Spendor ST
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Description:
2.5 way floor standing loudspeaker Enclosure type:
Spendor linear flow reflex HF drive unit:
29 mm wide-surround dome with fluid cooling MF/LF drive unit:
Spendor 180 mm (7”) ep39 cone LF drive unit:
Spendor 180 mm Kevlar composite cone with elastomer damping Sensitivity:
87dB for 1 watt at 1 meter Crossover point:
4.8 kHz Frequency response:
58 Hz to 20 kHz ± 3dB anechoic Frequency range:
-6dB at 40Hz anechoic Impedance:
8 ohms nominal Impedance minimum:
4.2 ohms Power handling:
200 watts unclipped programme Terminals:
WBT Next-Gen 4 way binding posts single-wired Cabinet (H x W x D):
38 x 8 x 13 inches excluding feet and rear terminals Finish:
Piano black lacquer cabinet with exotic ebony, zebrano or aluminum inlays Weight:
62 lbs Accessories: Adjustable height spike feet, magnetic drive unit protection grilles
8.995 $ το ζευγος
http://www.bluebirdmusic.com/spendor_st.htm
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Απάντηση: Spendor ST
Το φινίρισμα είναι άθλιο για τα γούστα μου. Ευτυχώς που η spendor βγάζει καλά ηχεία, γιατί αν περίμεναν να πουλήσουν design...
Saitama
