Weiss Engineering: Jason and Medea
Κώστας Φ.
Αχχχ, αυτή η Weiss.... :respect:
Tιμές: €12,300 για τον Jason (CD transport), €10,600 για τη Medea (DAC).
"In conclusion, the Weiss duo completely avoided my reactions to the first-generation NuForce amps and Benchmark Media's DAC-1 where I felt that the presentation of detail against ultra-black backgrounds exhibited an unnaturally heightened contrast ratio, ultimately lacked tone and suffered artifice in the treble. The Weiss sound is free of those shortcomings. In fact, it's free of anything that could be termed sonic shortcoming with a straight face. In amp-direct mode with speakers like Rethm's Saadhana, I personally preferred the Ancient Audio's 6H30 action for enhanced timbral richness but as with every sound comment in this review, the delta of difference was a small fissure in the ground only ants would mistake for an abyss.
Features are truly comprehensive; the remote is a poster child for intuitive organization; build quality seems superlative - and pricing befits Swiss luxury kit. Competitors I've reviewed are the two-box Esoterics and, for converters, the Stylus Systems Had. If you've been through the kid-in-the-candy-shop phase, you'll appreciate the unadorned, compact material implementation of Weiss. Considering the unstoppable ascendancy of hard-drive and eventually solid-state memory-based playback, the sheer fact that RedBook-only products of the Weiss Jason + Medea's caliber remain available to 2-channel non-professional hobbyists is astonishing. This, after all, is professional kit. How many home-based audiophiles will be prepared to invest steeply into a fading delivery format is a question for the pundits and their crystal balls. Those in the market for $30K digital machines know exactly who they are. It's to them these Weiss pieces are relevant. Those content with 98%, at the associated component level I'm personally playing at, can enter this game far earlier during the coin-saving process..."
6moons.com
JASON
MEDEA
Απάντηση: Weiss Engineering: Jason and Medea
Επίσης στην HI END έκθεση ο αντιπρόσωπος Κος Θέμης Ζαφειρόπουλος
θα επιδεικνύει τα προϊόντα που αντιπροσωπεύει-διακινεί με
μάλλον αποκλειστική χρήση PC σαν πηγή μουσικού υλικού!
Θυμίζω ότι ο Θέμης εκτός από χρόνια αντιπρόσωπος είναι
και ένας από τους καλύτερους Έλληνες ηχολήπτες !
Αντιγράφω από το site της location audio :
[FONT=Verdana, Arial, Helvetica, sans-serif]
http://www.locationhiend.com/eksoplismos.html
[/FONT]​
[FONT=Arial, Helvetica, sans-serif]"H Iστορία μου σαν ηχολήπτης ξεκίνησε το καλοκαίρι του 1976. H αγάπη για την μουσική και την υψηλή πιστότητα, συνδυάστηκαν εκείνο το καλοκαίρι του '76 στο Hρώδειο και το αποτέλεσμα ήταν καθοριστικό. Eνα καλό φορητό κασσετόφωνο και 2 πυκνωτικά μικρόφωνα ήταν αρκετά ώστε η ηχητική καταγραφή να γίνει από απλό χόμπυ, τρόπος ζωής.[/FONT]​
[FONT=Arial, Helvetica, sans-serif]Aπο τότε και μέχρι που η ηχοληψία έγινε επάγγελμα, ηχογραφήθηκαν εκατοντάδες συναυλίες, με μόνη ανεκτίμητη αμοιβή την γνώση.[/FONT]​
[FONT=Arial, Helvetica, sans-serif]Δοκίμασα απο τους πρώτους μινιμαλιστικές μεθόδους ηχογράφησης, όλα τα νέα ψηφιακά φορμά και μοντάζ σε υπολογιστή.[/FONT]​
[FONT=Arial, Helvetica, sans-serif]Aπο το 1982 μέχρι σήμερα, έχω ηχογραφήσει σχεδόν το σύνολο των Eλλήνων μουσικών, Oρχηστρών και συνόλων, πολλούς ξένους καλλιτέχνες, και αρκετά ξένα σύνολα και Oρχήστρες.[/FONT]​
[FONT=Arial, Helvetica, sans-serif]H συντριπτική πλειοψηφία των ηχογραφήσεων είναι από ζωντανές συναυλίες
σε όλες σχεδόν τις αίθουσες της Eλλάδας και στο εξωτερικό όπως Nέα Yόρκη, Mιλάνο, Στουτγάρδη, Λονδίνο, Σόφια και Πάζαρτσικ.
[/FONT]​
[FONT=Arial, Helvetica, sans-serif]Aπο το 1993 μέχρι το 2002 ήμουν υπεύθυνος για τις ηχοληψίες και βιντεοσκοπήσεις αρχείου της Eθνικής Λυρικής Σκηνής και της Kρατικής Oρχήστρας Aθηνών.[/FONT]​
[FONT=Arial, Helvetica, sans-serif]Σήμερα ο εξοπλισμός μου αποτελείται απο μία πλήρη γκάμα κορυφαίων μικροφώνων και συσκευών ήχου .[/FONT]​
[FONT=Arial, Helvetica, sans-serif]Tελευταίο απόκτημα το ψηφιακό μαγνητόφωνο NAGRA V με δυνατότητα στερεοφωνικής εγγραφής 96KHz/24bit σε σκληρό δίσκο.[/FONT]​
[FONT=Arial, Helvetica, sans-serif]____________________________________________________________
H ηχοληψία είναι μεράκι και γνώση.
Oταν αυτά υπάρχουν μένει το σπουδαιότερο: Nα μάθεις "να ακούς" .
Tότε καταγράφεις, όχι μόνο τον ήχο, αλλά και την ψυχή του καλλιτέχνη.
[/FONT]​
[FONT=Arial, Helvetica, sans-serif]Θέμης Zαφειρόπουλος
Φυσικός - Mηχανικός ήχου "
[/FONT]​
[FONT=Arial, Helvetica, sans-serif][/FONT]
Κώστας Φ.
Άλλο ένα review του DAC Medea, αυτή τη φορά από τον...μέντορα του μέντορά μου, τον AVmentor, Δ. Σταματάκο.
"Τελικώς...
... συμβαίνει σπανίως αλλά συμβαίνει. Τέσσερα χρόνια μετά την δοκιμή του Esoteric P70/D70 έπεσα επάνω σε έναν εφάμιλλο -και σε ορισμένα σημεία σαφώς καλύτερο DAC. Ο Medea είναι μια εξαιρετικά σχεδιασμένη συσκευή η οποία κινείται πραγματικά σε ένα κορυφαίο επίπεδο αναφοράς και, παρά την υψηλή τιμή του, αξίζει κάθε ευρώ που θα δώσετε, αν ο στόχος σας είναι η δημιουργία μιας κορυφαίας και χωρίς περιορισμούς ψηφιακής πηγής."
Full Review: avmentor.gr
roberto_portale
