ESS Technology Announces Sabre32 Reference DAC
Κώστας Φ.
ESS Technology Announces Sabre32 Reference DAC Worlds Best 32-bit Audio D/A Converter with 135dB Dynamic Range
FREMONT, Calif.--(BUSINESS WIRE)--ESS Technology, a leading provider of high performance audio/video solutions, today announced the addition of two new Sabre32 Reference 32-bit Audio DAC parts to its Vista™ family of high-definition audiovisual product line.
The Sabre32 Reference DAC is an enhancement to the original Sabre Reference DAC that has taken the audio world by storm since its introduction in January 2008, through its superior performance and jitter-free sound clarity made possible by the ESS patented Hyperstream™ architecture and Time Domain Jitter Eliminator.
Using an enhanced 32-bit Hyperstream™ architecture, the Sabre32 Reference DAC further extends the original Sabre Reference’s from 24-bit to 32-bit music and raises its mind-boggling performance even higher to 135dB dynamic range and -120dB THD.
The Sabre32 Reference DAC is available in two versions – the ES9018 8-channel DAC supports mono, stereo, 4- and 8-channel output modes, while the ES9012 2-channel DAC supports stereo output. Each part integrates an all-digital SPDIF receiver, supports digital audio in PCM or DSD formats, features click-free soft mute, volume control, de-emphasis, zero detect, customizable filter characteristics and consumes less than 100mW.
Robert Wong, vice-president of marketing and worldwide sales for ESS Technology, said, “The Sabre32 Reference DAC is a perfect companion for the emerging 32-bit audio content generated by music studios and DSP up-conversion. Together with other ESS Sabre32 and Sabre ADCs and DACs, audio enthusiasts can now enjoy music with performance never before possible. It is simply stunning.”
Both the ES9018 Sabre32 Reference 8-channel DAC and the ES9012 Sabre32 Reference Stereo DAC are sampling in 64-LQFP package and priced at $39 in quantities of 1000.
The Sabre32 Reference DACs will be demonstrated January 8 – 11, 2009 at the Consumer Electronics Show in Las Vegas at the Hilton. Appointments may be scheduled by calling Wendy Chafer at 510-492-1180.
Source: Click
Φυσικά το Heraklion Team του AVSite παρακολουθεί από την πρώτη μέρα το σχετικό thread στο diyaudio.com και κάποια μέλη του ακούν με τον προκάτοχό του εδώ και 4 μήνες.
Περισσότερα σε σχετικό thread γιατί από αυτά που βλέπω έχει μείνει πίσω το DIY community και ψωνίζει ακόμα κάτι τελειωμένα diy kit DACs από κινέζους και είναι κρίμα. :144:
Κώστας Φ.
To AVSite (παράρτημα Ηρακλείου - το κλουβί με τις τρελές), πάντα μπροστά, έχει ήδη (από τη Δευτέρα συγκεκριμένα) στα χέρια του 32άρι Sabre...
Οι πρώτες ακροάσεις του Buffalo 32S άφησαν τις καλύτερες εντυπώσεις - ακόμη και για εμάς που έχουμε συνηθίσει να ζούμε με τον ήχο ενός κορυφαίου DAC όπως το προηγούμενο Buffalo.
Κώστας Φ.
Ένα κακό έχει το 32S, πέρα από την τιμή του...
Δεν αφήνει παιχνίδι για δοκιμές/μετατροπές στο I/V στάδιο.
Οι πιο ανήσυχοι (και...υπερηχητικοί) φίλοι μας ας κάνουν κανένα δίμηνο υπομονή για το tweaker's board ή ας βγουν στο κυνήγι για το παλιό buffalo σε ξένα forums.
Η ηχητική υπογραφή είναι η ίδια και μακριά από τον ήχο των DAC "της σειράς" που έχουμε συνηθίσει να ακούμε.
Επίσης, κρίνοντας από τις θερμοκρασίες που ανεβάζουν τα opamps στα IVY II του 32S, μυρίζομαι bias σε τάξη Α.
