφωνικα. 🐒
Decembered
Μαϊμού
....οι ιδιοι οι καλλιτεχνες πσοφαγαν για στερεοφωνικα εφε τοτενες....σημερα θα επιδιωκαν αντιστοιχα immersive εμπειρια.
-> η διαμορφωση (μουσικου) κινηματικου-και-φορματ (απο την αρχη και μεχρι σημερα, αδειαλειπτως) προερχεται απο μη εμπορικα ειδη, και απο ειδη που δεν αποτελουν μερος της μουσικης βιομηχανιας.
Π
Π.Α.Η.
Διαφωνώ.Οι καλλιτέχνες ήταν οι μόνοι αμέτοχοι όπως είναι και σήμερα.
Λοιπόν.Αφηστε με τώρα να κοιμηθώ για να χορτάσω ύπνο γιατί αύριο το πρωι κανόνισα να πάω να πάρω ένα πολυπριζακι για δοκιμή.Οντως.
Decembered
Μαϊμού
οι καλλιτεχνες ειναι το κοινο τους
-Dec.
.... εφοσων διαπραγματευεσαι υπσηλη πιστοτητα και πχοιοτητα αναπαραγωγης, εχεις και τον αντιστοιχο αντιλογο, και χανεις και το δικιο σου αν τυχων εχεις.
Σε κανενα δε καιγεται κανενα (βιζμα) καρφακι αν ακους απο μονοκαναλο ή αν τα καλωδια ή και τα ηχεια σου ακομα κοστιζουν τα 10πλασια και τα 100 πλασια.
Και κατι τελευταιο, αν δινεις αξια στο ηχοσυστημα, τοτε κοινο μυστικο οτι εχεις θεματα αλλου τυπου, μπορει και στενης επαφης....τριτου τυπου.. 🐒
Π
Π.Α.Η.
-Dec.
Δε φαντάζεσαι τι διαφορές ακούω ακόμα και σε μονοφωνικες εγγραφές.Δεν είμαι μόνος.Εχω μαζί μου μεγάλο μέρος της Γερουσίας των δοκιμαστών ανά τον κόσμο.Κυριως οι Αμερικανοί που έχουν και παράδοση στη μουσικη που ακούω,δοκιμάζουν σύμφωνα με τη μουσική που τους αρέσει.
Decembered
Μαϊμού
.....ηταν ενας Λιαμ , που εκανε ερωτα σε μια λυχνια.
ηταν και ενας Δημοσιογραφος που εκανε με παλμογραφο.
(παραδοσιακο λογοτεχνικο αμερικανικο στιχακι)
Recap:
Alternatives:
Ποιος τα λεει αυτα ?
Π
Π.Α.Η.
Το δεύτερο είναι πολύ ύποπτο.Πρεπει να μάθω ποιος είναι για να μην τον ξαναδιαβάσω!
εγώ την ακούω μια χαρά , τι εννοείς ?
δεν βγαίνει εύκολα από εμένα ή από εσένα ;
Οταν το τραγουδάμε στο μπάνιο ;
Οταν παρεις καλυτερα καλώδια θα καταλαβεις /s 😄
Ε, θα φταίνε τα καλώδια. 🤪😁
Αυτο λεω! Χαχαχα
(μειώνεται το intermodulation distortion )
Εχεις κάποια μέτρηση που δειχνει η..? Δεν το λεω για να το παιξω απο πανω και μαγκας απλα αναρρωτιέμαι πως εψτασες σε αυτο το συμπερασμα :)
Δημητρης 777
Spendorious
Για να βάζεις εσύ και το Ταφ στη μπριζόλα πρέπει να 'ναι πολύ βαρύ ποπόνι το waveforming.. :roflmao::tongue:
Αμφιβολία διακρίνω.. :rolleyes:
Τι θα δοκιμάσεις απ΄το πολύπριζο καλέ? :idk:
ΕυτυχιΖμένος κουφός χίλιες φορές.. (για 'μένα λέω..):smoke:
Άσχετο..
Ρε 'σεις φχαριστηθείτε ότι έχ' ο καθένας (ότι λόξα έχει εννοώ.. :cry:), μην στεναχωρείτε τη μαιμού..
Θα φάει πάλι.. :o
Θα γίνει στρουμπουλή μαιμού.. :tongue: :whistling:
αύριο έχει δοκιμή πολυπριζων
Ωωωωω, αυτά είναι!
Δοκιμή πολυμπριζου.
Τι ωραία.
Μετά λέτε για το '60 που έπαιρναν LSD, λες και τώρα τι άλλαξε;
Π
Π.Α.Η.
Ωωωωω, αυτά είναι!
Δοκιμή πολυμπριζου.
Τι ωραία.
Ότι πωλείται πολυκάναλο!Μόνο με παραισθησιογόνα ακούγονται έτσι τα όργανα.Psychedelic trip.
hatzopou
