ΌΛΕΣ ΟΙ 1920Χ1080 LCD TV 37'' - 42''
Χρήστος Ακρατόπουλος
1. 37''
AMOI LC37A1E
http://www.avsite.gr/smf/index.php?topic=9584.0
http://www.amoi.com/product/products_detail_features.asp
1080p
Features:
- 37 inch 16:9 LCD TV
- 1920 x 1080 HD resolution
- 550 cd/m² panel brightness
- 1000:1 contrast ratio
- 8 ms quick response time
- 176 degrees wide viewing angle
- Dual Tuner PIP/PBP/POP functions
- Fasttext with 1000pages memory*
- HDMI/DVI interface with HDCP copy protection
- DCTi/DLTi & FTC (Flesh Tone Correction)
- V-Chip and CCD function*
- TV system: PAL/SECAM/NTSC*
- Power supply: AC 100V-240V
- Compatible to wall mount bracket
- 3 Scart sockets*, S-Video input, VGA socket, PC audio input
- Optional:
- USB+CF/SD card reader
MP3/WMA/JPEG/MPEG1/MPEG4 (Divx) stream media compatible
ΤΙΜΗ ΣΤΗΝ ΕΛΛΑΔΑ 1800 ΕΥΡΩ
Grundig LXW 94-8640
http://www.avsite.gr/smf/index.php?topic=14507.0
http://www.grundig.com/index.php?id=846&pid=989
1080i
* 37” (94 cm) Active Matrix TFT LC display with HD Evolution and a Full HD resolution of 1920 x 1080 – corresponding to 6.22 million colour pixels
* Innovative high-speed panel with a reaction time of max. 8 ms
* Digital Reference Plus II technology for picture optimization
* Luminous density 500 cd/m2
* Dynamic contrast ratio 2,600:1
* 178° viewing angle (horizontal/vertical)
* Ready for HDTV, including HDCP copy protection via HDMI
* Magic Fidelity sound system and Virtual Dolby® Surround for captivating sound
* Self-explanatory, convenient Easy Dialog user menu
* 2 HDMI inputs (1 x via DVI/HDMI adapter). 2 x SCART (2 x RGB-compatible), YUV sockets (Progressive Scan)
* Dimensions: approx. 96.3 x 70.7 x 14 cm (27.5 cm with pedestal)
* Weight: approx. 29 kg
* Available from 10/2006
ΤΙΜΗ ΣΤΗΝ ΓΕΡΜΑΝΙΑ 1900 ΕΥΡΩ
SHARP Aquos LC-37 XD1E
http://www.avsite.gr/smf/index.php?topic=14510.0
http://www.sharp.de/php/p.php?par=18_no_no_1300
1080p
# 16:9 Advanced Super View Black TFT LCD-Panel mit voller HD Auflφsung
# DVB-T Tuner und Analog Tuner
# Helligkeit 450 cd/m²
# Reaktionszeit 6ms
# Blickwinkel 176°
# Kontrastverhδltnis 1.200:1
# truD Bildverbesserung
# 2 x HDMI Eingang mit HDCP
ΤΙΜΗ ΣΤΗΝ ΓΕΡΜΑΝΙΑ 2000 ΕΥΡΩ
Toshiba 37 WL 67 Z
http://www.toshiba.de/consumer/content/defaultid1_1_id2_2_id3_8_id4_5.aspx
http://www.avsite.gr/smf/index.php?topic=14508.0
1080i
* 37" - 94cm LCD Panel
* 1920x1080 Full HD Panel
* HD Ready
* Helligkeit 500 cd/m²
* SRS-WOW Surround Sound
* 2 HDMI Anschlüsse
* Betrachtungswinkel: 176°
* Reaktionszeit: 8 ms (37WL67P: 6,5ms)
* PIXEL PROcessing III+
* 3D Colour Management
* Gesamtmusikleistung 2 x 25 W
* Top Videotext (1300 Seiten)
