Musical Fidelity Titan
Κώστας Φ.
  • Description: Solid-state, two-channel, fully balanced power amplifier with standalone power supply.
  • Maximum power output: 1kWpc into 8 ohms (30dBW), 2kWpc into 4 ohms (30dBW), "just short of" 4kWpc into 2 ohms (30dBW).
  • THD+noise:<0.008%, 20Hz–20kHz. Signal/noise:>126dB, A-weighted (no reference level quoted).
  • Intermodulation distortion: not specified.
  • Maximum output voltage: 90V RMS, 20Hz–20kHz; 254 peak–peak.
  • Peak output current: limited to 100A peak–peak.
  • Frequency response: 20Hz–40kHz,–0.5dB.
  • Input impedance: 100k ohms (balanced, unbalanced).
  • Input sensitivity for full power out into 8 ohms: 3V.
  • Damping factor: 250.
  • Dimensions: Amplifier: 19" (483mm) W by 7.3" (185mm) H by 25" (635mm) D. Weight: 99 lbs (45kg). Power supply: 19" (483mm) W by 7.3" (185mm) H by 24.5" (615mm) D. Weight: 150 lbs (68kg).
  • Price: $30,000. Approximate number of dealers: 70. Warranty: 5 years parts & labor.
Κώστας Φ.
Conclusion
Once you've experienced and lived with a mega-amplifier, whether tubed or solid-state, it's difficult to return to one of moderate power—and by moderate I mean even a few hundred Wpc—especially if your goal is to reproduce without strain the dynamic range of live orchestral performances, or even the SPLs of rock concerts, where dynamic swings tend to be somewhat narrower.
There need be no tradeoff between delicacy, sure-footedness, and precision and power, though some audiophiles insist that that's unavoidable, based mostly on conjecture and/or conventional wisdom. Play at low volume Musical Fidelity's Titan or kW, or some other modern high-powered amplifiers, and they won't sound sluggish or confused. Play them at high SPLs and ask them to deliver wide dynamic swings, and without complaint they'll do that too.
For reasons I can't explain, a high-powered amplifier loafing along sounds more relaxed, more in control, more musically involved and involving, than a low-powered one, even when the latter is operating within its power envelope. The big amps produce a sense of scale that the small ones simply can't. Convincing lovers of single-ended-triode amps and single-driver speakers of any of this is impossible, but in my book they're a lost cause anyway. I understand the attraction of such systems, but not if the goal is full bandwidth and the realistic reproduction of large-scale dynamic swings.
And if that's what you want, and you have the money and the space, big is beautiful. With the kW, Musical Fidelity joined the league of mega-power amplifier manufacturers with a product that was physically less than refined and, for some, was sonically as well. As a revealing reviewer's tool, it couldn't be beat, but it's easy to understand why some shoppers hesitated.
With the new Titan, Musical Fidelity becomes a player in the top echelon of makers of luxury, high-powered amplifiers. The $30,000 Titan is physically and sonically distinguished. Its build quality is impressive by any standard, and sonically, the Titan's combination of smooth refinement, aggressive grip, and silky transparency effectively bridges the gap between the sounds of tube and solid-state.
--Michael Fremer
The amplifier is specified at 1kWpc into 8 ohms (30dBW); I measured its power at clipping (1% THD) with one channel driven as 1050W (30.2dBW). The AC wall voltage, which had measured 125.7V with the Titan idle, at this point dropped to 122.4V. When the amplifier clipped at 1700W into 4 ohms with one channel driven (29.3dBW), the wall voltage fell to 119V. Into 2 ohms with one channel driven, the Titan clipped at 2.2kW (27.4dBW), and the wall voltage was now 116V. I had the amplifier plugged into a single 20A circuit for the tests, meaning that with both channels driven, the AC voltage would have dropped more and the amplifier's power delivery at clipping would be lower. But if you could manage it so that each of the Titan's channels was plugged into a separate AC circuit—easily done, as each has its own 20A IEC cord—you would get a maximum power delivery from each channel comparable to what I measured from just one.
Despite its enormous output power and dynamic-range capability, Musical Fidelity's Titan offers measured noise and distortion more typical of a high-quality preamplifier than a power amplifier. Technically, this is an extraordinary amplifier.
-- John Atkinson
Full Review: Stereophile.com
Κώστας Φ.
Tα μετασχηματιστάκια που βλέπετε στο σασί της τροφοδοσίας είναι 3kV το καθένα...
Απάντηση: Musical Fidelity Titan
ενας απο τους λιγους τραντζιστορατους ηχους που συμπαθω, ειναι και ο ηχος αυτης της εταιριας.
αλλωστε προσφατα αποκτησα δυο μονομπλοκ της.
Re: Απάντηση: Musical Fidelity Titan
Ρε Θανάση μας δουλεύεις? Εδώ δεν έχεις καλώδια και αγοράζεις συνέχεια τελικούς και ηχεία? :136:
Εγώ πάντως είχα ένα συλλεκτικό Musical Fidelity Nuvista, αν και τον αγάπησα πολύ γιατί ήταν ο πρώτος μου "σοβαρός" ενισχυτής - ήταν μεγάλο χρέπι τελικά. :142:
Χρεπι o nuvista θα σε πάρουν με τις ντομάτες ,
Το μηχάνημα ήταν αναφοράς τότε , με τι ηχεία άκουγες?
"Once you've experienced and lived with a mega-amplifier, whether tubed or solid-state, it's difficult to return to one of moderate power—and by moderate I mean even a few hundred Wpc—especially if your goal is to reproduce without strain the dynamic range of live orchestral performances, or even the SPLs of rock concerts"
τά'λεγε ο Κωσταυτιάς, δε τά'λεγε?
βαρέθηκε να τα λέει...
