PopCorn Hour A100 €199
vis
New firmware released:-
Please be informed that Popcorn Hour A-100 firmware release:
01-17-080612-15-POP-402
and NMT apps:
00-17-080529-15-POP-402
is available for update.
Changelog:
Release Date : 18 June 2008
Firmware Version : 01-17-080612-15-POP-402-000
Release Note :
1. Requires NMT apps 00-17-080529-15-POP-402
2. Stepstone update to a new fail-safe kernel
- *older firmware need to step through this, before able to update to future firmware.
- ** Note that there will be a repeated "programming kernel..." message, this is correct behaviour.
- fail-safe kernel for recovery from bad updates/flash programming.
3. Browser
- fixed Browser no longer runs after long idle
- fixed myiHomeLite hangs when certain filename listed
- improved memory clearing, reduce time from 390ms to few milliseconds
- fixed bug where links with #xxx does not work when page is with OnLoad
- added image changing and on-the-fly loading feature
- added menu frames for file operation UI
- fixed problem changing TV mode when URL prompt is turned on
- fixed focus/unfocus not working when browser frame does not start at (0,0) location
- all page loading and refresh request disabled when screensaver is on.
- fixed screen freeze when changing onfocus image in MSP
4. Subtitle
- increased subtitle font size to 32 max, swiched to cleaner method
- subitle time adjust now from -1000sec to +1000sec
- fixed subtitle not aligned to center under certain conditions
- fixed subtitle On/Off not persistent when in playlist
- fixed subtitle centering issue, encountered with Hebrew subtitle
- fixed Hebrew subtitle bi-directional bug
- fixed external subtitle turn on/off issue, when Play All
5. Matroska (MKV)
- added VC1 in MKV support (no TimeSeek for this yet)
- fixed MKV audio sync latency after TimeSeek/td>
- fixed MKV no audio after changing from AC3 to DTS track
- fixed MKV no PCM audio after switching audio track
- fixed MKV audio info not updated after switching, reported as audio switching failure.
6. BT
- recover schedule database after system reboot
- added reset schedule function
- fixed sometimes unable to delete BT schedule
7. WiFi driver
- Atheros USB 11n driver added
- added wpa_supplicant and new zd1221 driver
- WiFi setup page updated to support new scanning method and USB hotplug
- Enable Atheros USB WiFi detection for different vendor and product IDs.
8. UPnP
- Marquee tweaks and color customisation
- fixed for TVersity playback issue
- improved crash handling
9. Network share
- Share out removable storage (e.g. USB drives) through SMB/NFS server
- Reset UDN when restore factory settings
- Removes all network shares after restore factory settings
- Able to set system password to None now, just leave it blank
10. Photo app
- fixed 1-bit PNG rendering
- fixed after photo rotation failed, slideshow paused
- fixed after rotation, photo scaling incorrect
11. Skinnability for browser UI
- refer to notes below how to modify "skins" for your NMT
- added customisable color for fonts
- added NMT watermark
12. Various patches and improvements
- fixed aspect ratio issue for 4:3 TV mode (16:9 TV mode not affected)
- added OSD message when USB keyboard inserted/removed
- turns off SPDIF out when exit playback
- fixed character 'j' wrong horizontal position when rendering
- fixed login page wrong SD/HD server icon
- fixed Splashscreen flickering issue
- included traditional Chinese in language selection
- turns off analog video output when in HDMI (some power saving)
- added TV Mode 1360x768 60Hz
- fixed regression, when player first boot, if failed to login to server, get stuck at 2nd splashscreen for long time.
- fixed incomplete Traditional Chinese translation
- fixed delayed auto-login issue
- added additional language options for DVD subtitle and audio option
- enabled IP multicast support and USB card reader support in kernel configuration.
- fixed crash issue (#QA0482)
- fixed DVD autoplay issue during bootup.
- fixed missing dimension and AR info
- workaround long auto-login when SMB name resolution failed
- fixed info bar becomes translucent after ISO playback (#QA0480)
- fixed "Could not play" error after pressing next while play m4a
- fixed timezone DST and other xx:30/xx:45 timezone handling
- fixed occasional HDMI black-screen after stopping video playback
- fixed DVD setup page cannot save Chinese audio
- fixed Network setup navigation issue
- fixed HDD NMT version checking when network restarted
How to change the "skins" of your NMT UI:
1. Obtain _theme_.zip from release package or download from www.popcornhour.com/download/_theme_.zip
2. Unzip and modify existing graphics as you wish, but maintain the dimension and filename
3. Modify .config file in root of _theme_ folder to change the colors of the text, color attributes is same as in HTML, e.g. RRGGBB, #RRGGBB, "green", "white-alpha", "black"
4. Copy entire _theme_ folder to the NMT harddisk's Photo folder
5. Reboot (Power + Eject) and new theme will be loaded
NMT Apps Version : 00-17-080529-15-POP-402
Release Note :
1.Minimum firmware version to use this NMT App is 01-17-080529-15-POP-402-000
2. Share out USB / HARD DISK through SMB / NFS server
3. Blank password supported for FTP and SMB server
4. Support SATA drive with NMT partition
5. Fixed setup page start/stop torrent button disabled after stop
6. Fixed BT crash bug
7. Fixed upload cap for BT client reverting to 0
8. Fixed Samba auto login delay
vis
Πολύ καλό, μέσα σε όλα τα άλλα διορθώνει και το πρόβλημα με το κεντράρισμα των subs.
