ARCHOS 605 WIFI 30GB
L
LLLEFTERIS
Στο κουτι μεσα σε αριστη κατασταση με οθονη αφης!
Το μονο προβλημα ειναι πως εχω αντικαταστησει τα ακουστικα με αλλα γιατι τα δικα του τα εκαναν παιχνιδι τα γατακια που εχω εδω!
Τιμουλα 180 ευρο! Μονο απο Αθηνα! Τηλ 6938811128
Capacity: 30GB* hard drive stores up to 40 Movies, 300,000 photos or 15,000 songs3
80GB* hard drive stores up to 100 Movies, 800,000 photos or 45,000 songs3
160GB* hard drive stores up to 200 Movies, 1 million photos or 95,000 songs3 Display: High resolution screen, 800x480 pixels, 4.3'' TFT LCD, 16 million colors
Touch screen Video playback**: MPEG-4(4) (ASP@L5 AVI, up to DVD resolution)
WMV (MP@ML, up to DVD resolution)
With optional software plug-ins (available for purchase on www.archos.com):
- Video Podcast plug-in: H.264 up to DVD resolution and AAC
- Cinema Plug-in: MPEG-2 MP@ML up to 10 Mbps (up to DVD resolution) and AC3 stereo sound (5.1) Audio playback**: Stereo MP3 decoding @ 30-320 Kbits/s CBR & VBR, WMA, Protected WMA, WAV (PCM/ADPCM).
With optional software plug-ins (available on www.archos.com):
- AAC5 stereo audio files
- AC3 stereo audio and 5.1 sound files Photo viewer***: JPEG, BMP, PNG PDF viewer: Reads PDF documents (may not implement all PDF features) Video recording6: Via the optional DVR Station/ DVR Travel Adapter. Records NTSC/PAL/SECAM in MPEG-4 AVI format with stereo sound, VGA resolution (640 x 480) @ 30 or 25 f/s Audio recording: Via the optional DVR Station/ DVR Travel Adapter: Stereo line-in, WAV (IMA ADPCM or PCM) format Interfaces: USB 2.0 High-Speed Device (compatible USB 1.1): Mass Storage Class (MSC) and Media Transport Protocol (MTP)
USB 2.0 Host: Mass Storage Class (MSC) and Picture Transfer Protocol (PTP) with optional Mini Dock, Battery Dock and DVR stations Connections: WiFi (802.11g) connection. Optional Internet plug-in (Opera® Web browser and Adobe Flash® Player) for Web browsing (for purchase on www.archos.com)
3.5 mm mini jack for headphones
Docking connectors to connect DVR Station and other ARCHOS accessories Battery life: Music playback time: 177
Video playback time: 5.57 Power source: Internal: Lithium-Ion Polymer battery
Device charges via computer USB port
External: Power adapter/charger (via optional accessories) Scalability: Device automatically downloads latest firmware updates Dimensions & weight: Avg 122 x 82 x 15 mm/4.8'' x 3.2'' x 0.6'' (For 4/30GB* models) - 150gr/190gr
Avg 122 x 82 x 20 mm/4.8'' x 3.2'' x 0.75'' (For 80/160GB* models) - 260gr Package includes: ARCHOS 605 WiFi, headphones, ARCHOS USB cable, DVR Station Gen 5 adapter, protective pouch, Quick Start Guide (QSG), legal and safety notice.
L
LLLEFTERIS
Ανταλαγές με τί??
Gadgetakias ειμαι μπορει να υπαρχει κατι που να με ενδιαφερει και ας ειναι ποιο ακριβο απο το δικο μου δινω και την διαφορα! Πειτε μου τι εχετε και την τιμη που ζητατε και αν με ενδιαφερει θα σας πω!
2sc
Να υποθέσω ανταλλαγή με γίδα δεν κάνεις ...
Δεν μου λες. Μιας και είμαι εντελώς άσχετος. Με το
Web Browser Plug-in θα μπορώ να σερφάρω στο Internet? Με ποιον Browser?
Απάντηση: ARCHOS 605 WIFI 30GB
Λευτέρη, είχες ξαναβάλει αγγελία και στο παρελθόν για άλλο ARCHOS. Με ενδιαφέρει η πώληση και θα γίνει με χρήματα και όχι με ανταλλαγή προϊόντων. Αν είναι να μου πεις στο τέλος πως το έδωσες σε φίλο σου, πες το μου να μην περιμένω άδικα.
Σε ευχαριστώ.
L
LLLEFTERIS
Re: Απάντηση: ARCHOS 605 WIFI 30GB
Λευτέρη το θέλω. Είμαι από Αθήνα.
Σακη παρε με τηλεφωνο γιατι πολλοι μου εχουν πει το θελω κρατησε το μου και τελικα δεν το πηραν!
2sc Τον Opera εχει αλλα με το Ελληνικο μενου εχει Ελληνικο πληκτρολογιο και δεν καταλάβα πως αλλαζει σε Αγγλικο
lakiss51
Λεφτερη αν σου πεσει κανενα Archos 605 σε (πολυ!) καλη τιμουλα πμσε μου!
Ναι... Ναι... εγώ το πήρα.:116: ΤΗΧ Λευτέρη.
Κανένα μεγάλο σκληρό 1,8" που θα βρούμε ρε παιδιά για να του βάλουμε?
proteusjohn
