Cerious Technologies, React 1 - Του carbon fiber το κάγκελο!
Κώστας Φ.
"Everyone 'knows' two things when it comes to loudspeakers - that the enclosure must trap and absorb the rear wave of each driver and that the cabinet should be made of something inert to not vibrate. The problem is that these two things are mutually exclusive. If the enclosure is inert and dead, it cannot absorb energy which is its primary function. Stuffing foam inside is a lesson in self denial. Cerious Technologies chose a different path. We chose to design an enclosure that actually dissipates energy.
"Cerious Technologies introduces the React series of loudspeakers. The React 1 [$9,750/pr with stands] are constructed of 66 hollow carbon fiber rods for an incredibly light and rigid enclosure. The true breakthrough lies in the reactive ceramics that fill each rod. When the rods experience vibration, the ceramics within each tube counteract this energy, thus eliminating it.
"The center of each vented enclosure employs a spine of pure stainless steel. Within this steel tube is housed a Mass Damper System capable of neutralizing vast amounts of low frequency energy.
For drivers, the React 1 employs a proprietary 7-inch composite ceramic cone woofer mated to a 1-inch Illuminator tweeter. The 1st-order crossover at 3.7kHz contains only three elements, speaker sensitivity is 89dB, impedance a linear 6 to 8.5 ohms between 50Hz and 22kHz (F3 is 43Hz when mounted on the integral included 26" stands). Each React 1 measures 17” tall, 10½” wide, and 12¾” deep. The weight is 37 pounds each with the Mass Damper System installed. The integral stands are 26” in height and consist of a central 3” diameter carbon fiber tube to be filled with sand or steel ball bearings to add weight.
Choices of wood dowel finishes include Zebrawood (pictured), Bubinga and Cocobolo while the main speaker enclosure is black."
6moons.com
Απάντηση: Cerious Technologies, React 1 - Του carbon fiber το κάγκελο!
Επιτέλους και κάτι διαφορετικό, οι MDF φτηνιαδούρες με εχουν κουράσει...
Άραγε γιατί τα πλευρά έχουν αυτό το παράξενο σχήμα βιολοντσέλου η ακορντεόν; (Πάντως έρχονται δεύτεροι!).
:105:
Απάντηση: Re: Cerious Technologies, React 1 - Του carbon fiber το κάγκελο!
:105:
ποιοι ειναι πρωτοι?
:105:
Τρίτοι, μη σου πω τέταρτοι... :105:
Re: Απάντηση: Re: Cerious Technologies, React 1 - Του carbon fiber το κάγκελο!
ποιοι ειναι πρωτοι?
Oι Κινέζοι! (Εγώ τουλάχιστον το πρωτοείδα στην CAV, που έλεγε στο site της, ότι το σχήμα βιολοντσέλου μειώνει δραματικά τους συντονισμούς/χρωματισμούς στο md-x3. Φυσικά όταν το ανέφερα στο σχετικό thread που έχω ανοίξει, αντιμετώπισα την έντονη αμφισβήτιση). Και μάλιστα όχι σε απομίμηση κάποιου άλλου προϊόντος, αλλά σε Γνήσιο Κινέζικο πρώτυπο δημιούργημα.
:108:
[youtube]Xz2AFNFI-WY&feature=related[/youtube]
:612:
Απάντηση: Re: Απάντηση: Re: Cerious Technologies, React 1 - Του carbon fiber το κάγκε
:108:
τα πιστεύεις αυτά που γράφεις?
έχεις ακούσει το συγκεκριμένο ηχείο σε συγκριση με κάποιο άλλο Ευρωπαικό στον ίδιο χώρο και διαπίστωσες ότι έχει λιγότερους συντονισμούς/χρωματισμους?
εαν σε ενδιαφλερουν πραγματικά τα Κινέζικα κοίτα κάτι σε Aurum Cantus (ή κάπως έτσι...)
deleted user 10898
παιδια συγγνωμη, που ειπαμε οτι τα ακουμε αυτα?
(θυμαστε ε ψαχνω ηχεια βασης.... καθενας με τον πονο του....)
εντιτ: ta aurum cantus ενοω...
Πολυ χρησιμα τα ανθρακονηματα και μονο 32000 $. Μπορεις να τα κουβαλας και να τρεχεις πραγματικα γρηγορα.
deleted user 10898
Βρε ελα να σε βαλω να πηγαινεις τα μαρτιν λογκαν εμπρος πισω οπως κανω εγω (που θα παει θα τα παρω τα βιβλιοθηκης...) και σου λεω πως να εκτιμας τα ανθρακονηματα μετα....
Re: Απάντηση: Re: Απάντηση: Re: Cerious Technologies, React 1 - Του carbon fiber το κ
To τι πιστεύω και το τι αγόρασα υπάρχει εδώ:
http://www.avsite.gr/vb/showthread.php?t=53397
:107:
http://www.avmentor.gr/aurum_cantus_in_greece.htm
Δεν τα έχει εμφανίσει όμως ακόμα:
http://www.auditorium.gr/index.php
αλλά take a look:
http://www.auditorium.gr/index.php?show_page=100
σ αυτά τα βάσης(δεν τα έχω ακούσει)
Eπι πλέον, στο site της Αurum Cantus δεν μπόρεσα να διαπιστώσω ποιό έχει το επίμαχο σχήμα, (βιολοντσέλου). Ποιό είναι;
:121:
οκ caravelle το μελος voria proastia ενημερωθηκε για τα φρονηματα σου... :139:
Φίλε VET το έτσι: :139: σε συνδυασμό με το: "φρονήματά σου" σου το επιστρέφω!
:107:
Ουφφφφ, ζέστη απόψε...
  • loggeo
panaplio
