Κουνουπια
Επανέρχομαι (από τη σελίδα του προϊόντος στο indiegogo):
  • It can effectively identify and strike mosquitoes with a flight speed of no more than 1meter/s and a size characteristic of 2~20mm.It can also effectively strike other flying insects within this characteristic range such as sand flies and fruit flies.
  • However, its efficacy on house flies and similarly fast-moving insects is significantly diminished. If the professional version of the product is utilized and the scanning angle is adjusted from the maximum of 90 degrees to 45 degrees, it may present a certain level of threat to house flies, particularly when they are not flying at high speeds.
How safe is the product? Will it cause harm to humans or pets?
1. We use Lidar to identify mosquitoes. When the laser radar is working, it can precisely identify the size of objects . When there are only objects smaller than 2 centimeters within the range, it will consider them as the target for attack and can shoot; when there are objects larger than 2 centimeters in the range at the same time, it will not shoot under any circumstances. When people and pets enter, they will be identified within no more than 2 milliseconds, which is very fast and accurate.
2. When the laser radar identifies the target object, it will conduct multiple careful identifications at the specified angle. It will only proceed with the shooting after confirming that all the identified data meet the requirements. If there is any incorrect data, it will exit the identification and re-identify. Therefore, using laser shooting requires very high requirements to ensure that the target is completely correct.
3. This product is also equipped with millimeter-wave radar. The recognition range of the MMW radar is larger than that of the Lidar .It can only identify larger objects within 10 meters, such as people and pets like cats and dogs. It cannot identify very small things like mosquitoes and flies. when it identifies a larger object approaching, it will prematurely disable the shooting function to ensure sufficient safety. Moreover, the MMW radar can also identify people who are sleeping.
Mr Spock
demokratischer - sektor
- είμαι στο Αλιβέρι για ένα σφηνάκι διακοπών , το ευχάριστο αλλά και ανεξήγητο συνάμα , και που κουβεντιάζουν οι ντόπιοι , είναι η απουσία κουνουπιών μυγών και λοιπών εντόμων σε σχέση με άλλες χρονιές, αραιά και που καμιά μέλισσα , ο καιρός είναι ζεστός και υγρός ... και όντως χθες βράδυ πέρασα στο μπαλκόνι αρκετή ώρα διαβάζοντας και τίποτα δεν πετούσε
- πάει πουθενά ο νους σας ; Ψεκασμοί ή κάτι σχετικό ; ... καί εάν ψεκασμοί , δεν θά τό ήξεραν οι μόνιμοι κάτοικοι ;
... Είχε μια μικρή πυρκαγιά πρόσφατα , αλλά τίποτα το εκτεταμένο
melina
Cargo 200
Εχω μείνει με την εντύπωση ότι το "φονικό όπλο" ήταν διαθέσιμο μόνο μέσω Αμερικής.
Τώρα το βλέπω και με ευρωπαικό site.
melina
Cargo 200
Εχω βαλει το Link εδω και καιρο στο καταλληλο νημα
Κάτι υπήρχε αμυδρά ως μνήμη αλλά δεν ήμουν σίγουρος.
Το καλό με το alzheimer είναι οτι βιώνεις ξανά και ξανά νέες (τις ίδιες) εμπειρίες και περνάς καλά :roflmao: :roflmao: :roflmao:
Mr Spock
... Τελικά πρέπει να ψεκασαν λένε
Άρα κάποιοι έχουν δέρμα που δεν τρυπιέται από κουνούπια...
Για τους υπόλοιπους, μια πανοπλία ίσως θα ήτο μια κάποια λύσις...
roberto_portale
