Quad 22L
Κώστας Φ.
The 22L is the top of the line, featuring three drivers in a ported compact tower cabinet, a 6 1/2″ bass unit, an identical looking bass/midrange driver, and a 1 1/2″ soft dome tweeter. Crossover points are specified at 150 and 3 kHz. The enclosures are bi-wired, with high quality gold plated binding posts that accept spades or bananas, and come with substantial gold plated rods between them (for those who do not bi-wire), and those pesky little plastic plugs in the banana holes, thanks to IEC paranoia. Power handling is specified at 300 watts max, and nominal impedance 6 ohms, with sensitivity at 89 dB.
The cabinets are beautifully finished, and the Quad web site describes the process: The lustrous piano finish is applied to each speaker by hand over a period of seven days, each of which involves a coating of lacquer which must then dry at an ambient temperature before being cut and polished. The final coat is polished to a high gloss finish to produce one of the finest finishes seen on any loudspeaker in this class.”
“The 22L is the flagship of the range. This tall, floorstanding model with ultra low distortion twin KEVLAR drivers produces a fast, dynamic bass, extending to around 30 Hz at the lower end for real impact and a compelling sense of scale. Bass detail is excellent, tracking precisely every nuance of the deepest double bass, while maintaining an area of open space around instruments.” The cabinet is rear ported just above the binding posts at bottom.
“The tweeter fascia plate is engineered for a smooth frequency response and excellent dispersion. This is further aided by the flush mountings of this plate and the bass/mid unit into the cabinet front baffle.” “A profiled phase plug provides additional cone axial rigidity and also improves off-axis performance.”
”Phase coherency is particularly important to ensure the bass integrates perfectly with the treble, and, of course, to create a truly holographic stereo image - the hallmark of a classic Quad sound. This tweeter is so controlled; [that] it measures typically less than 1% distortion from 103dB (equivalent to normally loud playback) output at a distance of 1 metre.”
All that revealed (and claimed), it seems a good time get to the measurements, which are, in a word, spectacular. Virtually a straight line from 200 to 10,000 Hz, frequency response rolls off gently above and below after a very mild hump from about 190 down to 70 Hz. From there down, it slopes smoothly, down 2 dB at 50, and 5 dB (relative to 1 kHz) at 30, with appreciable response at 20 Hz. Up top, we see a smooth rolloff above 10 kHz, off 4 dB at 15, and 10 dB at 20 kHz. A little bit of character is offered in a 2 dB treble rise between 5 and 8 kHz on axis, but this smooths at 15 degrees and a controlled rolloff occurs beyond 30 degrees off axis. You might say that this is a very British speaker in its sound, with only that slight hint of upper class assertiveness, and a bit of public school mellowness of voice….rawther like the announcers (or programme presenters) on the Beeb’s Third Program. Ahem.
Impedance varies somewhat more than frequency response, reaching 5 ohms on either side of the single bass peak at about 17 ohms, and jumping to 19 ohms at 1.5 kHz. It dips to 4 1/2 ohms at high frequencies, suggesting a stable amplifier be utilized (”no singleended valves, please, Charles”). The phase angle through crossover, seen below impedance, goes from +20 to about -47 degrees, a little more than one might like in a speaker otherwise this excellent, but let’s move to its effect on imaging, as we turn to the listening tests.
The first impression was of size: they presented the biggest soundstage I’ve ever heard in such a modestly sized tower, seamless from top to bottom, with very clean, articulate bass almost into the feeling range. I suppose the Totem Mani2 comes to mind mind in a similarly sized, but differently shaped cabinet. Because the deepest bass is down in level, though still there, they can still benefit from a subwoofer, or at the very least, judicious placement for best deep bass reinforcement.
I did find that upper mid edge a little wearing after the smoothness of the 1.8s in this critical region, and I think the Energy metal dome tweeter is faster than the Quads’ silk dome in terms of transients, but these are small quibbles in the presence of a great speaker that definitely belongs in the tradition of the ESLs’ excellence over many decades.
These speakers are worth every penny of their price, manufactured and perfectly finished in China as they are, and clearly designed by the experienced and talented engineers at Quad Electroacoustics of Huntingdon, Cambridgeshire, England. If you can’t get them in Canada now, don’t despair. I’m sure that situation will change soon.
Full Review: audio ideas guide
Κώστας Φ.
Απάντηση: Quad 22L
Tα έχω ακούσει και όντως είναι πολύ καλά. Τεράστιος ήχος. Πάντως μην τα αγοράσετε πριν ακούσετε και τα μικρότερα 21L (με μία μονάδα 6.5'' για bass/midrange αντί για δύο που έχει το 22).
Παρόλο που η διαφορά τιμής ήταν μικρή, μετά απο συγκριτική ακρόαση, κατέληξα στα 21. Εκ των υστέρων που κοίταξα στο internet είδα πως δεν είμαι ο μόνος που προτιμάει τον ήχο του μικρότερου μοντέλου. :cool_4:
n_olympios
Μαντιναδόρος!
Μία από τις περιπτώσεις όπου less is more, έτσι Κώστα?
Οι σχεδιάσεις 2 δρόμων είναι γενικώς ευκολότερες στην υλοποίηση από αυτές των 2,5 δρόμων (ή 3 πιο σπάνια).
Κώστας Φ.
Απάντηση: Re: Quad 22L
Ακριβώς. :cool_4:
Το 22L υστερούσε σε αμεσότητα και δέσιμο των μονάδων. Γενικά το 21 ακουγόταν πιο σωστό. Μου έδωσαν την αίσθηση πως ξεκίνησαν για το μικρό και στην πορεία είπαν "δεν πετάμε άλλο ένα μεγάφωνο επάνω?" και να προέκυψε το 22άρι. Δε λέω πως είναι κακό ηχείο. Ίσως μάλιστα το παραπάνω μπούγιο που κάνει το extra μεγάφωνο στα χαμηλά να ταιριάζει καλύτερα σε ένα σύστημα home cinema π.χ.... Απλά όταν μιλάμε για αμιγώς audio σύστημα τα "+" του 21 είναι πιο σημαντικά.
n_olympios
Μαντιναδόρος!
Πολλοί κατασκευαστές το κάνουν αυτό. Θέμα εντυπωσιασμού? Θέμα αναγκών ήχου "home cinema"? Θέμα marketing? Οπως και να'χει, πουλάνε...
Κώστας Φ.
H συγκεκριμένη σειρά της Quad, η L-Series, περιλαμβάνει (εκτός απο τα βάσης 11L, 12L και τα δαπέδου 21L, 22L) sub και κεντρικό. :happy_6:
Για το sub ακούω καλά λόγια (φοράει 12ιντσο μεγάφωνο) αλλά δεν έχει τύχει να το ακούσω.
Το καλό της υπόθεσης είναι πως επειδή αυτά τα ηχεία έχουν πουλήσει αρκετά υπάρχουν σχετικά συχνά το κεντρικό και τα βάσης σε αγγελίες οπότε εαν και εφόσον μου τη δώσει κάποια στιγμη να ασχοληθώ με το home-cinema δε θα έχω πρόβλημα να βρω τα extra ηχεία σε λογικό κόστος. Παίζει βέβαια να έχω πάρει τα ηλεκτροστατικά μέχρι τότε και να μπουν τα 11L ως περιφερειακά... :cool_3:
  • loggeo
Manosmathiou
