Dynaudio Confidence C1 loudspeaker
Κώστας Φ.
  • Description: Two-way, reflex-loaded, stand-mounted loudspeaker. Drive-units: 1.1" soft-dome tweeter, 6.6" plastic-cone woofer. Crossover frequency: 1800Hz, with first-order slopes. Frequency range: 44Hz–22kHz. Nominal impedance: 4 ohms. Sensitivity: 86dB/2.83V/m. IEC long-term power handling: 170W.
  • Dimensions: 17.4" (445mm) H by 7.8" (200mm) W by 16.8" (430mm) D. Weight: 24 lbs (10.9kg).
  • Finishes: rosewood, maple, cherry, black ash veneers.
  • Price: $6500/pair in standard veneers; premium gloss black or rosewood lacquer finishes add $500/pair; matching Stand4 stands, $450/pair.
"In many senses, it's difficult to know what to make of the Dynaudio Confidence C1. At $6950/pair (stands included; add $500 for a premium finish), it isn't an impulse purchase, and as a two-way stand-mounted monitor, it doesn't fit many audiophiles' notions of a "real" loudspeaker. That's okay—the C1 is an "inside baseball" product.
The Confidence C1 delivers world-class performance in a real-world package. If you value openness and tonal clarity, the C1 is a contender. It will mate with small to midsize rooms in ways that larger speakers simply can't (yes, you can have too much loudspeaker), and it won't be overwhelmed by large spaces.
All which makes it sound as if I'm trying to convince you to buy the C1 because it's a logical choice. Maybe it is, but there's nothing inherently logical about a $7000/pair loudspeaker—you buy it because you've fallen in love with it. That's something no amount of logic can convince you of.
So I'll shut up. You listen. You'll know what to do."
-- Wes Phillips
"This superb measured performance is beyond reproach (other than that lively stand)." -- John Atkinson
Full Review: Stereophile.com
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Απάντηση: Dynaudio Confidence C1 loudspeaker
Εγώ πάλι αγαπώ τα woofer της Dynaudio. Τα θεωρώ μακράν τα πιο τίμια οικονομικά αλλά και τα πιο αποδοτικά...
Re: Απάντηση: Dynaudio Confidence C1 loudspeaker
Εχω στην κατοχή μου τα μεγάλα δαπέδου Dynaudio Contour 3.3 (με τα δύο 8 ιντσα woofers).
Κόστος 6.000 ευρώ πληρωτέα εν έτη 2002 . Υπέροχο ηχείο με τρομερή ενέργεια στις χαμηλές συχνότητεες, όταν βέβαια οδηγούνται σωστά από ενισχυτή που διαθέτει ικανά αποθέματα ενέργειας και ταχύτητα.
Τα θεωρώ καλύτερα monitors από τα ATC 50. Είναι και αισθητικά πιο όμορφα από τα ATC. Οι Δανοί δεν παίζονται σε ότι έχει να κάνει με την επεξεργασία και το φινίρισμα του ξυλου.
Οι νέες σειρές της Dynaudio ακολουθούν πιστά την παράδοση της εταιρείας που είναι η ικανοποίηση του χομπίστα μουσικόφιλου καθώς και του απαιτητικού επαγγελματία.
Εχω το C1 περίπου ένα χρόνο με τις βάσεις του αγορασμένο από τη Γερμανία. Το ηχείο είναι καταπληκτικό, περίμενα να ακούσω ήχο που αντιστοιχεί σε ηχείο βάσης και προορίζεται για μικρό χώρο, όμως οι δυνατότητες είναι πολύ μεγαλύτερες. Είναι ομοιογενέστατο, με έκταση στα άκρα, πολύ καλά δυναμικά και έξοχη υψηλή και μεσαία περιοχή. Θέλει ισχυρό ενισχυτή και πολύ ποιοτικά συνοδά.
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Απάντηση: Re: Dynaudio Confidence C1 loudspeaker
Αυτό το απαιτούν όλα τα Dynaudio. Θέλουν ποιοτικά συνοδά απλά γιατί δεν "σκεπάζουν" τις αδυναμίες του υπόλοιπου συστήματος, αλλά τις βγάζουν μπροστά (όπως και τα ATC). Και για αυτό δεν είναι ηχεία που απευθύνονται σε όλους, παρά μόνο σε όσους είναι έτοιμοι να δεχθούν αυτό το "ξεμπρόστιασμα".
Όσο για τους ενισχυτές, ξεχάστε τα SET, ξεχάστε τους ολιγόβατους τρανζιστοράτους, ξεχάστε ότι έχει μικρά ρεύματα. Ένας βαρβάτος 2x100w(8Ω) που σχεδόν διπλασιάζει στα 4Ω μπορεί να τα οδηγήσει. Με οτιδήποτε λιγότερο δύσκολα συμβιβάζονται. Το εκτεταμένο χαμηλό έχει και απαιτήσεις...
Το έχω αναφέρει πολλές φορές και θα το πω ξανά.
Η καλή οδήγηση ακούγεται ΚΑΙ στις χαμηλές στάθμες ακρόααης. Αυτό είναι πολύ σημαντικό γιατι διαφορετικά το ηχείο ακούγεταο "άδειο".
Η χαμηλή -σχεδόν μηδενική- αντίσταση εξόδου του ενισχυτή είναι must για την οδήγηση ενός δύσκολου ηχείου 4Ω με crossover πρώτης τάξης.
Κώστας Φ.
Dynaudio Confidence C1 Loudspeakers
Price: $6500 per pair.
Warranty: Five years parts and labor.
Review Summary
Sound
"Right from the start, the Confidence C1s sounded pleasantly direct, detailed, open, and spacious, and they had good bass extension." "Their bass was pitch defined and carried considerable weight into the 30Hz range," and the C1s displayed "a quick, spacious, straightforward purity often associated with fine minimonitors, but they also conveyed considerable heft and physicality." "I typically associate this kind of aural physicality with much larger speakers."
Features
"The bass-reflex C1 has a large port flared at both ends that exits at the bottom rear of the cabinet. The midrange/bass driver is mounted above the tweeter for better time alignment for a typical seated listing height, and this alignment also reduces interaction with the floor by placing the woofer higher than the usual tweeter-above-woofer arrangement would." All Dynaudio drivers, including the Esotar2 tweeter. The unusual baffle "is said to help reduce baffle-induced diffraction and uneven dispersion patterns, and make all Confidence-line speakers less susceptible to some of the boundary-interaction problems that plague speakers in typical domestic listening spaces."
Use
"The manual…gives refreshingly candid information about break-in and suggests 'several weeks running/playing.' It took about 350 hours for the C1s to settle in -- to develop their sound." "Dynaudio encourages fairly steep toe-in and recommends that you do serious listening without the grilles. I concur."
Value
"How can a relatively small, stand-mounted speaker be value-competitive with a larger floorstanding multi-way speaker? If sonic performance acts as the primary guide, rather than sheer size and number of drivers, the Dynaudio Confidence C1s are worth every penny of their asking price."
Full Review: Soundstage!
Μετρήσεις: Click
Marioslion
