Ενισχυτής Cambrige Audio Azur 551R
skonst
Πωλείται ο ανωτέρω ραδιοενισχυτής με το τηλεκοντρόλ του σε κατάσταση βιτρίνας στην τιμή των 380 ευρώ.
Χαρακτηριστικά
  • 7-channel amplifier
  • 90 watts per channel into 8 ohms (1k Hz) at 0.006% THD, with 2 channels driven
  • 60 watts per channel into 8 ohms (1k Hz) at 0.006% THD, with 7 channels driven
  • Dolby® TrueHD, DTS-HD™ Master Audio, Pro Logic® IIx, and DTS Neo:6 decoding
  • analog-to-HDMI video upconversion (up to 1080p) via Faroudja FLI3210 video scaler
  • Cambridge Audio Mic Controlled Auto Set (CAMCAS) uses supplied microphone for easy speaker setup
Audio Performance Features:
  • high-current amplifier design
  • Pure Analogue Stereo Direct mode switches off all unused circuitry for the cleanest possible sound
  • back surround speaker channels re-assignable for bi-amping front left and right speakers
  • 192kHz/24-bit digital-to-analog converters for all channels
Connections:
  • 1080p-compatible HDMI digital video switching (4 in, 1 out)
  • HDMI version 1.4a with support for 3D video, Audio Return Channel, Deep Color, x.v.Color, SACD, and auto lip-sync
  • digital audio inputs: 4 optical, 2 coaxial
  • digital audio outputs: 1 optical, 1 coaxial
  • 5 audio/video inputs, including:
    • 1 front-panel input with composite
    • 4 rear-panel inputs with 2 composite video, 2 S-video and 2 component video
  • preamp output for a powered subwoofer
  • 7.1-channel analog audio preamp input
  • 7.1-channel analog audio preamp output for connecting an amplifier
  • RS-232C port for automated control systems
  • detachable power cord
  • direct IR flasher input, and 12V DC trigger out
  • on-screen display for easier system setup and operation (via HDMI only)
  • 30 AM/FM presets
  • receiver remote
  • 16-15/16"W x 4-1/4"H x 14-3/4"D
  • weight: 22 lbs.
Επικοινωνία με pm η στο e-mail: [email protected]
Παρακαλώ όχι ανταλλαγές
  • rose.athens
Xatzisjim