* Eingänge: 2 x HDMI inkl. HDCP, 2 x Scart, Video (Cinch), 3 x Audio (Cinch), Komponenteneingang, PC Eingang
* Ausgänge: Audio (Cinch), Video (Cinch), Kopfhöreranschluss (3,5 mm Klinke)
Anschlüsse:
Eingänge: 2x Scart (1x RGB/1x S-VHS/2x AV)
S-VHS (Hosiden) über Scart 2
Video (Cinch) / 3x Audio (Cinch)
Komponenteneingang - YUV (480p/480i/576p/576i/720p/1.080i)
2x HDMI / HDCP (480p/480i/576p/576i/720p/1.080i)
PC Eingang
Ausgänge: Audio (Cinch) fest/regelbar
Video (Cinch)
ΤΙΜΗ ΣΤΗΝ ΓΕΡΜΑΝΙΑ 1600 EURO
PHILIPS 37PF9731D/10
http://www.consumer.philips.com/con...&proxybuster=M3HSKBGEAMK2HJ0RMRESHQNHKFSEKI5P
1080i
Εικόνα/Οθόνη
Λόγος διαστάσεων : 16:9
Φωτεινότητα : 550 cd/m²
Αντίθεση δυναμικής οθόνης : 6000:1
Χρόνος απόκρισης (τυπικός) : (BEW ισοδύναμο) 3 ms
Οπτική γωνία : 176º (H) / 176º (V)
Μήκος διαγωνίου οθόνης (ίντσες) : 3" ίντσα
Μήκος διαγωνίου οθόνης (μετρικό) : 94 εκ.
Τύπος οθόνης : LCD True HD W-UXGA Act. matrix
Ανάλυση οθόνης : 1920x1080p
Βελτίωση εικόνων : Pixel Plus 3 HD, Υποβίβαση κίνησης(Pull-Down) 3/2-2/2, Τρισδιάστατο κτενοειδές φίλτρο 3D, Active Control + Αισθητήρας φωτός, Clear LCD, Ψηφιακή τεχνολογία Natural Motion, Βελτίωση δυναμικής αντίθεσης, Jagged Line Suppression, Προοδευτική σάρωση, Pulse Killer Chip, WideScreen Plus
Βελτίωση οθόνης : Αντιανακλαστική επικάληψη οθόνης
Χαρακτηριστικά Ambilight : Ambilight Surround, Δυνατότ αυτόμ προσ σε περιεχ βίντεο, Αποτελεσμ. λυχνία χαμηλής ενέργειας
Ρυθμίσεις χρωμάτων : Πολλά χρώματα
Λειτουργία αχνού φωτισμού : Χειροκίνητος - μέσω αισθητήρα φωτός
Υποστηριζόμενη ανάλυση οθόνης
Φορμά Η/Υ : 640 x 480, 60Hz, 800 x 600, 60Hz, 1024 x 768, 60Hz
Φορμά βίντεο : 640 x 480i - 1Fh, 640 x 480p - 2Fh, 720 x 576i - 1Fh, 720 x 576p - 2Fh, 1280 x 720 p - 3Fh, 1920 x 1080i - 2Fh
Ισχύς εξόδου (RMS) : 2x15W
Βελτιώσεις ήχου : Ψηφιακή επεξεργασία σήματος, Δυναμική βελτίωση μπάσων, Equaliser γραφικών
Σύστημα ήχου : Virtual Dolby Digital
Ενσωματωμένα ηχεία : 4
Τύποι ηχείων : Ενσωματωμένα γούφερ με τεχνολογία wOOx, Θολοειδή τουίτερ
Digital Content Management : Ανάγνωση ψηφιακών μέσων
Τύποι κάρτας μνήμης : Compact Flash τύπου I, Compact Flash τύπος ΙΙ, Memory Stick, Microdrive, Κάρτα πολυμέσων (MMC), Κάρτα Secure Digital (SD), Κάρτα Smart Media
Συνδέσεις πολυμέσων : Ethernet-UTP5, UPnP, WiFi (προαιρ. γέφυρα Ethernet), Συσκευή ανάγνωσης καρτών μνήμης 7 σε 1, USB (δυνατότητα βίντεο ροής)
Φορμά αναπαραγωγής : MP3, Αρχεία προβολής slide (.alb), Ακίνητη εικόνα JPEG, Divx 3.11, Divx 5, MPEG1, MPEG2, MPEG4, XviD
Δέκτης/λήψη/μετάδοση
Είσοδος κεραίας : Ομοαξονική 75 ohm (IEC75)
Σύστημα τηλεόρασης : DVB COFDM 2 K/8 K, PAL, SECAM
