Atlantic Technology : Νεα επαναστατικα ηχεια
Πιστευατε ποτε οτι μια καμπινα περιπου 40 λιτρα, 2 drivers 4 1/2 ιντσες και ενα tweeter μπορουν να κατεβουν εως 29 Hz (-3dB) και να δωσουν 105 dB ?
Με αυτα τα υλικα και την επαναστατικη τεχνολογια H-PAS, η Atlantic Technology ανοιγει νεους δρομους στη φιλοσοφια κατασκευης και αποδοσης των ηχειων.
Η τεχνολογια H-PAS, που αναπτυχθηκε με τη συνεργασια μιας αλλης μεγαλης εταιρειας, της Solus/Clements, συνδυαζει στοιχεια της τεχνολογιας bass reflex, inverse horn, and transmission line, και μια μοναδικη σχεδιαση της καμπινας.
Θα παρουσιαστει σε λιγες μερες στην CEDIA 2009 και μεσα στο επομενο τριμηνο θα εχουμε και τα πρωτα ηχεια παραγωγης.
The new patent-pending system, called H-PAS™, (Hybrid Pressure Acceleration System), combines elements of several speaker technologies: bass reflex, inverse horn, and transmission line. Using a unique cabinet design, these technologies are cascaded one to another to pressurize and accelerate low frequencies. In addition, the signals travel through a passive resonance/harmonic distortion line filter. The final result is the ability of an H-PAS design to deliver extended deep bass with exceptionally low distortion.
H-PAS does not require the use of special drivers, any kind of on-board electronics or outboard equalization -- it is a purely passive system, completely compatible with all amplifiers and AV receivers.
The H-PAS demonstration model that will be on display at the CEDIA Expo utilizes two 4 ½-inch drivers in an enclosure of approximately 1.4 cubic feet to produce bass that extends to 29 Hz (-3dB) at Sound Pressure Levels that exceed 105dB. Bass harmonic distortion is under 3%. Comparable performance in a conventionally designed loudspeaker system would require bass drivers of at least triple the size in an enclosure at least twice as large.
“Until now, I would have considered it virtually impossible to achieve such high levels of bass performance and quality in such small enclosures," said Peter Tribeman, the president of Atlantic Technology.
"This new system," Tribeman continues, "is the first ever to break the famous Iron Law of loudspeaker design, which states: 'deep bass extension, compact enclosure, or good efficiency … pick any two at the expense of the third'. For the very first time, due to Phil Clements' breakthrough design, we can have them all.”
Περισσοτερα εδω : link
Οι μπαμπαδες του H-PAS, αριστερα ο Peter Tribeman, προεδρος της Atlantic Technology και δεξια ο Phillip Clements της Solus/Clements.
Το ηχειο θα κυκλοφορησει μεσα στο 2009 και η τιμη του στην Αμερικη θα ειναι γυρω στα $2.000 . Να δουμε τι τιμη θα δωσουν για την Ευρωπη....
Για το 2010 λεγεται οτι θα βγει και μια εκδοση με 6,5-αρια woofer.
Με το που θα το εχω στα χερια μου, θα οργανωσω μια παρουσιαση. Πιστευω οτι πολλοι απο σας θα θελατε να ακουσετε τι μπορει να δωσει αυτη η νεα τεχνολογια στο τομεα του ηχου και φυσικα η γνωμη σας μετραει. Αναμονη λοιπον...
Απάντηση: Re: Atlantic Technology : Νεα επαναστατικα ηχεια
Ειμαι σιγουρα μεσα !!!
Nick Arvanitakis
Audio Pro
Απάντηση: Atlantic Technology : Νεα επαναστατικα ηχεια
Αν ειναι και TL που ειναι το εσωτερικο του να το δουμε...
Εσωτερικο δεν δειχνουν ακομα, γιατι πουλανε τη πατεντα σε αλλες εταιριες.
Πριν την επισημη ανακοινωση και παρουσιαση στη CES 2010, αποκλειστικες φωτο του ετοιμου προιοντος και τεχνικα χαρακτηριστικα.
Atlantic Technology AT-1
Preliminary Specifications​
Type: H-PAS, 2-way
Woofers: (2) 5 ¼" (135mm) long-excursion GLH cone
Tweeter: 1 1/8” (28mm) low-resonance soft dome with 4mm oversize long-throw surround and integral back chamber/heatsink
Frequency Response: 29-20kHz, +/-3dB
Nominal Impedance: 6 ohms
Crossover Frequency:2kHz
Crossover Type
: Parallel, 2nd-order LP, 3rd-order HP
Sensitivity: 89dB
Recommended Amplifier Power: 20-200 Watts RMS
Dimensions: (W x H x D): 8 7/8 x 41 x 13 ¾" (227 x 1041 x 348mm) (Feet add another 1" to Height)
Weight: 54 lbs (24.6 kg) ea.
Link : Atlantic Technology Debuts Revolutionary AT-1 H-PAS™ Speaker at CES
Για να δούμε.. πολλά υποσχόμενο και ακριβώς γιαυτό είμαι συγκρατημένος.
Αναμένω ευκαιρία ακρόασης :201:
Μερικα νεα απο τη CES 2010.
Atlantic Technology showed its AT-1 H-PAS speaker first shown at CEDIA. The speaker uses a proprietary combination of passive technologies that produce impressive low frequency response. The demo included plenty of 32 Hz organ pedal stops that really shook the room.
( Secrets of Home Theater & High Fidelity )
One of the highlights of CEDIA 2009 was Atlantic Technology's announcement of H-PAS technology, which gets subwoofer-worthy bass out of a tower speaker. The prototypes shown then have developed into production models that are about to ship. First to ship will be the 5.25-inch tower; the 4.5-inch version may follow later in the year. With the inevitable pipe organ source material, the demo proved the ability of H-PAS to produce deep true bass sans sub. Phil Clements of Solus/Clements, father of H-PAS technology, weathers the media spotlight with good grace.
( Home Theater Magazine )
και η τιμη αυτων θα ειναι???
Ελα μου ντε....affordable but not cheap....διαβασα καπου.
Απο τον επομενο μηνα, ειναι πιθανο οτι θα εχουμε Ευρωπαικη τιμη και ημ/νια αφιξης.
Αναμεσα στα 2.000 και τα 3.000 το κοβω.
Νεα απο την ISE 2010 :
Τα ειδα, τα αγγιξα δεν τα ακουσα γιατι ηταν στατικα. Μερικες φωτο αυριο.
Τα καλα νεα ειναι οτι θα ερθουν γυρω στο Μαιο και απ οτι μου ειπαν θα παιξουν γυρω στις 2.500.
Σε παγκοσμια πρωτη :126: οι φωτογραφιες του AT-1.
Το τελικο προιον ειναι ετοιμο και αρχισε η διανομη του.
Ημ/νια αφιξης στην Ευρωπη και τιμες δεν εχω ακομα.
Car_Audio_Test
2πλό 5μισάρι με 29 Hz κατέβασμα είναι ενδιαφέρον. Πότε ακούμε?
  • loggeo
koskef
