BLUES
TV
Καλησπερα στην μεγαλη παρεα
Λογω διαλυσης του συστηματος προσφερετε ενα κορυφαιο usb καλωδιο 1 m ,απο την Σερβικη μπουτικ εταιρεια Way cables-το Libertas
Χωρις συσκευασια,σε αψογη οπτικη και λειτουργικη κατασταση
www.waycables.com/digital-audio-cables/
LIBERTAS provides a realistic presentation of instruments and voices with impressive sound resolution and fullness. It acts like it defogs a sound image, so the music materials become more transparent, spacious, and natural than we used to hear via a USB link.
With its features, LIBERTAS sets a new quality standard for WAY Cables for transferring the highest resolution music files and supporting audio electronics to perform maximum results by converting digital data to analog music over the USB connection.
LIBERTAS makes substantial sound improvements thanks to a newly developed Unique Xtreme Damping design solution for USB cables UXD3.1-WAY with interlinked shieldings for signals and grounding, separately isolated power.
Besides novelties inside, the LIBERTAS USB cable has a finish comprised of thick Pure Cotton overbraided with white glass fibers COTFIB-WAY™. This lightweight yet long-lasting material effectively dissipates micro-vibrations on the cables’ surfaces and creates a unique outlook.
Cable name: LIBERTAS
Type: Digital audio USB cable, profile 2.0, A to B plugs
Design: UXD3.1-WAY™ / Unique Xtreme Damping System from vibrations and electrical interference. The solution for USB cables with interlinked shieldings for signals and grounding, separately isolated power.
Conductors: EQL-WAY™ / Identical solid-core wires
Material: 5N Single Crystal Silver
Signals (Data+ & Data-) gauge: 16.48 AWG / 1.17 mm² in total
Power & Grounding gauge: 17.71 AWG / 0.88 mm² in total
Insulation: COT-WAY™ / Pure Cotton with 1.3 dielectric constant
Shielding: Pure Copper braid and 5N solid-core Silver wires
Plugs: USB connectors with Gold-plated HQ Copper alloy contacts and housing, customized by WAY Cables / CUST1-WAY™
Soldering: Lead-free with a high percentage of Silver
Finish: COTFIB-WAY™ / Red thick Pure Cotton overbraided with white glass fibers
Marker: Engraved natural bamboo
Outer diameter: cca. 22 millimetres
Production: FNICA-WAY™ / Genuinely handmade in Serbia with quality control through all the stages of making, assembling and testing
Burn-in time: >100 hours
www.listening-sessions.com/produit/way-cables-libertas/
www.hifigroov.be/cable-usb/650-way-cables-libertas.html
www.hifiroma.com/cavi/p/waycables-digital-usb-libertas
Τιμη λιανικης 2190 ε-------------- τιμη προσφορας-------900 ε
Οχι ανταλλαγες
Επικοινωνια με πμ η τηλ στο 697 467 2617
Αποστολη στην επαρχια με κουριερ επιλογης και χρεωση δικη σας
Ευχαριστω για την φιλοξενια
Οχι ανταλλαγες