Αναπαραγωγή βίντεο : NTSC, SECAM, PAL
DVB : Επίγειος δέκτης DVB *
Υποδοχή scart 1 : Ήχος L/R, Είσοδος/έξοδος CVBS, RGB
Υποδοχή scart 2 : Ήχος L/R, Είσοδος/έξοδος CVBS, RGB, Y/C
3 εξ. : YPbPr
Ext 4 : HDMI
Ext 5 : HDMI
Ext 6 : VGA PC-in, Είσοδος ήχου L/R
Μπροστινές / πλαϊνές υποδοχές σύνδεσης : Είσοδος ήχου L/R, Είσοδος CVBS, Έξοδος ακουστικών, Είσοδος S-Video, 2x USB, Memory card reader πολλών υποδοχών
Άλλες συνδέσεις : Αριστερή/δεξιά αναλογική έξοδος ήχου, Ethernet, Είσοδος S/PDIF (ομοαξονική), Έξοδος S/PDIF (ομοαξονική), Κοινή διασύνδεση
ΤΙΜΗ ΣΤΗΝ ΕΛΛΑΔΑ 3500 EURO
BENQ VL3735
http://www.avsite.gr/smf/index.php?topic=14519.0
http://www.benq.com/products/LCDTV/?product=904
1080p
Screen Size 94cm/37"
Aspect Ratio 16:9
Brightness 550 nits
Contrast Ratio 1200:1
Response Time 8 ms
Viewing Angle 176/ 176
Resolution
1920x1080
Display Compatible 480i / 480p/ 720p/ 576i/ 576p/ 720p/ 1080i/ 1080p(HDMI)
Broadcasting System NTSC/ PAL/ SECAM
Speakers 10Wx2
Video Features
Senseye Technology: Yes
10 Bit color processing: Yes
Aspect Ratio Adjustment: 4:3/ 16:9/ Letter box/ Wide/ Real
Picture Modes: Cinema/ Dynamic/ Standard/ Personal
Sharpness Enhancement: Yes
Low Angle Modle: Yes
De-Interlacing: Motion Adaptive
3D Y/C Comb Filter: Yes (3D)
Auto Contrast Enhancement: Yes
Noise reduction: Yes
Audio Features Sound Effect: Virtual Dolby Sound
Other Features PIP/PBP: PIP
Personal Setting: 1
Picture Freeze: Yes
Sensi-Light Sensor: Yes
Swivel View: Yes
Connector Auto Detection: Yes
Soft Mute: Yes
Backlight Eco Mode: Bright/ Normal/ Dark/ Auto
Color temperature: Warm/ Cool/ Standard
Sleep Timer: 0, 30,60,90,120,150,180
PC Mode Horizontal Frequency: 31.5 ~ 60 KHz
Vertical Frequency: 50 ~85 Hz
DPMS: Yes
Image Auto Setting N/A
Horizontal Frequency 31.5 ~ 60 KHz
Vertical Frequency 50 ~85 Hz
Input Terminals Composite AV (Video+L/R): 2 (Rear x1 + Side x1)
S-Video: 2 (Rear x1 + Side x1)
Scart: rear x 2 (Full, Half)
Component (Y Pb Pr / Y Cb Cr) + Audio: 2
Analogue TV Tuner: 1
D-Sub: 1
DVI: Thru HDMI
HDMI: 1
PC Audio: 1
RS 232: Through D-sub
Output Terminals
Headphone: 1 at side
Audio Out: L/R
Dimensions Dimension with Stand (W x H x D mm): 970x748x295
Dimension w/o Stand (W x H x D mm): 970x697x122
Weight Weight (with stand, Kg): 27.6
Weight (without stand, Kg): 23
ΤΙΜΗ ΣΤΗΝ ΓΕΡΜΑΝΙΑ 1950 EURO
2. 40''
SONY KDL-40X2000
http://www.sony.gr/view/ShowProduct...w_el_GR&pageType=Overview&category=TVP+LCD+TV
http://www.avsite.gr/smf/index.php?topic=14509.0
1080p
* Τηλεόραση LCD 40" BRAVIA Χ-series
* Ενσωματωμένος ψηφιακός τηλεοπτικός δέκτης (λαμβάνει και αναλογικό σήμα)
* Οθόνη LCD ανάλυσης1920 x 1080
