Windows 11
πες λεπτομέρειες. Συμβαδίζουν με αυτά που έχουν αναφερθεί από άλλους χρήστες;: "
This issue was first reported last week by a Japanese PC builder who saw SSDs disappear from the OS during heavy write operations (like writing large files or many files at once) to drives that were over 60% full on devices with the KB5062660 preview update or this month's Windows 11 24H2 security update installed.
Other users have encountered the same issue on systems with Corsair Force MP600, Maxio SSD, SanDisk Extreme Pro, Kioxia Exceria Plus G4, Kioxia M.2, and various other drives with Phison and InnoGrit controllers.
A spokesperson for NAND controller maker Phison also shared a statement with BleepingComputer on Wednesday, saying that the company is "working with Microsoft to resolve the issue."
"Phison has recently been made aware of the industry-wide effects of the 'KB5063878' and 'KB5062660' updates on Windows 11 that potentially impacted several storage devices, including some supported by Phison," a Phison spokesperson told BleepingComputer.
"We understand the disruption this may have caused and promptly engaged industry stakeholders. [..] At this time, the controllers that may have been affected are under review and we are working with partners."
Until the issue is addressed, Windows users should avoid writing large files (tens of gigabytes) and extract large compressed files with many items (e.g., 200 files of 200 MB each) in several steps rather than all at once.
Δεν κράτησα screenshots γιατί δεν φαντάστηκα το χαμό που ακολούθησε.
Εν ολίγοις, ξεκίνησε πριν λίγες μέρες να κάνει το τελευταίο update, και στο τέλος έβγαλε ένα μύνημα του στυλ "κάτι δεν πηγε καλά με το update, δεν χρειάζεται να ανησυχείτε, γίνεται roll-back"
Το επόμενο μύνημα ήταν "δεν ήταν δυνατόν να γίνει roll-back, πρέπει να γίνει επανεκκίνηση"
. . . και δεν ξεκίνησε ποτέ. Corrupted MBR. Repair δοκίμασα, τίποτα. Μέσω cmd δοκίμασα, πάλι τίποτα. Ξανά και ξανά και ξανά....τίποτα.
Δοκίμασα με usb stick να μπω και να τα εγκαταστήσω από πάνω, τίποτα.
Τελικά έκανα νέα εκγατάσταση. Έσβησα όλα τα προηγούμενα partitions και ξεκίνησα από το μηδέν,
Εδώ και 2 μέρες είναι ΟΚ φαινομενικά και έχει κάνει όλα τα updates
Mbr στα win11? Παλιος υπολογιστης που δεν εχει τυπικες προδιαγραφες για win11?
Στους υπολογιστες δουλειάς εχω απενεργοποιησει τα αυτοματα updates για καμια 30ρια χρονια και κανω επιλεκτικα οποτε θελω. Τα υπολοιπα τα εχω για πειραματοζωα
5ετίας dell precision. Είχε WIn10 pro όταν το πήρα και ήταν υποτίθεται certified για Win11.
Αν παραδεχτουν το προβλημα, θα πρεπει να αρχισουν τις αποζημιώσεις οπότε ενεχομενως ψαχνουν πως να μειωσουν το πιθανο κοστος. Απο τη στιγμη που δεν μπορεις νομιμα να κοψεις τις ενημερωσεις, δεν μπορουν να ρίξουν μέρος της ευθύνης στο χρηστη/διαχειριστή.
Θα δουμε το πορισμα της ms και των κατασκευαστων controllers που εχει ηδη αργησει.
xfader
Το είδα κι αυτό...
Έκανα πριν λίγο update το BIOS της μητρικής. Είχα φύγει από το δωμάτιο μέχρι να ολοκληρωθεί κι όταν γύρισα είδα ότι είχε γίνει το boot και είχε μπει στα Windows χωρίς να ζητήσει το 8ψήφιο PIN που έχω ορίσει.
Σε χακάρανε.
Ένας Θεός ξέρει τι θα σου συμβεί από δω και πέρα....
Καλή τύχη...