Απάντηση: ESS Technology Announces Sabre32 Reference DAC
The OPA1632 does not have thermal shutdown
protection. Take care to assure that the maximum
junction temperature is not exceeded. Excessive
junction temperature can degrade performance or
cause permanent damage. For best performance and
reliability, assure that the junction temperature does not
exceed +125°C.
http://focus.ti.com/lit/ds/symlink/opa1632.pdf
κανονικά θέλει ψήκτρα, αλλιώς χρησιμοποιεί την πλακέτα (τις χαλκοδιαδρομές της γης) σαν ψήκτρες)
Πολύ καλή επιλογή πάντως....
Αλλη μια απορια ωρε παιδια!
H ρυθμιση του volume πως γινεται?
Με μπουτονς η με ποτενσιομετρο?
sorry για τις παραξενες ερωτησεις αλλα δεν εχω ασχοληθει με το αθλημα...
Thanks a lot man!
Επειδη εχω ακουσει πολλα καλα σχολια για αυτο το dac σκοπευω να το παραγγειλω. (ελπιζω)
Εκτος απο τα τροφοδοτικα και το volumite, θα χρειαστω τιποτε αλλο;
Για μετασχηματιστες φανταζομαι τοροειδεις θα ειναι μια χαρα...
connector για spdif για σασσι ας πουμε καμια γνωμη που μπορω να βρω;
Κώστας Φ.
Μετασχηματιστές πουλάνε οι ίδιοι κάτι κομμάτια της Avel Lindberg με τις σωστές τάσεις. Μπορείς να πάρεις από εκεί ή να ψάξεις στην εγχώρια αγορά για αντίστοιχους.
Βύσματα είναι εύκολο να βρεις.. Από eBay μέχρι Farnell - ανάλογα το budget και την ποιότητα (ή "ποιότητα" που θέλεις).
Αν θες οπτική είσοδο δες το αντίστοιχο module από Twisted Pear.
Mία άριστη και εύκολη λύση είναι το Volumite που δίνει η ίδια εταιρεία (η Twisted Pear).
Η ρυθμιση μπορει να γινει απο την πηγη (π.χ. απο τις επιλογες της motherboard) η απο το cd player?
Σε αυτην την περιπτωση κραταει μια σταθερη ενταση στην εξοδο (π.χ.επιπεδου line)
Και τι ειναι προτιμοτερο;
Kυριως η απορια μου ειναι αν ειναι απαραιτητο το volumite για να λειτουργησει το sabre 32s
Κώστας Φ.
Απαραίτητο δεν είναι..
Αν έχεις κάποιο προενισχυτή πριν τους τελικούς ή αν έχεις ολοκληρωμένο ενισχυτή ή αν ακούς από PC και παίζεις με το volume του player, δε σου χρειάζεται.
Aκριβως αυτο με ενδιαφερει να κανω (να ακουω απο pc και να ελεγχω την ενταση απο εκει).
Επειδη παρακολουθωντας τα post σου εχω σχηματισει την εντυπωση οτι εχεις εμπεριστατωμενη γνωμη για τον ηχο του συγκεκριμενου dac, πες μου σε παρακαλω την αποψη σου:
Ακουω απο το player marantz cd 63 kiss (αν το ξερεις γιατι ειναι λιγο παλιο), και ο ηχος του με ικανοποιει πολυ.
Απο το pc τωρα, απο την καρτα ηχου της asus- essence stx.
Λειτουργικο-vista ultimate.
Ο ηχος της ομως δεν συγκρινεται με αυτον του marantz.
Υπολειπεται σε ογκο και ελεγχο στα χαμηλα, ογκο-ζεστη και φυσικοτητα στα μεσαια και υψηλα, καθως και σε αναλυση.
Η ερωτηση ειναι οτι με το buffalo θα κερδισω ηχιτικα σε αυτους τους τομεις;
Μιλαω για τις ιδιες συνθηκες ακροασης.
Και παλι σε ευχαριστω
Thanks a lot man!
Τι εγινε ρε παιδια;
Τωρα που εγω αξιωθηκα και πηρα την prepaid στα χερια μου, τελειωσε το stock?
Εχει κανεις καμια πληροφορια;
Κώστας Φ.
Ναι, δυστυχώς.
Εντάξει, για τα δεδομένα της Twisted Pear κράτησε ΠΟΛΥ καιρό το "stock"..
Σε 3 εβδομάδες ξανά οι επόμενες προ-παραγγελίες.
  • loggeo
ΒΑΣΙΛΗΣ ΜΗΤΣΙΟΥ
