Wyred4Sound STi1000
Κώστας Φ.
Η χάρη του ολοκληρωμένου ενισχυτή της Wyred4Sound έφτασε μέχρι το 6moons.
Conclusion.
Wyred4Sound has gone to great lengths to earn your business. They are offering near state-of-the-art technology and performance at mid-level prices. By any realistic definition, the STI 1000 is a bargain. The preamp will appeal to those looking for the “straight wire with gain” approach. It will not create warmth but convey it. The line stage alone would probably warrant the price of admission. The amplifier has virtually unlimited power and a high pedigree. If your loudspeakers are relatively sane loads, the sole caveat I have expressed will not apply and it will be happy to display its HighEnd credentials.
For years, serious hifi has traditionally meant separates. Wyred4Sound has challenged that preconception with a no-compromise single box solution which gives little ground to any separate dynamic duo (and made this proposition temptingly affordable). This is a serious effort and in the right system the STI 1000 will perform with a vengeance that belies its size. Powerful, efficient, musical - separation anxiety? Perhaps it’s time the masses embraced integration.
Easily recommended, the Wyred4Sound STI 1000 is sold Internet direct and through select dealers. See website for details.
Full Review: 6moons.com
Κώστας Φ.
Διαβάστε και το (επίσης θετικότατο) review του Β. Μαρκουλή για τον αντίστοιχο τελικό ενισχυτή εδώ.
Το πρώτο που έκανα ήτανε να δω ποιος (δεν ) ήτανε ο reviewer..:126::136::142:
Μετά πείστηκα και το διάβασα..
Απάντηση: Re: Wyred4Sound STi1000
τι ειναι το circuit breaker?
ασφαλειοδιακοπτης ειναι.
οταν πεταχτη εξω τον πιεζης και ξαναλειτουργη αλλα ειναι για
μεγαλες καταστροφες δεν πεταγεται οσο ευκολα καιγεται μια
ασφαλεια.
deleted user 10898
Even though I’ve spent a lot of time listening to Class D amplifiers, I will be the first to admit that a good Class AB amplifier such as the Pass still sounds more like live music than any Class D amplifier I’ve heard
avguide
Κώστας Φ.
Καλή φάση. Εγώ που δε θέλω να ακούσω live αλλά μόνο τι είναι γραμμένο στο δισκάκι καλά έκανα και πήρα Class D δηλαδή!
Κώστας Φ.
"...μέχρι που άκουσε τους συγκεκριμένους".
Κλασσικό κόλπο όταν δεν ξέρεις τι να γράψεις στην εισαγωγή.
Άλλωστε παρακάτω λέει:
Harmonically the Bel Canto Ref 1000 Mk II has a slightly warmer, more musical presentation then the Wyred 4 Sound SX 1000. The Bel Canto closely approaches the warmth and musicality of the Pass X150, with only a smidgen less richness in the upper bass and lower midrange.
και...
If you like the concept of an amplifier that is compact, efficient, powerful, transparent, musical, and extremely reliable, the Bel Canto Ref 1000 Mk II amplifier could be the last amplifier you’ll ever want or need. Hey, it’s worked for me.
deleted user 10898
τωρα μιλας σωστα.
για μενα η κριτικη αυτη ειναι πολυ θετικη.
παρολα αυτα ο pass x150 ειναι υποδεεστερος του pass x150.5 και κυριως του χα150.5.
αρα η συγκριση αυτη τοποθετει τους ψηφιακους σε σχεση με ενα γνωστο ονομα σε καλο επιπεδο αλλα οχι κορυφαιο.
Απάντηση: Wyred4Sound STi1000
ωστοσο ατομο που εχει τον pass xa250 και τον belcanto προτιμαη τον belcanto
deleted user 10898
Re: Απάντηση: Wyred4Sound STi1000
πες του να παρει τον χα250.5
πλακα κανω...
δεν λεω ποιος προτιμαει τι...
γουστα ειναι αυτα...
και εγω απο ice ακουω (ακουγα μαλλον)
απλως παραθεσα και μια αλλη γνωμη καποιου που εχει την δυνατοτητα της συγκρισης. οπωιος θελει την αξιολογει.
Κώστας Φ.
Wyred 4 Sound the best value for money!!
Να μας το αναλύσεις λίγο παραπάνω αυτό, σε παρακαλώ! :144:
Για όσους δεν θυμούνται, εδώ είχαμε ξεκινήσει μία ενδιαφέρουσα συζήτηση που ξεκίνησε από το ενδιαφέρον σου για τον Plinius και κατέληξε στα ρημάδια τα "ψηφιακά" (δηλώνω ένοχος για το post #16 αλλά οφείλει να τιμωρηθεί και ο CostasEAR ως ηθικός αυτουργός!)...
Για πες λοιπον... :126:
Υπαρχει καποιος φθηνοτερος αυτης της τεχνολογιας?(icepower)?
roque