κι ορμούσανε διάφοροι να λεν "τη τη θες τόση ισχύ" κι "άχρηστη είναι"...
που θα πάει, θα καταλάβουν κι αυτοί κάποτε....
την ισχύ πολλοί εμίσησαν, την ΠΟΛΥ ΙΣΧΥ ΟΥΔΕΙΣ!
Ζήτω τα κιλοβάτ ρε!
Ζήτω!
Απάντηση: Re: Musical Fidelity Titan
30 χιλιαρικα ομως - ειναι πολλα τα λεφτα αρη
ναι ρε συ, αλλά στα ίδια ή και περισσότερα λεφτά κυκλοφορούν κάτι πορδές των 8 βαττ ή των 100... και πρόσεξε: πουλάνε οι πορδές! κάποιοι τις αγοράζουν! φάκιν ανμπιλίβαμπλ...
για μας τους "χαμηλότερης οικονομικής επιφάνειας" - "κοινούς θνητούς" η λύση των παλμοενισχυτικών βαθμίδων ισχύος είναι μονόδρομος, καθαρά και μόνο λόγο κόστους και χωρίς ουσιαστικό συμβιβασμό στην ποιότητα, αν και είναι ευνόητο πως το ακριβότερο μπορεί - αν σχεδιαστεί και υλοποιηθεί σωστά - να παίζει και καλύτερα, αλλά αφού δε το "φτάνουμε", ε, δε το συζητάμε κιόλας. Αλλιώς όλοι θα είχαν ένα ζευγάρι ΤELOS !
Απάντηση: Η ισχύς στην υπηρεσία του λαού...
Σύμφωνα με την προσφιλή τακτική της εταιρίας,αναμένεται σε δύο χρόνια η ΄΄ολοκληρωμένη΄΄ εκδοχή βασισμένη στην κυκλωματική διάταξη του Τιτάνα,με σημαντικά μικρότερη τιμή.Όσο γιά την κατανάλωση,τα κιλά και τα κυβικά...τα ηλεκτρικά όνειρα του Αντώνη Μιχαηλίδη είναι μάλλον...κλάσης Δέλτα.:144:
Εσύ θα μας τρελάνεις! Για πες...
ενα σετ απο τους 550Κ αυτης της σειρας
πριν λιγες μερες οταν σας ελεγα οτι μπορουσα να παρετε τον ηχο απο τους SE DARED και να οδηγησω τα Αναλυσις σχετικα ανετα, αυτο εννοουσα - απο τον προ στους SE τελικους και απο εκει, απο την εξοδο ηχειων τους, στην εισοδο ηχειων των 550Κ
http://www.stereophile.com/solidpoweramps/907mf/
μολις τελειωσω με τα μηχανηματα, θα παω να κλεψω ετοιμη την καλωδιωση του ARGI
Κώστας Φ.
Kαλορίζικα Θανάση!
Θέλω να δω το σαλόνι σου.. Με αυτούς τους ρυθμούς σε κανένα χρόνο θα ακούς από την πόρτα γιατί δε θα χωράς να μπεις μέσα!
Το θυμάμαι ότι αυτό ισχυριζόταν η MF όταν έβγαλε τα superchargers.
Στην πράξη πώς τα πάνε;
:143:
κατα 70% κανει αυτο που υποσχεται, εισαγει ομως και στο υπολοιπο ποσοστο την δικη του υπογραφη, που εμενα δεν με ενοχλει, μιας και δινει λιγο παραπανω ογκο χαμηλα. Αυτο που προσφερει παντως απλοχερα - πιθανον λογω της ισχυος του - ειναι σαφως τα πολυ καλυτερα δυναμικα του.
Σαν σταντ αλον τελικος ενισχυτης ειναι πολυ καλος με την ογκΩδη μεσαια περιοχη που μου θυμιζει καπως λαμπα, μαλακα πριμα με ελαχιστη ελλειψη σε αυτην την περιοχη και ογκωδες χαμηλο, αν και υπολειπεται ελαφρως σε ελεγχο με απολυτα κριτηρια, οπωσδηποτε παντως καλυτερο ελεγχο απο εναν μεσο ενισχυτη λαμπας σε αυτην την περιοχη. Θα ελεγα οτι ηχητικα θυμιζει πολυ τον ηχο των ANTHEM.
Η στερεοφωνικη εικονα ειναι καλη - ενω συνδεομενος με τον προ της DARED MC7, εδωσε την καλυτερη ηχητικη του αποδοση, με αυξηση των υψηλων και καλυτερη στερεοφωνικη εικονα τοσο σε βαθος, οσο και πλατος, αποτι οταν οδηγειτο κατευθειαν απο την μεταβλητη εξοδο του DROPLET CD.
Τελος οδηγουμενος απο την εξοδο ηχειων των DARED εδωσε εναν ουδετερο ηχο με πολυ γλυκα και παχυνση στα οργανα και τις φωνες, που εμενα μου αρεσε σε καποιους αλλους ισως οχι. Επισης συνδεομενος με την εξοδο ηχειων του MCINTOSH MC275, εδωσε κατα 90% τον ηχο του - ταιριαξαν φαινεται τα ηχητικα χαρακτηριστικα τους, με τις υψηλες να ειναι ενα τι ακομα πιο μαλακες αυτην την φορα
Κώστας Φ.
Ωραίος Θανάση!
Είχα διαβάσει διάφορους να κάνουν "παράπονα" ότι αφήνει την υπογραφή του στο σύστημα που θα μπει αλλά αυτό δεν είμαι καθόλου σίγουρος αντικρούει τα όσα λέει η MF..
Eίναι λογικό να αλλάζει ο ήχος εφόσον έχεις καλύτερη οδήγηση.
Καλές ακροάσεις!
  • loggeo
Manosmathiou
