new audysssey for sub
για παμε τωρα που το μαγαζι φορτσαρει
για να δουμε.................
On Thursday, June 11, Audyssey CTO, Chris Kyriakakis and VP of Business Development, John Hallman will give our installers a sneak peek at our latest innovation in bass calibration.
The new component from Audyssey uses MultEQ Pro and works with any AVR. It is our first standalone product with an MSRP under $1,000 and is sure to be a hit with your customers, providing you a new revenue stream.
Audyssey customers and fans have been asking for this product and we are happy to present it to our installers first
θελετε φωτο ?
platon
Απάντηση: new audysssey for sub
Γιατι ομως μονο για σαμπ.............
γιατι υπαρχει και το κανονικο οντιτσι που τα κανει ολα.
τιμη κατω απο 1.000 δολαρια - καλα ειναι
θαναση 800 και τα εξοδα του εγκαταστατη
αλλιως αγοραζεις κιτ
και επειδη ειμαι πιο γρηγορος και απο τους αμερικανους
εδω εισαι
June 16, 2009 — Anyone with a home theater knows how difficult it is to integrate a subwoofer with the rest of the audio system. And if there's more than one sub, the problems are multiplied. Fortunately, these problems could be a thing of the past thanks to the latest product from Audyssey called the Sub Equalizer, which is scheduled to become available on July 1.
Based on the company's highly acclaimed MultEQ XT automatic room-correction algorithms found in many A/V receivers, the Sub Equalizer is actually a dedicated hardware box that applies MultEQ XT to the low frequencies. It can be used with any AVR or pre/pro to optimize the performance of one or two subs by first measuring the low-frequency response at up to 32 listening positions.
Typically, the bass response is all over the map as shown above due to room modes and time-domain problems. The Sub Equalizer creates an inverse profile based on thousands of correction points, which is far higher resolution than other EQs. Also, the analysis and correction are performed in the frequency and time domains, a combination not offered by other such products.
The result is exceptionally smooth, even bass throughout the room as shown above. Muddy and/or boomy bass is abolished, and previously lost deep bass is restored thanks to a frequency response down to 10Hz (±0.5dB). The unit works with one or two subs, setting the level and delay of each before equalizing them together to blend seamlessly with the main speakers.
The Sub Equalizer will be sold only through certified installers and requires the Audyssey installer's kit to set it up. Thus, it will not normally be sold to end users without having a professional technician configure it. List price is $800, not including the tech's time, and from what I've heard in demonstrations, it's money well-spent to get the best possible bass in your room.
platon
To opoio ειναι πολυ ακριβωτερο να υποθεσω?
ναι αλλα ειναι και 8καναλο
στα 3 χιλιαρικα
χωρις το κιτ του εγκαταστατη
Είναι στην ούσία αυτό το οποίο το έφτιξαν μαζί με την SVS http://www.lsound.no/index.php?side=info&group=499&subgroup=0&id=757839
και υπάρχει εδώ και μήνες διαθέσιμο. Απ'ότι βλέπω δεν υπάρχουν διαφορές στο τι παρέχει.
Το σκέφτομαι σοβαρά πάντως εκτός και αν καταλήξω σε Pro.
To λινκ που έβαλα για Ευρώπη είναι και είναι το ίδιο με το δεύτερο που έβαλες.
τα 2 ικ μπορω πλεον να τα τρεξω με το νεο φιρμγουερ του οντισι
πληροφοριες ερχονται
  • n_olympios
    Μαντιναδόρος!
antavent