ΝΑ ΜΕΤΑΝΟΗΣΕΙΣ ΕΥΘΥΣ ΑΜΕΣΩΣ, ΑΠΙΣΤΕ!!!! Το PC του @xfader είναι απροστάτευτο!!!! ΔΙΑΔΩΣΤΕ!!!11!!11!!1!!!
Το είδα κι αυτό...
Αυτό κι αν είναι καρακενό ασφαλείας...
Παρόλα αυτά δες κάτι:
  1. Windows Hello PIN isn’t stored in the BIOS/UEFI – it’s tied to your Windows user profile and TPM (Trusted Platform Module). Updating the BIOS can reset certain security-related configurations, including TPM state.
  2. TPM reset or reinitialization – if the BIOS update cleared or re-provisioned the TPM, Windows might temporarily fall back to cached credentials or default to automatic login if "automatic sign-in after update/restart" was previously enabled.
  3. Windows Fast Startup / Credential Caching – if "use my sign-in info to automatically finish setting up my device" is enabled (Windows feature), the system may log you in automatically after updates, including a BIOS update.
  4. Local Account Auto-Login – if someone configured auto-login via netplwiz or registry before, the BIOS update might have triggered that behavior instead of enforcing the PIN.
  5. Fallback to Password Instead of PIN – if the PIN became invalid due to TPM change, Windows sometimes silently switches to the stored account password if available.
Private profiles of sexy women ready to chat live
***link removed***
***link removed***
Α να χαθείς μας κάφλωσες βραδυνιάτικα κωλόμποτο.
@daharis666 τζάστονε ρε :D
Περα από την πλάκα μή πατήσει κανείς το λινκ και κολλήσει καμια ψύρρα... Δε ξέρουμε τί είναι και δε χρειάζεται και να μάθουμε.
στο νήμα για τα γουίντοουζ βρήκε να τα βάλει? άλλη μια κινεζιά :biggrin:
xfader
  1. Windows Fast Startup / Credential Caching – if "use my sign-in info to automatically finish setting up my device" is enabled (Windows feature), the system may log you in automatically after updates, including a BIOS update.
Βρέθηκε ο ένοχος.
Το αξιοσημείωτο είναι ότι έχω κάνει πάνω από 5 bios updates στο ίδιο σύστημα (από τον Μάρτιο που το έστησα) και πρώτη φορά συνέβη. Μπορεί να άλλαξε κάτι στη συνεργασία του BIOS με τα Windows.
minas
Πισιά
Βρέθηκε ο ένοχος.
Ενημερώσεις του BIOS μέσω του Windows update, συμπεριφέρονται ως "κανονικά" Windows updates. Μεταξύ άλλων δεν απαιτούν σύνδεση ρεύματος για να γίνουν, όπως μπορεί να γινόταν πχ με την εφαρμογή του κατασκευαστή, ενώ τηρούν την ρύθμιση του credential caching.
Σημείωση: Εάν κάνεις χειροκίνητη επανεκκίνηση σε αντιδιαστολή με την αυτόματα προγραμματισμένη, έχει διαφορετική συμπεριφορά το auto sign-in.
xfader
Τα BIOS uodates τα κάνω πάντα από το μενού του BIOS με αποθηκευμένο το αρχείο που κατέβασα σε συγκεκριμένο φάκελο ενός εσωτερικού SSD.
xfader
Δεν έφταιγε η Microsoft!
Τις τελευταίες εβδομάδες κυκλοφορούν αναφορές ότι οι πρόσφατες ενημερώσεις των Windows 11 (KB5063878 και KB5062660) προκαλούν προβλήματα σε SSD δίσκους με ελεγκτές Phison, οδηγώντας σε αποτυχίες λειτουργίας. Πολλοί χρήστες και δημιουργοί περιεχομένου στα social media κατηγόρησαν τη Microsoft, αλλά η Phison διευκρίνισε ότι το πρόβλημα οφείλεται σε πρώιμες εκδόσεις firmware και BIOS, που δεν αντιστοιχούν στις τελικές εκδόσεις που διατίθενται στους καταναλωτές.
LefterisG