Απο ότι είδα αν είναι ενσωματωμένοι σε mkv τους πάει αρκετά αριστερά...............................στην περίπτωση που είναι εξωτερικοί μάλλον (σίγουρος θα ειμαι αργότερα όταν κάνω και άλλα τεστ) είναι κεντραρισμένοι.
Γιατί δεν παίζει τον ήχο από τα videoclips που κατεβάζω στον υπολογιστή μου με το Azureus Vuze και τα μεταφέρω στο popcorn με στικάκι;
Προσπάθησα μάλιστα να τα μετατρέψω σε avi με το mkv2vob αλλά δεν υποστήριζε ούτε και αυτό τον ήχο του βίντεο. Μήπως παίζει κανένα κλείδωμα του ήχου από το Azureus ;
Είναι κρίμα πάντως γιατί έχει μερικά πολύ καλά videoclips.
Δοκίμασε να αλλάξεις στις ρυθμίσεις ήχου του popcorn εκεί που ειναι για AAC απο Digital σε Analog PCM,αν θυμάμαι καλά.
H αλλαγή των ρυθμίσεων είχε ήδη γίνει αλλά.....
Μάλλον πως ο λόγος είναι ότι το Azureus χρησιμοποιεί στα βίντεο του codec Vorbis και το popcorn δεν είναι συμβατό με αυτόν, έτσι είναι;
vis
Στο τελευταίο beta (01-17-080711-15-POP-402-000) έφτιαξαν και το rendering στα fonts, αν και μια μικρή βελτίωση χωράει ακόμη
Απάντηση: Re: PopCorn Hour A100 €199
Θελω να αγορασω το popcorn a100 και το βρηκα σε ελληνικο site με τιμη 220e ,το εχει παρει καποιος απο εδω η συμφερει απο εξω
Από έξω θα σου έρθει πιο φτηνα, 165 ευρω, αλλά θα αργήσει 2-3 βδομάδες. Εγώ πάντως το πήρα απ'εξω.
Για την συνδεση του ηχου εχω οπτικη ινα στον ενισχυτη ενω το a100 εχει coaxial.Ξερει κανεις αν γινεται η μετατροπη ?
Είχα το ίδιο θέμα και πήρα από εδώ http://www.emimikos.gr/shop/product.php?productid=17392&cat=420&page=1 τον μετατροπέα Coaxial σε optical. Δουλεύει μια χαρά και δεν χρειάστηκε να τον παραγγείλω στο εξωτερικό όπου σημειωτέον τον βρήκα και πιο ακριβό...Το συγκεκριμένο e-shop το βρήκα με αναζήτηση στο Google.
Ευχαριστω για την λυση του ηχου.Μια ερωτηση για την hdmi εξοδο.Θελω απο μια hdmi που εχει να συνδεσω τον epson 700 1280χ720 και μια 32΄' tv 1366χ768 ,θα παιζει παντα μια απο τις δυο.Εχω βρει αυτο http://www.ioulios.gr/product-id-30509.html .Γινεται αυτο η πρεπει να ορισω την ιδια αναλυση?
Τωρα πηρε το ματι μου οτι σε ενα μηνα θα βγει το α-110 με 1.3 hdmi και με οπτικη ινα .Μαλον θα περιμενω το δω.
Ακουσε κανείς κάτι νεότερο σχετικά με usb wifi σε μια από τις θύρες του pop αντί την ethernet που έχει?
Ξέρω ότι το 1.3 έχει παραπάνω bandwidth και υπάρχει μεγαλύτερη γκάμα μηχανημάτων που υποστηρίζει λόγω του κλειδώματος HDCP, αλλά ούτως ή άλλως το 1.1 που έχει το pop φτάνει και περισεύει για 1080p με ταυτόχρονο AC3 (δεν ξέρω για DTS)
HDCP έχεi και το HDMI 1.1. Το HDMI 1.3 θα χρειαστεί για αρχεία με lossless φορμά ήχου. Το θέμα είναι αν έχει νόημα μια ματρόσκα πχ με τέτοιο φορμά ήχου, από τη στιγμή που προσπαθούμε να γλυτώσουμε ό,τι μπορούμε σε μέγεθος αρχείου από το video.
Προσωπικά, δεν νομίζω να δούμε πολλά τέτοια αρχεία.
Από την άλλη, ένα τέτοιο αρχείο σε συσκευή με 1.1, δεν θα παίζει καθόλου ή θα παίζει σαν AC3;
παιδια επειδη ενδιαφερομαι να παρω απο αμερικη την τελευταια εκδοση του popcorn μπορειτε να μου πειτε την πληρη ονομασια του.......θα ημουν ευγνωμων και επειδη η αγορα θα γινει απο συγγενη μου θα γλιτωσω και τα μεταφορικα........
jerry78
