ΕΠΕΤΕΙΑΚΑ ΜΟΝΤΕΛΑ KENWOOD 25th anniversary
XXV-05V
[General Features]
Number of Pixel: 336,960 pixels
Screen Size: W154.1mm x H87.0mm
New Full-automatic "Z-action"Open/Close Mechanism
Motorized Tilt Angle Adjust (8 Step)
Motorized Back and Forth Display Position Adjust (4 Position)
Multifunction Key Operation
Audio Easy Control Mode
External Hard-key Operation (When Monitor Closed)
Partial Detachable TDF Panel with DSI & Security Code
Mini Display = 5 x 7 Dot Matrix LCD (Blue/Green/Red)
Selectable Key Illumination (Green/Red)
Advanced B.M.S.(Bass Management System) with '02 PS Amplifiers
2-way Telephone/Navigation Mute
Digital Clock (24H)
All-in-one Hide-away Black Box ( 5.1ch DSP/ TV Tuner/Receiver) Supplied
Diversity TV Antenna (Window Type) Supplied
[Audio/Video Features]
Video 2 Input Signal Automatic Detection Mode (Normal/ AUTO/ Rear View Camera)
RGB Input for Kenwood Navigation System Option
SFC/ 4 Band Parametric EQ/ Digital X'over/Digital Time Alignment
Sound Management System (Type of Car & Speaker Size for Each Channel Selectable)
Dolby Digital DRC (Dynamic Range Control : Wide/ Normal/ Midnight)
SPF (Speaker Protect Filter) Operation
[Tuner Features]
FM/MW/LW 24 Station Presets (18FM, 6MW & LW)
AME (Automatic Memory Entry)
Up/Down Seek Tuning
Local Seek
FM Stereo/Mono Selector
[TV Tuner Features]
TV Tuner (PAL/ SECAM)
12 TV Station Presets
Auto Memory Entry
SNPS (Station Name Presets)
[DVD / CD Features]
DVD± / RW Compatible (Video Format Only)
CD Text Ready
CD-R/CD-RW Compatible
Direct Access with Remote
Random/Repeat/Scan Play
[Changer Control Features]
DNPS (Disc Name Presets) with Compatible CD Changers
DNPP (Disc Name Preset Play) by Remote
CD Text Ready with Compatible CD Changers
Random/Repeat/Scan Play (Disc/Track)
[Accessoires]
Centre Speaker Unit (KSC-700CCS/KSC-310CCS)
10 Disc MP3/CD Changer (KDC-C719MP)
10/ 6 Disc CD Changer (KDC-C719/KDC-C669)
iPod Interface (KCA-iP500)
XXV-04S
[KEY FEATURES]
240 Watt Max Input
Power
Oversized 17 cm Woofer
Die-Cast Aluminium Basket
High Quality Crossover Network
Zobel Network for Woofer
Tweeter Protection Circuit
Bi-Amp / Bi-Wire Capable
XXV-03A
[General Features]
25th Anniversary Super Filtering Capacitors for Special Sound Tunning
High Quality Glass Epoxy PCB
Blue LED Display
Amp Control System
Amp Information Display(Voltage/Current/Temperature/Cooling Fan Speed)
Cooling Fan (Computer Controlled)
Detachable Aluminum Dress Plate & Top Panel Control
Gold Plated RCA Line Input/Output Terminals
D-class Amplifier Circuit
1 ohm Load Capability
Built in Parametric EQ Control(Bass Frequency/Gain Control/Bass Q Factor)
Built-in Variable Low-pass Filter 50-200Hz (24dB/oct)
Built-in Infrasonic Filter 15Hz/25Hz (24dB/oct)
Phase Inverter (0°/-180°)
Band Reject Filter Frequency 6dB/12dB (40-200Hz Variable)
Power MOSFET
Power Supply Fuse : 25A x 3
1600watt
XXV-02A
[General Features]
Blue LED Display
Amp Control System
LAPT Power Transistors
Built in Parametric EQ Control(Bass & Treble Frequency/Gain Control/Bass Q Factor)
Built-in Variable Low-pass Filter 50-200Hz (24dB/oct) : B Channel
Built-in Variable High-pass Filter 50-200Hz (12dB/oct) : A/B Channel
Built-in Infrasonic Filter 15Hz (24dB/oct) : B Channel
Power Supply Fuse : 30A x 2
960watt
XXV-01D
[KEY FEATURES]
4 x 50 Watt
3 RCA Pre-outs, 5 Volt
RCA AUX input
MP3/WMA/AAC playback
24 bit DAC (Burr Brown)
Multicolor Full dot OEL
Digital DSP / Digital E’s+
ACDrive technology
IR remote included
Changer control
Electronic slide-down TDF
sitherion