* Οθόνη LCD υψηλής απόδοσης
* Δυνατότητα 1080p μέσω HDMI
* Οπίσθιος φωτισμός WCG-CCFL
* BRAVIA Engine EX
* Live Colour Creation
* HD Ready με 2 υποδοχές HDMI
* Υποστηρίζει σήματα 1080p
* Ψηφιακός ενισχυτής ήχου
* Dolby Virtual (Prologic II) και BBE Digital
* Τεχνολογία BBE® για καθαρό και ευκρινή ήχο
* PIP Freeze για πάγωμα των σημαντικών σκηνών
* High Definition Multimedia Interface (HDMI™)
* Είσοδος σύνδεσης σε υπολογιστή για χρήση ως οθόνη υπολογιστή
* "Διαχρονικός" μεταβλητός σχεδιασμός
* Ανταλλακτικά έγχρωμα πλαίσια (δεν περιλαμβάνονται) - Μαύρο, Μπλε, Κόκκινο, Καφέ, Λευκό
* Μη αντανακλαστική επικάλυψη για οθόνες τηλεόρασης
* Δυναμική αντίθεση 7000:1
* Συμβατό με διάκενο οπών VESA
ΤΙΜΗ ΣΤΗΝ ΕΛΛΑΔΑ3000 ΕΥΡΩ
SAMSUNG LE-40F71B
http://av.samsung.de/article.asp?artid=5167D296-3F7F-41FE-9507-583155AEBD5B&show=specs
1080p
Bildschirmgröße
101 cm, TFT-LCD mit Super PVA-Technologie
Bildformat
16:9
Auflösung
Full-HD Auflösung (1920 x 1080)
Helligkeitswert
500 cd/m²
Kontrastverhältnis
Dynamische Kontrasteinstellung: 6.000:1
Funktionen
Erweiterter Farbraum WCG
(127 % der PAL-Norm)
Automatische Helligkeitseinstellung
DNIe (Digital Natural Image Engine)
Digitaler Kammfilter
Reaktionszeit 8 Millisekunden
Betrachtungswinkel 178°/ 178°
Bild-im-Bild Funktion (1 Tuner: PC- oder HDMI-Quelle erforderlich)
5 Farbtemperatureinstellungen (Kalt2, Kalt1, Normal, Warm1, Warm2)
4 Bildmodi (Dynamisch, Standard, Film, Benutzerdefiniert)
4 Bildformate: 16:9, Autobreit, 4:3, Zoom
Standbildfunktion
Ton
usikleistung
RMS 2 x 10 Watt
Funktionen
Nicam/A2 Stereo
SRS Tru Surround XT
5 Tonmodi (Standard, Musik, Film, Sprache, Benutzerdefiniert)
Sound Equaliser
Automatische Lautstärkeanpassung
2 x Digitaler Bildeingang (HDMI mit HDCP)
USB-Anschluß
Multi-Memory Slot (10 in 3)
DVI-Audioeingang (Cinch-Anschlüsse)
Komponenteneingang
2 x SCART-Anschlüsse:
AV-1 (FBAS, S-Video, RGB)
AV-2 (FBAS, S-Video)
PC-Anschluß (D-Sub)
PC-Audioeingang
Antennenanschluß
Serviceanschluß (nur für Kundendienst)
Seitlich
1 x FBAS
1 x S-Video
1 x Kopfhöreranschluß
Allgemein
Abmessungen
(BxHxT) in cm
99,4 x 64,7 x 9,2 ( ohne Standfuß)
99,4 x 69,6 x 29,0 ( mit Standfuß)
111,0x83,5x37,5 (Verpackung)
Gewicht
TIMH ΣΤΗΝ ΓΕΡΜΑΝΙΑ 3800 ΕΥΡΩ
3. 42''
ΑΜΟΙ LC 42T1E
http://www.avsite.gr/smf/index.php?topic=13045.0
http://www.avsite.gr/smf/index.php?topic=13041.0
1080p
42 inch 16:9 LCD panel
- 1920΅Α1080 resolution*
- 550 cd/m² panel brightness*
- 8ms response time
- HDMI/DVI in with HDCP
- Smart touch screen buttons
- Exclusive channel rename function
- Built-in ATSC tuner*
- 1000 pages teletext*
- 2 Scart ports*
- DCTi/DLTi
