Pioneer: Oι πρώτοι HD audio compatible πολυκάναλοι
Κώστας Φ.
Pioneer has announced a range of new AV receivers for the summer. Top of the range and compatible with the latest HD audio formats is the 1080p-ready VSX-LX50. A seven channel, 150 watt model, it will be the first Pioneer to offer onboard Dolby TrueHD and DTS HD Master Audio decoding. It can also be hooked up to an iPod and boasts a USB port for PC/ memory stick connectivity.
With an eye to the future, the LX50 can also networked via Ethernet and is DLNA (Digital Living Network Alliance) compliant. Price TBA.
It will be joined by the VSX-417, the VSX-817 and the VSX-917AV.
VSX-LX50 specifications:
1080p ready AV multi-channel receiver; 7-ch 150W. HDMI 1.3 (2 in, 1 out), USB; Dolby TrueHD, DTS HD Master Audio; iPod audio/photo/video ready; Advanced MCACC with 9-band EQ; Standing Wave Control; Front Stage Surround Advance; Phase Control; Sound Retriever
VSX-1017AV specifications:
1080p ready AV multi-channel receiver; 7-ch 150W. HDMI 1.3 (2 in, 1 out), USB; iPod audio/photo/video ready; Advanced MCACC with 5-band EQ; Front Stage Surround Advance; Phase Control; Sound Retriever
VSX-917V specifications:
1080p ready AV multi-channel receiver; 7-ch 150W. HDMI 1.3 (2 in, 1 out), USB; Auto MCACC with 5-band EQ; Front Stage Surround Advance; Phase Control; Sound Retriever
VSX-817 specifications:
AV multi-channel receiver; 7-ch 110W; USB (no HDMI); Auto MCACC with 5-band EQ; Phase Control; Sound Retriever
VSX-417 specifications:
AV multi-channel receiver; 5-ch 110W; USB (no HDMI); Phase Control; Sound Retriever
homecinemachoice.com
Παρα πολυ ωραια. Ξερουμε τιμες για τα μεγαλα μοντελα?
Χαθηκε ομως να βαλουν ενα παραπανω hdmi in...
Εμενα ο 917 μου φαινεται αριστη αγορα αν εχει καλη τιμουλα
7.1 ειναι , τα καινουρια codecs τα υποστηριζει, hdmi 1.3 εχει (εστω και 2 μονο), και 150W ανα καναλι επαρκη φαινονται για ενα χαμηλο-μετριο συστημα. Απο υποστηριξεις λοιπον ειναι jet απο κει και περα αμα σε καποιον δε φτανει η δυναμη του, τα hdmi του κλπ ας παει σε πιο hi-end (ισως επρεπε ο 1017 και οι πιο πανω να εχουν πιο πολλα hdmi).
Παντως μπορω να ρωτησω γιατι θελετε πολλα HDMI? εκει που εχουν παει τα πραγματα με τις πολυσυσκευες, και 1 θα μου εφτανε συνηθως. Δηλαδη παιρνεις ενα PS3 και παιζεις blueray/dvd/games με 1 HDMI , τι αλλο θα συνδεσεις? Αντε και ενα hd-dvd player στο δευτερο....τι αλλο?
Τον 917 τον εχει ενα μαγαζι στο skroutz στα 417 ευρω....not bad νομιζω , ισως παιξει και φτηνοτερα οταν τον φερουν πιο πολλα. Α και εχει 110W ανα καναλι (οχι οπως λεει στο πρωτο post στα specs)....λογικο, τα 150 φανηκαν πολλα και θα ειναι μονο στον 1017.
EDIT : Επισης μολις ειδα οτι δεν εχει αυτος trueHD και DTS-HD υποστηρηξη :( κριμας....αυτος ηταν και ο βασικος λογος που χαρηκα.
Αν παρουμε την υποθεση εργασιας ενος "αρρωστου" γκατζετακια (εγω προσωπικα... δεν ξερω κανεναν τετοιον) εχουμε ηδη τις εξης συσκευες με HDMI:
PC
Δορυφορικος δεκτης
Upscaling DVD player
ΧΒΟΧ 360
Blu-Ray
δορυφορικο δεκτη τον βαζεις με component, ουτως ή αλλως μεχρι 1080i παει και δεν ειναι και η απιστευτη εικονα του δορυφορικου να νιωσεις οτι χανεις κατι. Το upscaling dvd player δε το χρειαζεσαι αν εχεις xbox360. Αληθεια εχεις προμηθευθει απο αμερικη το xbox360 elite που εχει HDMI? Φανταζομαι πως οχι...αλλα οκ καποτε θα γινει και αυτο. Αρα τελικα θελεις 3 HDMI για PC-xbox-bluray , οκ θα σου λειπει 1 , αλλα δε χαθηκε ο κοσμος οποιο απο τα 3 χρησιμοποιεις πιο σπανια να το εχεις αποσυνδεμενο και να το βαζεις προσωρινα.
Anyway καλο θα ηταν να εχει παραπανω απο 2 inputs αλλα κυριως στα ψηλα μοντελα, γενικα δε το βλεπω μεγαλο μειονεκτημα, καλυτερα που ειναι version 1.3 παρα να ηταν 3 και version 1.2.
Αποτι ειδα ο VSX-LX50 που ειναι ο μονος που υποστηριζει τα νεα codecs παιζει στις 620 λιρες = 900 ευρω στην Αγγλια. Οχι και ασχημη τιμη... Αντιστοιχα μοντελα απο Yamaha/Denon με τα νεα codecs εχουν βγει?
Ρε παιδια, τι λεμε τωρα. Ειμαστε στην εποχη του HDMI και οι εταιριες τσιγκουνευονται δυο-τρεις θυρες παραπανω, των οποιων το κοστος ειναι 50 ευρω, αντε 100.
Κώστας Φ.
Απάντηση: Pioneer: Oι πρώτοι HD audio compatible πολυκάναλοι
Κι αυτοί που πουλάνε HDMI switch κλέφτες θα γίνουν? :mrgreen:
Ο LX70 θα ειναι πολυ ακριβος....το ενδιαφερον για μενα συγκεντρωνεται στο ποσο θα κοστιζει ο LX50 που ειναι ο μικροτερος με HD audio support....ποσο γρηγορα θα πεσει η τιμη του και τι θα κανουν οι ανταγωνιστες (yamaha, denon).
Απάντηση: Re: Pioneer: Oι πρώτοι HD audio compatible πολυκάναλοι
αν και πολυ ευχαριστημενος, μολις πριν απο 3 βδομαδες αγορασα τον 1016. Αν το ηξερα ισως περιμενα λιγακι...:happy_2:
αντε να βγαινουν κ πιο πολλοι τιτλοι σιφγα σιγα!!!
:bravo: :happy_4:
απ'οτι λενε και στη γερμανια περιπου 1000ευρω θα παει το μαλι για τον lx50...
επισης τα lx60 & lx70 εκτος απο μια εξτρα HDMI εισοδο, θα εχουν εισοδο δικτυου ειτε για συνδεση με υπολογιστη ειτε κατευθειαν με ρουτερ για ιντερνετ... (streaming, etc)
γνωριζει κανεις αν εχουν γραφικο (ή εστω απλο) μενου στις βιντεο εξοδους τους για να μην δουλευεις με τη δυσχρηστη οθονουλα των ενισχυτων...? wall_1
Jiovani75
