Martin Logan CLX and CLX 25th Anniversary
Κώστας Φ.
MartinLogan has announced their new CLX and CLX 25th Anniversary electrostatic loudspeakers. The CLX and CLX 25th are 70" tall and retail for $19,995 and $24,995 per pair, respectively.
  • CLX 25th Anniversary Limited Edition: $24,995/pair (US retail) -
  • available in black and clear anodized billet aluminum with interior and exterior white lighting
  • CLX: $19,995/pair base price (US retail) -
  • available in cherry, maple, and black maple hardwood; black EcoSound; and custom finish options with exterior blue lighting
Features:
- 57" CLS (curvilinear line source) XStat electrostatic technology
- DualForce double diaphragm, triple stator 57" dipole low-frequency electrostatic transducer
- Low-frequency dipole phase stabilization
- Precision Vojtko filtering including: thick film on alumina substrate
resistors, air core coils, polypropylene capacitors, and custom wound toroidal audio transformers
- Audiophile grade power cable
- ETC spikes
- Environmentally conscious design
Specifications:
- System Frequency Response 56-23,000 Hz ± 3db
- Horizontal Dispersion 30 Degrees
- Vertical Dispersion 57" (145 cm) line source
- High Frequency Transducer 57" (145 cm) CLS (curvilinear line source) XStat electrostatic transducer
- Low Frequency Transducer 57" (145 cm) DualForce ESL double diaphragm, triple stator dipole low-frequency electrostatic transducer
- Sensitivity 90 dB/2.83 volts/meter
- Impedance 6 ohms , 0.7 ohms @ 20 kHz
- Crossover Frequency 360 Hz
- Components Thick film on alumina substrate resistors, air core coils, polypropylene capacitors, and custom wound toroidal audio transformers
- Controls Accent Light On/Off
- Power Handling 225 watts per channel
- Weight (Aluminum) 152 lbs. each
- Weight 110 lbs. each
- Size 70.32" h x 25.75" w x 13.75" d
Πηγή: audiojunkies.com
Δεν προλαβε να παρουσιαστει στο Μοναχο και την τσιμπησε την ειδηση ο Κωστης....:136:
Αυτο που λεει finish with exterior blue lighting τι ειναι?
Black light?:142:
Σαν αυτο που εχει ο Ali g κατω απο το αμαξι?
Ωπ σωστος νομιζα οτι ειχε γουφερακι κατω, δεν το προσεξα καλα.
Συγγνωμη παιζει κρος μεταξυ δυο μεμβρανων?Ποιος ο λογος? Υπαρχει μεμβρανη για χαμηλα και μεμβρανη για μεσουψηλα?
Ε ρε τι μαθαινει κανεις.
Αλλα και παλι το κρος ειναι κρος, ειναι δυσκολη περιοχη αυτη που διαλεξαν!
Gebreselassie
Μαύρος!
Συγγνωμη παιζει κρος μεταξυ δυο μεμβρανων?Ποιος ο λογος? Υπαρχει μεμβρανη για χαμηλα και μεμβρανη για μεσουψηλα? Ε ρε τι μαθαινει κανεις.
Φυσικά και υπάρχει. Εκτός κι αν το ηχείο είναι full range. Όπως βλέπω το συγκεκριμένο, έχει μια μονάδα σαν αυτή που βάζει στα υβριδικά και ένα πάνελ για χαμηλές.
- Υπάρχει και ηχείο με δύο δρόμους επάνω στην ίδια μεμβράνη (βλέπε magnepan). :126:
Τhanks...;)
Ρε θα βγαλεις τις τελιτσες??? Θα ησουν πολυ ψαρωτικος αξιωματικος στο στρατο.:137:
jerry78
