xoντροκωλα γκομενα τυπου ηχειου!!!!!!
vlasis
Φωτογράφος!
Αν σας περισσευουν 60000 ψωροδολλαρια παρτε δυο για το σπιτι σας απο τους φιλους τους Ιαπωνες..........................ε ρε τρελλα ΧΑΙΕΝΤΑΔΙΚΗ!!!!!!!
These technologies will bring you the most vivid and the purest sound you’ve ever experienced!!
Profile
system --- single driver with short straight back load horn
driver --- 3” full range FDM driver (surround-less, dumper-less)
size --- 60cm x 70cm x 140cm (W, D, H)
weight --- 160 lbs
frequency respons (-6dB) --- 50-30,000 Hz
sensitivity (2.83V, 1m) --- 87dB
“Evanui signature” is the ViV laboratory’s flagship speaker. “Evanui” means “vanish” in Latin. Good speakers make us forget their existence. ViV laboratory’s speaker line up, “evanui series”, vanish when they play back music. To make it true, we pay most effort to convert amplifier’s electrical signal to acoustic vibration precisely as possible. And we also attach great importance to its design.
Technology
<< FDM Driver >>
We finally reached to realize the dream of speaker engineers. Our original FDM Driver has no surround and no dumper, then the diaphragm has no mechanical contact except lead wire of voice coil. This means that the diaphragm floats mechanically (Floating Diaphragm Mechanism). This evolutional driver can play back sound with very low distortion and covers so wide frequency range that it needs neither extra woofer nor extra tweeter. This brings us additional big merit that we need no dividing network any more. Then, the FDM Driver can avoid both electrical distortion and mechanical distortion.
3” diaphragm of the FDM Driver is made of pure magnesium that is very light, strong and low resonance. The surface of the diaphragm is coated with URUSHI, which is Japanese traditional natural paint.
The magnetic circuit of the FDM Driver is powered to the limit with extra large neodymium magnet and pure iron parts.
Απάντηση: xoντροκωλα γκομενα τυπου ηχειου!!!!!!
Μου φέρνει κάτι σε σκουλίκι, που έφαγε και δεν έχ3σ3:135:
Άντε και με όψη Godzilla το επόμενο...
Εμενα μου κανει κατι μεταξυ κομπρας και ναργιλε. :138:
Εγω πρεπει να το κοιταξω η αυτοι ? :142:
Shai-Hulud...
Μη με παρεξηγείτε, διαβάζω τα Dune αυτό τον καιρό...:137:
Αυτές, εκτός από χοντροκwλες είναι και χαμηλοκwλες, κλ@νουν και σηκώνουν σκόνη! :142:
vlasis
Φωτογράφος!
χε χε χε ....εχετε ξεφυγει τελειως μου φαινεται παλιοαναωμαλοι!!!!!!!!!!!!
Το ηχείο είναι πολύ σωστά μελετημένο! Ειναι αδύνατον η σύζυγός σας να βάλει γλάστρα απο πάνω!
vlasis
Φωτογράφος!
Πολυ σωστη παρατηρηση και φυσικα....ουτε ενα σεμεν (της μανουλας)!!!!!
Μ' αυτό το πλευρό να κοιμάστε!:143:
Όλο και κάτι θα βρει...
Εδώ η μάνα μου κόντεψε να βρει να βάλει πράμα πάνω στην LCD, αλλά υπέβαλλα βέτο!
mpalo