- FTC (Flesh Tone Correction)
- TV system: PAL/SECAM/ATSC/NTSC*
- Optional£Ί
VESA standard wall mount compatible
ΤΙΜΗ ΣΤΗΝ ΕΛΛΑΔΑ 2300 ΕΥΡΩ
SHARP AQUOS LC-42 XD1E
http://www.sharp.de/php/p.php?par=18_no_no_1299
http://www.avsite.gr/smf/index.php?topic=14511.0
1080p
Spezifikationen
# Bild Bildschirmformat 16:9
# Auflφsung 1.920 x 1.080
# Bildpunkte 6.220.800
# Blickwinkel 176°
# Reaktionszeit 6 ms
# OPC (Optische Bildkontrolle)
# Lebensdauer Hintergrundbeleuchtung 60.000 h
# Standbild
# Ton Musikleistung 2 x 15 W
# Audio Volume Control
# Digitaler Verstδrker
# Virtual-Dolby-Surround-Sound
# Clear Voice
# Bedienung Automatische Sendersortierung
# Digital-Bildschirm-Menό in 13 Sprachen
# Multi-Text eingebaut (Top, List, Flof)
# 2.000 Seitenspeicher
# Progressive Scan /
Digital Standbild /
Bild Split - / Bild in Text Funktion
# Quick Shoot Technologie
fόr schnell bewegte Bilder
# Speicher fόr 99 Programme (Analog Tuner)
# Sleep Timer
# Anschlόsse SCART x 2
# HDMI mit HDCP x 2
# AV/S-Video IN
# VGA IN
# AV OUT
# Kopfhφrer
# PC Input (analog RGB)
# RS-232
# CI-Card Slot
# Empfang PAL B/G, D/K, I
# Secam B/G, D/K, L/L
# NTSC όber AV
# NICAM/A2 IGR Stereo-/Zweikanalsystem
# PLL Synthesizer-Hyperband Kabeltuner
# DVB-T Tuner
# Sonstiges Spannungsversorgung: 220-240 V, 50Hz
# Bedienungsanleitung
# Adapterkabel fόr VGA auf YUV
# Abmessungen mit Fuί B: 1.031 mm
# H: 733 mm
# T: 292 mm
ΤΙΜΗ ΣΤΗΝ ΓΕΡΜΑΝΙΑ 2.500 ΕΥΡΩ
TOSHIBA 42WL66P
http://www.toshiba.de/consumer/content/defaultid1_1_id2_3_id3_3.aspx
http://www.home-entertainment.toshi...es/lcdplasma-lcdfreeview-42wlt66?opendocument
1080i
* Visible screen size (cm): 106
* Screen format: 16:9
* Display technology: LCD
* Display resolution: 1920x1080
* High Definition ready
* Full HD (1080)
* Contrast ratio: 800:1
* Brightness (cd/m2): 550
* Comb filter (3D/Digital)
* Active Vision LCD
* Progressive scan
* DNR
* Selectable picture format
* Auto format (WSS)
Interactive Features
* Fastext
* Text page memory
* Digital Text
* EPG
Audio
* NICAM stereo
* Sound output (RMS) W: 20
* SRS WOW
* Bass boost
Tuning
* Digital TV Tuner
* Auto set-up
* Number of channels (Analogue): 100
* Multi-standard tuner
* NTSC video playback
Connections
* HDMI: 2
* Component video
* RGB: 1
* SCART: 2
* Front/side AV input
* PC Input
* Rear audio out
* Headphone
ΤΙΜΗ ΣΤΗΝ ΕΛΛΑΔΑ 2700 ΕΥΡΩ
PHILIPS 42PF9731D/10
http://www.consumer.philips.com/con...&proxybuster=VOOY2XUMLDRFDJ0RMRCSHQFHKFSESI5P
1080i
Εικόνα/Οθόνη
Αντίθεση δυναμικής οθόνης : 4000:1
Χρόνος απόκρισης (τυπικός) : 8 ms
Μήκος διαγωνίου οθόνης (ίντσες) : 4" ίντσα
Μήκος διαγωνίου οθόνης (μετρικό) : 107 εκ.
Βελτίωση εικόνων : Pixel Plus 3 HD, Υποβίβαση κίνησης(Pull-Down) 3/2-2/2, Τρισδιάστατο κτενοειδές φίλτρο 3D, Active Control + Αισθητήρας φωτός, Ψηφιακή τεχνολογία Natural Motion, Βελτίωση δυναμικής αντίθεσης, Jagged Line Suppression, Προοδευτική σάρωση, Pulse Killer Chip, WideScreen Plus
Eικόνα σε Εικόνα : Διπλή οθόνη πλήρους προβολής (2 αρχεία), Διπλή Οθόνη με κείμενο
Τηλεχειριστήριο : Amp, DVD, Sat, STB, Βίντεο, Πολλές λειτουργίες
Τύπος τηλεχειριστηρίου : RC4401
Μετατόπιση υποτίτλων & επικεφαλίδας, Super zoom, Ευρεία οθόνη
Teletext : Hypertext 1,200 σελίδων
Βελτιώσεις Teletext : Habit Watch, Γραμμή πληροφόρησης προγράμματος
Ζώνες δέκτη : Hyperband, S-Channel, UHF, VHF
3 εξ. : YPbPr
Ext 4 : HDMI
Ext 5 : HDMI
ΤΙΜΗ ΣΤΗΝ ΕΛΛΑΔΑ 5000 EURO
ΠΗΓΕΣ 1080i - 1080p
1. HD-DVD
2. BLU - RAY DISC
3. Home Theater PC/b]
4. DVD PLAYERS με upconverting σε 1080p
5. DVD PLAYERS με upconverting σε 1080i
6. DVD RECORDERS με upconverting σε 1080i
7. ΔΟΡΥΦΟΡΙΚΟΙ ΔΕΚΤΕΣ HDTV
Σιγά - σιγά θα συμπληρώνουμε και τις τηλεοράσεις και τις πηγές 1080i - 1080p.
Παρακαλώ πολύ οι συζητήσεις για τις τηλεοράσεις να γίνονται στα αντίστοιχα topic κάθε τηλεόρασης. Το ίδιο ισχύει και για τις πηγές.
Επίσης για νέα μοντέλα τηλεοράσεων 1080i - 1080p καλύτερα να ανοίγουμε νέο θέμα και εγώ θα ενημερώνω και αυτό για τα χαρακτηριστικά του.
Μπραβο Χρηστο πολυ χρησιμο !
Και οταν υπαρχουν αλλαγες στις τιμες να γινονται και τα αναλογα updates , αφου τα τσεκαρεις πρωτα βεβαια .
@ΑΝΔΡΕΑ δεν μπορει να γινει και ενα τετοιο sticky και στις υπολοιπες κατηγοριες με τα αναλογα προιοντα τους
τα σημαντηκοτερα τουλαχιστον πχ φωτο με dslr καλυτρες lcd , satelite με HD , HDD , recievers ,
projectors με 720 , 1080 , και καποιους αξιολογους χαμηλοτερης αναλυσης , κοκ .
Δεν μπορει να γινει κατι τετοιο τι λες ?
gkontoletas
trouble in my brain
Χρήστος Ακρατόπουλος said:
ΠΗΓΕΣ 1080i - 1080p
1. HD-DVD
2. BLU - RAY DISC
3. DVD PLAYERS με upconverting σε 1080p
4. DVD PLAYERS με upconverting σε 1080i
5. DVD RECORDERS με upconverting σε 1080i
6. ΔΟΡΥΦΟΡΙΚΟΙ ΔΕΚΤΕΣ HDTV
Στις πηγές έχει ξεχαστεί το PC.
Παρακαλώ πολύ να μπει στη λίστα και μάλιστα με την σημείωση :
«είναι πάντα πρωτοπόρο, όταν τα PC έδιναν 1080p to 99% των υπολοίπων δεν ήξεραν τι θα πει HD» 8)
Μπράβο Χρήστο.
Μήπως να βάζαμε τις πηγές στις αντίστοιχες κατηγορίες;
Τα 2 μοντελα της Sharp υπαρχουν και απο Ελλαδα στο www.technixx.gr και μαλιστα σε καλυτερες τιμες , 1.929 η 37αρα και 2.379 η 42αρα. Δε μπορω να δωσω link γιατι ειναι περιεργο το format του site, αλλα αμα πατε και ψαξετε θα τις βρειτε. Και σαν σχεση brand-name/τιμης εχουν πολυ καλη, και αποτελουν μια αριστη εναλλακτικη σε οποιον δε θελει να εμπιστευτει τα λεφτα του στην Amoi επιδη ειναι κινεζικη, και χωρις να δωσει πολλα παραπανω, γυρω στα 100 ευρω (κατι περισσοτερο στην 37αρα, κατι λιγοτερο στην 42αρα) παιρνει και κατι πιο επωνυμο που θα τον καθυσηχασει. Χωρις να σημαινει βεβαια οτι θα ειναι καλυτερες απο τις αντιστοιχες Amoi, αλλα εχουν το βασικο (1080p) οποτε τουλαχιστον δε θα κανει σοβαρο συμβιβασμο για να παρει "μαρκα".
Απλά από το συγκεκριμένο κατάστημα δεν ξέρω αν ισχύει η Ελληνική εγγύηση... Τις τηλεοράσεις τις φέρνουν από Γερμανία και παλιότερα τουλάχιστον έλεγαν ότι σε περίπτωση βλάβης την ξαναστέλνεις Θεσσαλονίκη και από εκεί την στέλνουν Γερμανία...
Οι SHARP τελικά είναι 1080p.
Από το επίσημο pdf αρχείο της Sharp όπου παρουσιάζει όλες τις τηλεοράσεις της, αντιγράφω:
"Advanced digital interfaces with 2 HDMI inputs
• Support 1080P HD signal"
Φιλε Χρηστο συγχαρητηρια,ολλα σε ενα κ νοικοκυρεμενα.κατι ερωτησεις εχω?
Εχει μεγαλη διαφορα το 1080ι απο το1080p?
Αν συνδεθουν με υπολογιστη ποιες θα βγαλουν την 1920*1080p?
Τι ειναι το HDCP που το ακουω πολυ συχνα?
Και αν ειχες το ποσο τον 3000 ευρω ποια υγροκρυσταλη θα αγοπαζες?
Ευχαριστω κ ευχομαι να σας δω στην εκθεση
1. Υπάρχει διαφορά μικρή στην εικόνα αλλά μεγάλη στην συνδεσιμότητα (δες στο 2)
2. Μόνο όσες είναι 1080p μπορούν να συνδεθούν με Pc σε ανάλυση 1920Χ1080
3. Το HDCP με λίγα λόγια, είναι ένα πρωτόκολλο "κλειδώματος" των dvd ώστε μόνο όσες tv το έχουν μπορούν να το προβάλουν μέσω hdmi σύνδεσης σε υψηλή ανάλυση.
4. Θα πήγαινα στην Έκθεση και θα τις έβλεπα όλες μαζεμένες... πάντως σίγουρα θα αγόραζα 1080p αν είχα τα χρήματα...
FotisLam
